[AMD] Clover Vanilla patches
@jsl2000
Lightening the number of patches in the config.plist, leaving only those that are really useful for the systems you have installed,
certainly does not solve your "cosmetic" problem on the CPU name ..
but it helps, maybe, to better understand any others problems
imho you should do this with both clover and OpenCore
Link to post
Aaaaand... it WORKSSSS!!! Very few patches with Clover 5137/5138... Just make sure to have all the kexts updated to the latest release version: BS 11.4, 11.5, MR Beta1/2/3
704052856_Schermata2021-07-24alle17_08_00.thumb.png.2cddd8057ec655754af58e72c3b69280.png
1161917223_Schermata2021-07-24alle17_12_06.thumb.png.032d011ab5546cfe15e61ce6d8f5d92f.png
...somebody just stops at number 2 😉
config.plist.zip
Edited by tomnic
  • Like 4
Link to post
10 hours ago, jsl2000 said:
Yes, your theory and instruction are correct.
Enabled ProvideCurrentCpuInfo Quirk can disable many patches related to core logical string, but my About this Mac issue still bother me up to now.
Only Clover booting can fix it from Catalina to Monterey beta3 and the same issue occured at High Sierra and Mojave too!
[Edit]
No such an issue in FX-6300 hackintoshs from Catalina to Monterey beta3 booted by Clover or OpenCore.
Unfortunately if ProvideCurrentCpuInfo was enabled my Fx-6300 hackintoshs will got red screen KP on booting Legacy OC.
hi Jsl2000, can you help me about amd fx? I try to boot monterey beta 3 this success but, my cpu frequency is wrong over 200mhz, I’m using amd fx 8150
thanks
Link to post
thanks
For Clover you need set CPU parameters as the attached one:
For OpenCore you should set DataHub as mine:
[Edit] Some errors of patches for Replace in both config.plists were corrected.
config-Clover-FX6300.plist.zip config-OC-FX6300.plist.zip
Edited by jsl2000
Link to post
17 hours ago, fabiosun said:
@jsl2000
I need your help and advice to fix one problem I faced OpenCore 0.7.1 or OC PR 0.7.2:
These two versions' ocvalidate always warn me about ReplaceMask of patch 1 & 2 which I need to boot kernel 17.0.0 to 20.x.x
unless I changed from FFFFFFFFFF00 to FFFFFFFFFFFF it can not passed.
In fact after change it can pass ocvalidate, but always failed to boot High Sierra to Big Sur now.
Do you have any solution to fix it ?
In Clover I had the same issue too.
Edited by jsl2000
Link to post
Just now, fabiosun said:
@jsl2000OC PR does not need of any of them...they are included in OpenCore
Do you mean by OC 0.7.1 or 0.7.2 if ProvideCurrentCpuInfo was enabled I don't need patch 0,1, & 2 ?
Or just no need patch 1 & 2 ?
Link to post
OC PR Patches.plist.zip
to explain better (I hope in a better way I mean)
attached here patches I use withOpenCore PR 072
No, only in 072 PR Patches 0,1,2 are included in that quirk
Link to post
Thanks for your explanation which is the great news for all AMD CPU users.
In case of FX-6xxx which can not enable ProvideCurrentCpuInfo Quirk do you have any other solution ?
Link to post
yes..
you can try to use old patch for it
or try to verify better the schema proposed here (I will find for you if you do not find it)
two kind of patches were proposed from the start
one
core number -1 (count 0 and other stuff)
two
a more articulated ones with mask  and replace masking (count 1)
remember..if they have not published in a clear way..a reason could be there 😉
Link to post
@jsl2000
old one:
patch 0 that algrey posted on Insanely Mac is made for my processor in this example
it is very easy to recreate it for other types of cpu (search on this forum new patch, below is the old one😞
PatchProvideCurrentCpuInfo set cpuid_cores_per_package
f:4489EAC1 EA1A
r:BA1F0000 0090
PAY ATTENTION
Value 1F means 31, 3970 x has 32 cores so as stated by @algrey on IM
32 -1=31=1F
IE for a 8 cores  CPU :
8-1=7=07
for 3950x or 5950x 16:
16-1=15=0F
and so on
newer (not latest because it is not public for now...but a good one)
FIND: c1 e8 1a 00 00 00
MASK : FF FD FF 00 00 00
BASE:  _cpuid_set_info
COUNT: 1
REPLACE high sierra to mojave:  b8 XX 00 00 00 00
REPLACE from catalina to big sur :  ba XX 00 00 00 00
REPLACE MASK high sierra to big sur : FF FF FF FF FF 00
REPLACE monterey : ba XX 00 00 00 90
REPLACE MASK monterey : FF FF FF FF FF FF
Link to post
35 minutes ago, fabiosun said:
@jsl2000
old one:
f:4489EAC1 EA1A
r:BA1F0000 0090
PAY ATTENTION
32 -1=31=1F
8-1=7=07
16-1=15=0F
and so on
COUNT: 1
Thanks and that means if I apply the newer patches my current issue will bother me again by ocvalidate warning or interference.
Hope in the near future the developer team of OC or Clover release better solution for FX-6xxx/8xxxx users.
Link to post
@jsl2000old ones work for you (with FX cpu I mean)?
No, in order to boot Monterey beta2 & 3 I apply newer 3 patches in both Clover 5138 and OC 0.7.1 config.plist and it worked well up to now.
Link to post
@jsl2000
thank you so much for the tests you are doing and sharing with the forum
I compiled the latest version of opencore taken from the official github and added the two useful patches for my operating systems (Big Sur 11.4, 11.5 and Monterey 12.b3
The patch for big sur works perfectly even if it does not pass the verification with OC Validate
Tried the same thing with the High Sierra and Mojave patch too
They do not pass the OC Validate validation, but then they work perfectly, allowing you to eliminate many of the patches related to the core logical processor and the core count.
By the way, I allow myself to ask you very humbly, how come you still use all those patches if you use the new ones (0,1)?
Link to post
43 minutes ago, fabiosun said:
@jsl2000
Thanks and I can confirm OC PR 0.7.2 working at Monterey beta3 without these 3 patches in my Ryzen 1700X hackintoshs.
The reason I still kept many extra patches because I am a conservative person and try to keep compatibilities between FX-6300 and Ryzen 1700X hackintoshs from High Sierra to Monterey.
It seems FX-6300 lost support from OC team since Monterey beta1.
I can boot it at FX-6300 because I use previous working patches from High Sierra to Big Sur plus newer one at Ryzen 1700X.
Without these experience and basic info I can not boot both now.
Special thanks for your help and many excellent explanation and advice from here.
In the past I can get support from insanelymac mainly and Shaneee's website sometimes.
But recent 2~3 weeks your website provide the newest and excellent info and support as well as prompt reply which I could not find in any other websites.
Thanks again and again you are the most wonderful person in this forum !
Edited by jsl2000
  • Thanks 2
Link to post
I see an error in your config-OC-FX6300.plist:
1142910214_Screenshot2021-07-26at10_40_07AM.thumb.png.e918f76d8750a93cfee4b93ec0f7647c.png
if you see this:
COUNT: 1
for macOS HighSierra, Mojave, Catalina, BigSur 0090 should be 0000
in this way OCValidate passes with 0 error masking section
Link to post
if you see this:
COUNT: 1
Thanks for your correction and I had similar error for Replace High Sierra to Mojave in Clover's config.plist too.
Link to post
Posted (edited)
Dear Clover's friend 🙂
attached here a minimal set of patches useful to boot these OS:
0) High Sierra
1) Mojave
2) Catalina
3) BigSur (tested 11.4 ,11.5,11.5.1)
4) Monterey(tested Monterey b1,2,3)
if you like and you want to try:
HS_MOJ_CATA_BS_MR.plist.zip
If this set of patches  is not working for you and you like to be useful to understand..post a debug specifying your system and if possible attach here your config.plist used!
Thank you
Edited by fabiosun
UPDATE 27-07-2021 added HS support :)-added also FIX PAT Patches
Link to post
Thanks @carlo_67he noticed I have forgotten a MatchOS for High Sierra in patch 17
so adding in it 10.13.x...bangggg all system start...
I am updating above post 🙂
Link to post
https://github.com/AMD-OSX/AMD_Vanilla/pull/170
I have opened a PR on AMD OSX github where we show all the works done in these months also using Clover bootloader.
thank you to all people who helped to test in different platform !🥰
thanks to:
@iGPU
@carlo_67
@tomnic
@jsl2000
and others users have tested these set of patches 🙂
  • Like 4
Link to post
  • fabiosun changed the title to [AMD] Clover Bootloader Monterey Beta (1 ,2,3,4) installation patches!!
  • fabiosun changed the title to [AMD] Clover Vanilla patches
