Adobe Lightroom Classic 11.3.1 crashing
Nighthawk99
Hello guys,
I updated today to Lightroom Classic V11.3.1 on my hackintosh (Dell XPS 15 9570), but it crashes on startup.
Is anyone able to run this version by applying some fix?
The previous installed version (V11.0) was running without issues, I revert back to that version for the moment.
Thank you.
It starts perfectly on my Ryzen 9 5950x:
1185737131_Schermata2022-05-29alle11_16_12.thumb.png.232277afbb9d8014ce8c4c97f0fb41c6.png
No patches needed yet, since AMDFriend cannot find any intel specific code.
Search in console app the crash log of Lightroom and post it please.
Hello, thanks for the reply.
I opened up the console app, but the only crash report is the below one, which is not on the date I had this issue.
Am I wrong?
Do you have Big Sur or Monterey on your Ryzentosh?
What is the Camera Raw version?
1312134324_Screenshot2022-06-02at11_44_27.thumb.png.040966e778401735049903c6658d8b5e.png
Edited by Nighthawk99
  • 4 months later...
Update: Seems to be related to network interface. LR 12 is fully functional when using my built in Intel I211 ethernet on Big Sur, but does not work if I switch to USB dongle (which I need to use for Monterey / Ventura).
Any ideas on how I can fix this on Monterey / Ventura?  Can I somehow make my USB dongle appear internal? Force it to be en0?
There is a newly updated I211 driver that seems to be mostly working depending on the motherboard. So far I've only lost connection once. Crossing my fingers this is a longterm solution.
Thank you for letting me use your forum thread to document my self-help journey. Hopefully someone else will find this helpful in the future.
-- original post below --
Did you ever find a solution for this?
Latest version that works for me is 11.0.1. I've tried 11.1, 11.2, 11.3, 11.5, 12. I can get the app to open now, but Develop Module won't load, and I can't import photos. I'm also having trouble with Lightroom cloud sync.
I'm currently running OC 8.3 on a x570 3900x with Monterey 12.6, but also tried Big Sur 11.6 and a fresh install of Monterey. Have not tried Ventura yet. Installed Ventura, same problem no version after 11.0.1 works.
Could it be related to AMD kernel patches? (Edit: Updating to latest kernel Patches for Ventura had no effect. )
Apologies for bumping an old thread, but I'm getting desperate haha
Here is an abbreviated crash report:
Process:               Adobe Lightroom Classic [1766]
Path:                  /Applications/Adobe Lightroom Classic/Adobe Lightroom Classic.app/Contents/MacOS/Adobe Lightroom Classic
Identifier:            com.adobe.LightroomClassicCC7
Version:               12.0.1
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2022-11-01 21:56:25.5188 -0700
OS Version:            macOS 12.6 (21G115)
Report Version:        12
System Integrity Protection: enabled
Crashed Thread:        4  cr_scratch
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
Thread 4 Crashed:: cr_scratch
0   libsystem_kernel.dylib        	    0x7ff807fa600e __pthread_kill + 10
1   libsystem_pthread.dylib       	    0x7ff807fdc1ff pthread_kill + 263
2   libsystem_c.dylib             	    0x7ff807f27d24 abort + 123
3   libc++abi.dylib               	    0x7ff807f98082 abort_message + 241
4   libc++abi.dylib               	    0x7ff807f891a5 demangling_terminate_handler() + 242
5   libobjc.A.dylib               	    0x7ff807e86016 _objc_terminate() + 104
6   libc++abi.dylib               	    0x7ff807f974a7 std::__terminate(void (*)()) + 8
7   libc++abi.dylib               	    0x7ff807f97458 std::terminate() + 56
8   CameraRaw                     	       0x129d97e0b 0x12926f000 + 11701771
9   CameraRaw                     	       0x129a68c51 0x12926f000 + 8363089
10  libsystem_pthread.dylib       	    0x7ff807fdc4e1 _pthread_start + 125
11  libsystem_pthread.dylib       	    0x7ff807fd7f6b thread_start + 15
Thread 4 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x00007000078f6000  rcx: 0x00007000078f5918  rdx: 0x0000000000000000
  rdi: 0x000000000000a10b  rsi: 0x0000000000000006  rbp: 0x00007000078f5940  rsp: 0x00007000078f5918
   r8: 0x00007000078f57e0   r9: 0x00007ff807f9af78  r10: 0x0000000000000000  r11: 0x0000000000000246
  r12: 0x000000000000a10b  r13: 0x0000003000000008  r14: 0x0000000000000006  r15: 0x0000000000000016
  rip: 0x00007ff807fa600e  rfl: 0x0000000000000246  cr2: 0x0000700001a46498
Logical CPU:     0
Error Code:      0x02000148
Trap Number:     133
Edited by pixelfixer
Updated with partial fix
