OCValidamus
dreamwhite
Salve a tutti,
nel mio tempo libero ho scritto un piccolo script in Python che verifica l'esistenza di:
- ACPI
- Driver
- Kext
- Tool
presenti nelle EFI di OpenCore. Potrebbe risultare utile per coloro che spesso per un motivo o l'altro (come il sottoscritto) si dimenticano di un file abilitato nel config come da screen:
Potete trovare maggiori info qui: https://github.com/dreamwhite/ocvalidamus
  • Like 3
  • Thanks 2
fabio@fabios-Mac-Pro EFI % python3 ocvalidamus.py
							Made with ♡ by dreamwhite
---CHECK ACPI---
Checking 1-SSDT-PLUG.aml (1-SSDT-PLUG)
	- 1-SSDT-PLUG.aml exists
Checking 2-SSDT-SBRG-USBX-v4.aml (2-SSDT-SBRG-USBX-v4.aml)
	- 2-SSDT-SBRG-USBX-v4.aml exists
Checking 5-SSDT-6900XT-v6.aml (5-SSDT-6900XT-v6.aml)
	- 5-SSDT-6900XT-v6.aml exists
Checking SSDT-TB.aml ()
	- SSDT-TB.aml exists
---CHECK Drivers---
Checking OpenRuntime.efi ()
	- OpenRuntime.efi exists
Checking HfsPlus.efi (HFS+ Driver)
	- HfsPlus.efi exists
Checking OpenCanopy.efi ()
	- OpenCanopy.efi exists
Checking ResetNvramEntry.efi ()
	- ResetNvramEntry.efi exists
Checking ToggleSipEntry.efi ()
	- ToggleSipEntry.efi exists
---CHECK Kexts---
Checking Lilu.kext (V1.6.3 | Patch engine)
	- Lilu.kext exist
		- Contents/MacOS/Lilu exists
		- Contents/Info.plist exists
Checking VirtualSMC.kext (V1.3.1 | SMC emulator)
	- VirtualSMC.kext exist
		- Contents/MacOS/VirtualSMC exists
Skipping RestrictEvents.kext (V1.0.9 | RestrictEvents.kext) as it's disabled
Checking AMDRyzenCPUPowerManagement.kext (V0.7.1 | AMD Power Gadget)
	- AMDRyzenCPUPowerManagement.kext exist
		- Contents/MacOS/AMDRyzenCPUPowerManagement exists
Checking AppleMCEReporterDisabler.kext (V1.2)
	- AppleMCEReporterDisabler.kext exist
		-  exists
Skipping WhateverGreen.kext (V1.6.2) as it's disabled
Skipping USBMap.kext (V1.0) as it's disabled
Checking AGPM-RX6900XT.kext (V131)
	- AGPM-RX6900XT.kext exist
		-  exists
---CHECK Tools---
Checking OpenShell.efi (Not signed for security reasons)
	 - OpenShell.efi exists
Skipping ResetSystem.efi (Perform shutdown) as it's disabled
No issues found
Metterei nel read me il fatto che il comando va lanciato entrando precisamente nel volume dove e' la EFI ed il comando
a me con il drag and drop non ha funzionato:
fabio@fabios-Mac-Pro ~ % python3 /Volumes/EFI/ocvalidamus.py
Traceback (most recent call last):
  File "/Volumes/EFI/ocvalidamus.py", line 130, in <module>
    OCValidamus()
  File "/Volumes/EFI/ocvalidamus.py", line 20, in __init__
    with open('EFI/OC/config.plist', 'rb') as f:
FileNotFoundError: [Errno 2] No such file or directory: 'EFI/OC/config.plist'
---CHECK ACPI---
---CHECK Drivers---
---CHECK Kexts---
	- Lilu.kext exist
		-  exists
		-  exists
---CHECK Tools---
No issues found
    OCValidamus()
Hai ragione, stavo pensando a questo punto di fare una cosa del tipo drag-n-drop del config e in automatico prende il full path
