Gigabyte B550 Ryzen 9 5900x didn't work EFI Properly............
i have a Gigabyte B550 AMD motherboard & Processor AMD Ryzen 9 5900x. last 6 month i use Hackintosh mac Os Big Sur 11.4 version.
Now i download new version Mac OS Big Sur 11.6.1 & Mac OS Monterey 12.1. I got the Image and EFI. i make properly make
Bootable USB. But this USB didn't work properly. show ACPI r error. last 5 day ill try another EFI still show same problem.
I m so much tired. Pleas give me a proper Solution..
Link to post
@Karigor_Bari welcome here
both your posted EFI are not useful for your AMD rig
One is for an Intel Hackintosh
The best one is set for a 6 cores CPU
By the way, we do not support distros or prebuilt EFI (as olarila one)
try to build a proper EFI or post a working one you used in BS 11.4
ah By the way 2
Your GPU if it is a RX 6600 Xt is supported from latest Monterey 12.1 beta 1 or 2
No support for this GPU in Monterey 12.01 or older OS
Link to post
ah By the way 2
If u any kind help solution....??
Link to post
this you say here is with this rig (amd)?
If so you have to post your working EFI
Otherwise you have to build new one from zero
and I repeat your GPU does not work in Big Sur
Only in Monterey Beta 1
Link to post
I may not be able to explain to you..
with the EFI that i have posted, i am hackintosh another AMD processor  and the is in the Monterey release version.
There was no problem with the other PC, But this is being configured.
if possible, give me an EFI to solve this so that i can do hackintosh.
Gigabyte = B550
AMD Ryzen 9 5900x 12 Core
Graphic = AMD Redeon RX6600
Ram=32gb 3200MHz
SSD=512 M.2
under posted EFI i used another PC and make successfully make Hackintosh
EFI.OpenCore.Desktop.Bulldozer.Jaguar.Ryzen.Threadripper.rar
On 11/17/2021 at 4:16 AM, carlo_67 said:
Post your Efi and a photo of the block
sir you did not reply.
I kept up with all the information i used
Link to post
@Karigor_Bari
Your GPU (graphics card, TX6600) is not compatible for now with Hackintosh
RX 6600 XT yes..but only with latest Monterey beta 12.1
Others component are good
config.plist.zip
this above config is set for your new 12 cores CPU by me
before you had configured as a 6 cores
Edited by fabiosun
added a config.plist for 12 cores CPU
Link to post
4 hours ago, fabiosun said:
@Karigor_Bari
sir i use this config.pilst but now this progress that is. what can i do now...???
And my GPU RX6600IMG20211124161316.thumb.jpg.7e755a16514eac2053d934cf3d0b26f0.jpg
Edited by Karigor_Bari
Link to post
your GPU is not supported (I think)
if you want try this config
config.plist.zip
Link to post
53 minutes ago, Karigor_Bari said:
sir the problem is the same as your thought when i changed another graphics card. So far i have never seen such a problem with 20 PC hackintosh.  Can you create a new EFI for give my cooperation...?
try and post error if it fails 🙂
Link to post
1 hour ago, fabiosun said:
@Karigor_BariI would suggest to create an USB installer with "apple" method (do not use olarila stuff , here no support for "their" tools)
yeh but how can i create..?? don't knows this prosses . sir any tutorial..?? how to make "apple" method..???
Link to post
try before latest EFI posted please
then if you can download Monterey from apple store and if you have a working Hack or Mac you can type from terminal:
sudo /Applications/Install\ macOS\ Monterey.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolumeName
/Volumes/MyVolumeName = your USB pen path
Link to post
Ok & thank u sir for u r suggestion.....ill try ur last giving EFI...
Link to post
Try to disable amd power gadget kext
is it a msi motherboard o r gigabyte?
Hello sir
My Problem is now solved. install macOS Monterey 12.1 ok. but some problem finding
i use 2 monitor 1 monitor ok 2nd monitor not plugin
this mother board wifi device is building but wifi is not work
with mouse work slow
how to solved this problem........??
i use this EFI
Link to post
