NvidiaGraphicsFixup
Bloccato
Avatar utente
Connesso
Support Team
Support Team
Reactions:
Grazie dati: 621 volte
Grazie ricevuti: 1188 volte
NvidiaGraphicsFixup
#1
Messaggio da iCanaro » ven mar 09, 2018 7:44 pm
v1.2.7
Fix a name conflict for config variable
v1.2.6 https://github.com/lvs1974/NvidiaGraphicsFixup/releases
Made ngfxcompat=0 explicitly disable NVDAStartupWeb.kext loading from HDD
Disabled AGDC patches for compatible models to avoid issues with IGPU switching on MacBooks
v1.2.5
Hardened solved symbol verification to avoid panics with broken kext cache
Added a workaround to interface lags in 10.13 ( add ngfxsubmit=0 boot-argument to disable)
Fixed improperly working forced driver compatibility from 1.2.4
With this change you may not need to disable Metal support. Make sure to restore CoreDisplay preferences:
sudo defaults delete /Library/Preferences/com.apple.CoreDisplay useMetal
sudo defaults delete /Library/Preferences/com.apple.CoreDisplay useIOP
v 1.2.3 https://github.com/lvs1974/NvidiaGraphicsFixup/releases
Add AAPL,slot-name injection
Fix HDEF layout-id detection
Ultima modifica di iCanaro il gio giu 07, 2018 8:44 am, modificato 3 volte in totale.
My Hack
► Mostra testo
Avatar utente
Connesso
Support Team
Support Team
Reactions:
Re: NvidiaGraphicsFixup
#2
Messaggio da iCanaro » gio mar 29, 2018 7:28 pm
appena sfornati :D
v 1.2.4
Added ngfxgl=1 boot argument (and disable-metal property) to disable Metal support
Added ngfxcompat=1 boot argument (and force-compat property) to ignore compatibility check in NVDAStartupWeb
In order to boot with ngfxgl=1 on 10.13.x you may need to set the defaults:
sudo defaults write /Library/Preferences/com.apple.CoreDisplay useMetal -boolean no
sudo defaults write /Library/Preferences/com.apple.CoreDisplay useIOP -boolean no
My Hack
► Mostra testo
Avatar utente
Non connesso
Site Admin
Site Admin
Reactions:
Grazie dati: 1389 volte
Grazie ricevuti: 1407 volte
Contatta:
#3
Messaggio da Gengik84 » mar apr 03, 2018 5:56 pm
Versione beta allegata 1.2.5 correzioni e miglioramenti confermati per GPU Nvidia e soprattutto pascal
lo allego qui... alla release ufficiale lo rimuoverò
[Guida] MacOS_Clover_USB.
Avatar utente
Connesso
Support Team
Support Team
Reactions:
#4
Messaggio da iCanaro » mar apr 03, 2018 6:22 pm
Ah allora era questa la chicca di cui hai accennato l'altro giorno!!! emoticon_urca stasera ce proviamo subito un paio di benchmark emoticon_41
My Hack
► Mostra testo
Avatar utente
Non connesso
Jahstories
Amministratore
Amministratore
Reactions:
Grazie dati: 57 volte
Grazie ricevuti: 35 volte
Contatta:
#5
Messaggio da Jahstories » mar apr 03, 2018 6:23 pm
Confermo, su 1.2.5
1060 senza 78fps
con 84!
Great!
Leggere le regole del forum. ASUS ROG GL502VM-FY172T Cpu: i7 7700HD Gpu: GeForce 1060 6GB Ram: 16GB DDR4 2400Mhz Wifi/BT: BCM943602BAED
CorsairPro Mobo: ASUS B250F Gaming Cpu: i7 7700 Gpu: Geforce GTX 1070 Ram: 32GB DDR4 3000Mhz Corsair Vengance LED (White) Wifi/BT: BCM943224
Avatar utente
Non connesso
Site Admin
Site Admin
Reactions:
Contatta:
#6
Messaggio da Gengik84 » mar apr 03, 2018 6:24 pm
Non posso provare personalmente...non ho Nvidia.. ma il lavoro svolto è quello di correggere i lag che alcuni utenti hanno
Poi Vit9696 e il suo "team"... EhmBhè... TOP
emoticon_sorriso2
Avatar utente
Connesso
Support Team
Support Team
Reactions:
#7
Messaggio da iCanaro » mar apr 03, 2018 7:35 pm
Ho fatti alcuni bench con cinebech e geekbench prima e dopo il nVidiaGraphicFixup 125 beta e in openCL e non ci stanno significative differenze; mentre nella visione del Sony Bravia OLED 4K Demo http://4kmedia.org/sony-bravia-uhd-hdr-4k-demo/ devo dire che mi è parso un ottimo miglioramento, la 1050 dell'hack 3 in firma si è avvicinata molto alla RX560 dell'hack 2 come fluidità di visione
My Hack
► Mostra testo
Avatar utente
Non connesso
Support Team
Support Team
Reactions:
Grazie dati: 206 volte
Grazie ricevuti: 247 volte
#8
Messaggio da fabiosun » mar apr 03, 2018 7:53 pm
anche io nessun miglioramento, ma devo dire che i lag non ne ho mai visti
@iCanaro che intendi con miglioramenti di visione?
grazie
Gigabyte X299 Designare Ex (F4c bios)
Intel 7980 Xe
Samsung 850 Pro 512 Gb macOS High Sierra
Avatar utente
Connesso
Support Team
Support Team
Reactions:
#9
Messaggio da iCanaro » mar apr 03, 2018 8:59 pm
Esatto... durante la visione, in locale, si aveva qualche microimpuntamento e qualche rallenty mentre con questa versione, seppur beta del nvidiagraphicsfixup la visione è più fluida, non ancora perfetta al 100% ma meglio di prima.
PS: come player ora uso IINA. Pure io mai avuto nessun problema di lag con nessun webdriver
My Hack
► Mostra testo
Avatar utente
Non connesso
Zark63
Donatori
Donatori
Reactions:
Grazie dati: 7 volte
Grazie ricevuti: 7 volte
#10
Messaggio da Zark63 » mar apr 03, 2018 10:09 pm
Provato! Per me nessun beneficio, resto con i 378xxx106, altri che prima usavo nella 10.13.3 che laggavano, qui con la 10.13.4 non vanno schermo nero...al caricamento del driver si riavvia.
Hack_Asrock Z270 extreme 4_Intel I5 7500_16 GB DDR4 Ballistix 2400 Ghz_ Intel I5 7500_
Grafica Nvidia GTX 1050Ti_SSD Samsung 850 Pro 256GB
Avatar utente
Connesso
Support Team
Support Team
Reactions:
#11
Messaggio da iCanaro » dom apr 08, 2018 8:45 am
Dopo l'anteprima che ci è stat gentilmente fornita da gengikn emoticon_41 ecco la versione ufficiale
v1.2.5 https://github.com/lvs1974/NvidiaGraphicsFixup/releases
My Hack
► Mostra testo
Avatar utente
Connesso
Support Team
Support Team
Reactions:
#12
Messaggio da iCanaro » ven apr 13, 2018 2:59 pm
My Hack
► Mostra testo
Avatar utente
Connesso
Support Team
Support Team
Reactions:
#13
Messaggio da iCanaro » gio giu 07, 2018 8:44 am
v1.2.7
My Hack
► Mostra testo
Bloccato
