IntelGraphicsFixup
Bloccato
Avatar utente
Connesso
Support Team
Support Team
Reactions:
Grazie dati: 1013 volte
Grazie ricevuti: 1708 volte
IntelGraphicsFixup
#1
Messaggio da iCanaro » ven mar 09, 2018 7:42 pm
v1.2.7 https://github.com/lvs1974/IntelGraphicsFixup/releases
Add igfxgl=1 boot argument (and disable-metal property) to disable Metal support
Implement Gen6Accelerator with IntelAccelerator rename to fix GVA warnings (use igfxsnb=0 boot argument to disable)
Harden solved symbol verification to avoid panics with broken kext cache
Replace connector-less Sandy Bridge framebuffer for unsupported macmodels from 0x30030 to 0x50000
In order to boot with igfxgl=1 on 10.13.x you may need to set the defaults:
sudo defaults write /Library/Preferences/com.apple.CoreDisplay useMetal -boolean no
sudo defaults write /Library/Preferences/com.apple.CoreDisplay useIOP -boolean no
V 1.2.6
Fix Skylake and KabyLake automatic framebuffer detection
Ensure standard connector-less framebuffers are used
V 1.2.5
Add basic automatic IGPU model detection if it is not set
Add IGPU device id correction (correct device-id should be set via device properties or ACPI
Add basic digital audio correction on (HDAU rename on Haswell and layout-id/hda-gfx where needed)
Add GFX0 -> IGPU automatic rename
Add MEI/HECI -> IMEI automatic rename
Add IMEI device id automatic correction on Sandy Bridge and Ivy Bridge
Add basic automatic AAPL,ig-platform-id injection (defaults to connector-less when AMD/NVIDIA is found)
Add GuC microcode loading on SKL (9.33) and KBL (9.39) in 10.13 (enabled via igfxfw=1 boot-arg)
Add igfxframe=frame boot-arg for framebuffer id injection in testing cases
Fix booting without -disablegfxfirmware boot argument on KBL GPUs
Fix compatibility with connector-less frames
Minor performance improvements
Ultima modifica di iCanaro il mar apr 10, 2018 7:10 pm, modificato 2 volte in totale.
My Hack
► Mostra testo
Avatar utente
Non connesso
Nikino
Donatori
Donatori
Reactions:
Grazie dati: 37 volte
Grazie ricevuti: 16 volte
Re: IntelGraphicsFixup
#2
Messaggio da Nikino » dom mar 11, 2018 11:17 am
per i neofiti come me..., basta soltanto sostituirlo in other? anche Shiki?
Ga-Z370 gaming 5 - I5 8400 - Radeon Rx 470 4Gb - DDR4 16 Gb 3000 mhz - SSHD 2Tb+8Gb - Broadcom BCM94360CD WiFi + BT - macOS 10.14.3 (18D109) su SSD 960 EVO 250Gb + Windows 10 su SSHD SATA3 1Tb + SSHD 1Tb dati Mac - Clover UEFI ultimo agg. - SMBIOS iMac 18,1
Avatar utente
Non connesso
Site Admin
Site Admin
Reactions:
Grazie dati: 1937 volte
Grazie ricevuti: 2247 volte
Contatta:
#3
Messaggio da Gengik84 » dom mar 11, 2018 11:19 am
si ti basta sostituirlo ma controlla sempre quando aggiorni..che lilu sia l'ultima versione
Detto alla "bona" Lilu.kext è la "base"
tutti l'altri sono dei suoi plugins
[Guida] MacOS_Clover_USB.
Avatar utente
Connesso
Support Team
Support Team
Reactions:
#4
Messaggio da iCanaro » dom mar 11, 2018 11:24 am
:D senza LILU tutti questi https://github.com/vit9696/Lilu/blob/ma ... Plugins.md non funzionano, ergo sono tutti alle sue dipendenze
My Hack
► Mostra testo
Avatar utente
Non connesso
Nikino
Donatori
Donatori
Reactions:
#5
Messaggio da Nikino » dom mar 11, 2018 11:49 am
il lilu è del 28 gennaio va bene?
Avatar utente
Non connesso
Baio77
Donatori
Donatori
Reactions:
Grazie dati: 1147 volte
Grazie ricevuti: 614 volte
Contatta:
#6
Messaggio da Baio77 » dom mar 11, 2018 11:52 am
si è l'ultimo disponibile
Avatar utente
Non connesso
Nikino
Donatori
Donatori
Reactions:
#7
Messaggio da Nikino » dom mar 11, 2018 11:53 am
empticons_thu
Avatar utente
Connesso
Support Team
Support Team
Reactions:
#8
Messaggio da iCanaro » dom mar 11, 2018 11:54 am
Se sui KEXT fai destro mouse e selezioni "ottieni informazioni" ti dirà tra le varie cose, quale versione è; vai sul sito di LILU e verifichi se la tua versione è l'ultima disponibile in download ;) se si hai la più aggiornata.
My Hack
► Mostra testo
Avatar utente
Connesso
Support Team
Support Team
Reactions:
#9
Messaggio da iCanaro » mar mar 13, 2018 7:09 pm
V 1.2.6 https://github.com/lvs1974/IntelGraphicsFixup/releases
My Hack
► Mostra testo
Avatar utente
Connesso
Support Team
Support Team
Reactions:
#10
Messaggio da iCanaro » mar apr 10, 2018 7:11 pm
My Hack
► Mostra testo
Bloccato
