Autodesk Autocad 2022 AMD fix
As in Maya 2022 two libs need a simple fix:
put patched libtbb.dylib in
/Applications/Autodesk/AutoCAD 2022/AutoCAD 2022.app/Contents/Frameworks
and patched libtbbmalloc.dylib in the same
You need to overwrite the files already present there.
If you have SIP enabled you may need to re-sign them:
sudo codesign --force --deep --sign - /Applications/Autodesk/AutoCAD\ 2022/AutoCAD\ 2022.app/Contents/Frameworks/libtbbmalloc.dylib
sudo codesign --force --deep --sign - /Applications/Autodesk/AutoCAD\ 2022/AutoCAD\ 2022.app/Contents/Frameworks/libtbb.dylib
Archive 2.zip
  • Like 3
  • fabiosun changed the title to Autodesk Autocad 2022 AMD fix
Thank you!
  • 1 year later...
Hi Fabiosun,
I run into similar issue with fusion 360 as of the latest release, I used to just copy over the libtbb@2020 version into the app but that no longer works. I see an error about code signing of these libraries but if I force sign the error changes in "libtbb.dylib' not valid for use in process: mapped file has no Team ID and is not a platform binary (signed with custom identity or adhoc?)"
Trying to code sign with my personal developer cert throws another error in codesign:  Warning: unable to build chain to self-signed root for signer "Apple Development: xxxxxxx"
Any clue?
Ok, solved the code signing issue but now I get this: "libtbb.dylib' not valid for use in process: mapping process and mapped file (non-platform) have different Team IDs)"
Original:
codesign -d -v libtbb.dylib
Executable=/Users/xxxxxxxx/Library/Application Support/Autodesk/webdeploy/production/091ac024abfbd3b18cc71f4f8bebd0095c5b58c6/Autodesk Fusion 360.app/Contents/Frameworks/AIRMAX/libtbb.dylib
Identifier=libtbb
Format=Mach-O universal (x86_64 arm64)
CodeDirectory v=20500 size=5490 flags=0x10000(runtime) hashes=166+2 location=embedded
Signature size=9048
Timestamp=6 Apr 2023 at 11:44:38
Info.plist=not bound
TeamIdentifier=XXKJ396S2Y
Runtime Version=10.12.0
Sealed Resources=none
Internal requirements count=1 size=168
Ok, one step further again. If I force code sign the entire AIRMAX library folder with my own identity fusion starts up and I was able to open one of my files but after a few seconds crashes...
After some more tries this seems to be working... 😀
Edited by Rox67er
