Luminar Neo 0.9.1 fix lib for ryzentosh
Vorshim
Hi there. I apply the patch to libtbbmalloc.dylib and to libtbb.dylib and voilat! I attach the dylib already modified.
just replace it in this directory:
/Applications/Luminar\ Neo.app/Contents/Frameworks/SLFoundation.framework/Versions/A/Frameworks/
and don't forget to give also this command:
sudo codesign --force --deep --sign - /patched library or patched plugin path and file
(or you can simply resign the entire .app)
sudo codesign --force --deep --sign - /Applications/Luminar\ Neo.app
lib patch ryzentosh for Luminar Neo.zip
  • 4 weeks later...
fabio@fabios-Mac-Pro ~ % sudo codesign --force --deep --sign - /Applications/Adobe\ After\ Effects\ 2021/Adobe\ After\ Effects\ 2021.app
Open terminal app and after this:
drag and drop your patched lib or app
