Gigabyte TRX40 AORUS MASTER (rev. 1.0)
shrisha
@shrishafrom your log:
35:434 00:015 OCABC: MMIO devirt 0xC7100000 (0x81 pages, 0x8000000000000001) skip 0
35:442 00:008 OCABC: MMIO devirt 0xCF180000 (0x81 pages, 0x8000000000000001) skip 0
35:730 00:287 OCABC: MMIO devirt 0xD7180000 (0x81 pages, 0x8000000000000001) skip 0
35:734 00:004 OCABC: MMIO devirt 0xD7300000 (0x100 pages, 0x8000000000000001) skip 0
35:739 00:004 OCABC: MMIO devirt 0xDF100000 (0x181 pages, 0x8000000000000001) skip 0
35:748 00:008 OCABC: MMIO devirt 0xFEA00000 (0x100 pages, 0x8000000000000001) skip 1
35:757 00:009 OCABC: MMIO devirt 0xFEC00000 (0x1 pages, 0x8000000000000001) skip 1
35:766 00:008 OCABC: MMIO devirt 0xFEC10000 (0x1 pages, 0x8000000000000001) skip 1
35:776 00:010 OCABC: MMIO devirt 0xFED00000 (0x1 pages, 0x8000000000000001) skip 1
35:785 00:008 OCABC: MMIO devirt 0xFED40000 (0x5 pages, 0x8000000000000001) skip 1
35:794 00:008 OCABC: MMIO devirt 0xFED80000 (0x10 pages, 0x8000000000000001) skip 1
35:803 00:009 OCABC: MMIO devirt 0xFEDC2000 (0xE pages, 0x8000000000000001) skip 1
35:811 00:008 OCABC: MMIO devirt 0xFEDD4000 (0x2 pages, 0x8000000000000001) skip 1
35:820 00:009 OCABC: MMIO devirt 0xFEE00000 (0x100 pages, 0x8000000000000001) skip 1
35:829 00:008 OCABC: MMIO devirt 0xFF000000 (0x1000 pages, 0x8000000000000001) skip 1
35:838 00:009 OCABC: MMIO devirt 0x2040000000 (0x10400 pages, 0x8000000000000001) skip 0
35:847 00:008 OCABC: MMIO devirt 0x5770000000 (0x10400 pages, 0x8000000000000001) skip 0
35:857 00:010 OCABC: MMIO devirt 0x8EA0000000 (0x10400 pages, 0x8000000000000001) skip 0
35:866 00:008 OCABC: MMIO devirt 0xC5D0000000 (0x10400 pages, 0x8000000000000001) skip 0
Bios changement produced 5 skip 0 in first mmios of your list
try this EFI
I have adjusted your MMIO, reduced some kext (till we will able to boot fine)
Added a couple of SSDTs
I am assuming you are installing a full installer of Monterey 12.x (12.01, 12.1 or 12.2.x)
if it hangs
post as always a photo where it hangs and debug log txt file
PS do not change bios settings from the latest try you did
EFI-Shrisha.zip
Thank you Fabio. You wasn't answering yesterday and I tried few things. After I disabled resize BAR it start booting fine. But installation again rebooted at 40%. Also I disable fTMP as was suggested in some guides. But I will change everything back as it was on a moment of that log what I sent you.
@shrishaour first problem is to have a proper MMIO list
and to achieve it we have to find optimal bios setup and then stay fixed with it 🙂
then we will try to understand why your pc does not complete its installation
have you downloaded a full installer of Monterey?
if so
which version?
Have you ever had in this PC OSX working?
thank you
Yes as I mentioned I downloaded Monterey 12.2.1 official and made bootable USB on real MAC. Yes I have BigSur installed and Monterey 12.1 before. Performance was not really good so I was using it just when I really need something on Mac. Then two weeks ago it's stopped booting with no reason, I was busy with other stuff and yesterday decided to fix it and found your post about clover and decide to try. That's a story 🙂
Ok I tried new EFI and after I choose USB installation disk it hangs at that point what in attachment. Log File is not created, don't know why
3 minutes ago, fabiosun said:
Ok now is all clear
if nothing is broken..we will fix it
here we fixed all problem for many trx40 users! 🙂
Thank you so much. Will appreciate this very much. 🙂
19 minutes ago, fabiosun said:
4g is ON,CSM OFF, UEFI on, Resize bar off?
no overclock on your CPU I hope in BIOS?
Sorry got destructed. But i'm back now. Yes 4g is ON,CSM OFF, UEFI on, but Resize bar is AUTO. No I didn't change anything in my computer. no new hardware what so ever. Just stopped booting with no reason
SUCCESS! Finally installation went through with your clover EFI. I just change UUID serial number and removed your memory info. It reboots few time during installation and now it's fully booted to Monterey!
Few things graphic performance is a bit laggy and no network adapter found 😞
about ethernet, in Monterey could be problematic
you have these ethernet on board :
1 x Aquantia 5GbE LAN chip (5 Gbit/2.5 Gbit/1 Gbit/100 Mbit) (5GLAN)
1 x Intel® GbE LAN chip (10/100/1000 Mbit) (LAN)
Second one is not working for sure if it is a i211 or similar
first one (Aquantia could work with a kext patch)
but it could be problematic in Monterey
in the past which kexts have you to use for them?
Ethernet in Monterey is a different story
Aquantia could work but intel one has some problem from a bit
About GPU performance
with clover is about 5/10 % lower than Opencore in many user testing
By the way
Your CPU seems a bit overclocked
By the way
Is make Aquantia to work difficult?
Do you think go to OpenCore would be better?
Yes it is overclocked but super stable.
