Photoshop, After Effects CC 2021, Premiere Pro CC 2021 15.4 AMD hackintosh fix
photoshop work is good,however, there is no response when opening large PSB files (20GB).Ai high processor utilization in empty document.
Edited by wongdi
Link to post
After Effects 18.4.1 build 4
Camera tracking OK
Warp Stabilizer OK
Premiere Pro 15.4.1 build 6
Morph Cut transition OK
Warp Stabiliser Effect OK
Thank you @tomnicyour patching method wins again 🙂
Link to post
Hey Brochachis
PP 15.4.1 Works with the above. Awesome stuff
Also for those who are wondering what are they supposed to do with the two files to patch Premiere Pro
Replace the two files Tommic has attached in the following folder image.thumb.png.4fa583dc64ac916453bbdc963ae0a5d1.png
Link to post
@nikoelif you do not have it patched
could you try this?
RollingShutterRepair
and see if it works for you (I think no)
in that case you have to patch in the same way as previous two
Link to post
could you try this?
Yeah, doesn't work for me. Thankfully I never used it before
Question - if it's patched the old way, then warp stabiliser and morph trans no longer work. Yes?
Link to post
@nikoel
Yes you need new plugin patching method explained by @tomnic
or if you are on 15.4.1 you can use this one attached 🙂
I have tested all others features and to me they seem to work fine
If you find some other errors post it please
Strangely it seems no many users are interested in public of this subjetct
Weird..on OSX Adobe suite is a must from many years and now that it is working pretty perfectly without doing many quirks.... 🙂 🙂
AEFilterRollingShutter.bundle.zip
Link to post
48 minutes ago, fabiosun said:
@nikoel
If you fine some other errors post it please
You file works! I have the latest PP as you
Thank you
Yes it is strange. I think this is because of the adobe AMD fixes github page. People just copy and paste the solution and assume the rest (eg Warp Stabiliser / Tracking / Neural Engine etc... will never work without an intel machine
Edited by nikoel
Link to post
Thank you
...yes, I think it is the same psychological mechanism, and it is easier to sell the AMD rig and buy an Intel CPU + Mainboard or stick with Unraid / Proxmox hypervisors
  • whahahah 1
Link to post
Just now, fabiosun said:
I would like to find a pc faster than one similar to mine on intel side 🙂
They think that everything is optimized for Intel in every os, it is true but now we have the prove that Intel simply cheats with its own software libraries... faking the AMD cpus to be Intel we get the same performances, and we lack AVX512...
Link to post
10 hours ago, fk2106 said:
Very nice! it's working for me as well. I'm able to get Pugetbench to complete in Photoshop and After Effects.
Adobe Premiere does not complete so I think there might be more plugins that need patching...
Have you patched all three mandatory plugin ? (you can find in this thread)
Which Premiere version Exactly?
And which Puget benchmark version exactly?
Thank you
Edit it hangs here also on an Intel platform:
Edited by fabiosun
Edit
Link to post
Hey guys,
thanks for all the work you put into this! I am new to the party and I just wanted two things to work:
the warp stabilizer in latest Premiere Pro, do I just need to replace those two files or is more necessary?
Photoshop closes when I for example open a cloud document, how do I fix that?
Link to post
@tomnic Excellent work! Gonna try this on Photoshop beta 23.
Could you take a look at this for Camtasia 2019? (Camtasia 2 mid version works in AMD but ever since Oct 2016 version onwards of Camtasia 2 and upto version 2020 it fails. Here's the Camtasia 2019 lib failure.
Process:               Camtasia 2019 [12254]
Path:                  /Applications/Camtasia 2019.app/Contents/MacOS/Camtasia 2019
Identifier:            com.techsmith.camtasia2019
Version:               2019.0.7 (109599)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Camtasia 2019 [12254]
User ID:               501
Date/Time:             2021-10-20 16:26:07.674 +0100
OS Version:            macOS 11.6.1 (20G221)
Report Version:        12
Anonymous UUID:        CFD7290E-9754-1ABA-09FD-A8BF8CD3C8BB
Time Awake Since Boot: 100000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x00007ffee5a51ff8
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [12254]
VM Regions Near 0x7ffee5a51ff8:
    MALLOC_MEDIUM (reserved) 7f9ef0800000-7f9ef8000000 [120.0M] rw-/rwx SM=NUL  reserved VM address space (unallocated)
--> STACK GUARD              7ffee2252000-7ffee5a52000 [ 56.0M] ---/rwx SM=NUL  stack guard for thread 0
    Stack                    7ffee5a52000-7ffee6252000 [ 8192K] rw-/rwx SM=SHM  thread 0
Application Specific Information:
/Applications/Camtasia 2019.app/Contents/MacOS/../Frameworks/StatsLoaders.framework/Versions/A/StatsLoaders
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   com.techsmith.StatsLoaders        0x000000010e732841 _intel_fast_memset.A + 1
1   dyld                              0x0000000115424f52 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 40
2   dyld                              0x000000011541fae6 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 492
3   dyld                              0x000000011541fa51 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 343
4   dyld                              0x000000011541fa51 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 343
5   dyld                              0x000000011541d89f ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 191
6   dyld                              0x000000011541d940 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 82
7   dyld                              0x00000001154098b1 dyld::initializeMainExecutable() + 199
8   dyld                              0x0000000115410041 dyld::_main(macho_header const*, unsigned long, int, char const**, char const**, char const**, unsigned long*) + 9098
9   dyld                              0x0000000115408224 dyldbootstrap::start(dyld3::MachOLoaded const*, int, char const**, dyld3::MachOLoaded const*, unsigned long*) + 450
10  dyld                              0x0000000115408025 _dyld_start + 37
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x000000010e86d6e0  rbx: 0x000000010e5952f0  rcx: 0x00000007389d97ff  rdx: 0x0000000000001000
  rdi: 0x000000010e7a3a28  rsi: 0x00000000ffffffff  rbp: 0x00007ffee6249dd0  rsp: 0x00007ffee5a52000
   r8: 0x0000000000000001   r9: 0x0000000000000006  r10: 0x0000000000000000  r11: 0x0000000000000000
  r12: 0x000000010e7a3220  r13: 0x00007ffee6249c80  r14: 0x00007fff806ebd78  r15: 0x0000000000000000
  rip: 0x000000010e732841  rfl: 0x0000000000010202  cr2: 0x00007ffee5a51ff8
Logical CPU:     34
Error Code:      0x00000006 (no mapping for user data write)
Trap Number:     14
Thread 0 instruction stream:
  41 81 e1 ff 01 00 00 41-81 f9 ff 01 00 00 75 09  A......A......u.
  48 83 c4 08 e9 46 ff ff-ff 44 8a 00 41 80 e0 7f  H....F...D..A...
  41 80 f8 7f 75 09 48 83-c4 08 e9 20 ff ff ff f6  A...u.H.... ....
  00 01 74 09 48 83 c4 08-e9 02 ff ff ff e8 cd ee  ..t.H...........
  ff ff e9 6a ff ff ff 0f-1f 84 00 00 00 00 00 90  ...j............
  90 90 90 90 90 90 90 90-90 90 90 90 90 90 90 56  ...............V
 [e8]3a 00 00 00 59 c3 0f-1f 84 00 00 00 00 00 e9  .:...Y..........    <==
  bb 74 00 00 0f 1f 40 00-0f 1f 80 00 00 00 00 e9  .t....@.........
  ab 4c 00 00 0f 1f 40 00-0f 1f 80 00 00 00 00 e9  .L....@.........
  4b 1c 00 00 0f 1f 40 00-0f 1f 80 00 00 00 00 56  K.....@........V
  48 b9 ff 97 9d 38 07 00-00 00 48 8d 05 4e ae 13  H....8....H..N..
  00 4c 8b 00 4c 23 c1 4c-3b c1 75 09 48 83 c4 08  .L..L#.L;.u.H...
Thread 0 last branch register state not available.
Binary Images:
       0x1099ae000 -        0x1099c6fff +com.techsmith.camtasia2019 (2019.0.7 - 109599) <91BF2823-2D02-33AC-ACDB-8E19A21D28D1> /Applications/Camtasia 2019.app/Contents/MacOS/Camtasia 2019
       0x1099d7000 -        0x109a15fff +org.sparkle-project.Sparkle (1.16.0 1-g03abfe27 - 1.16.0) <7C18DCA0-8C47-3900-B07B-5A126FA9A415> /Applications/Camtasia 2019.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
       0x109a5d000 -        0x109a6cfff +libTSCLicensing.dylib (0) <B2E828AA-EECB-3498-883F-3079C89E2562> /Applications/Camtasia 2019.app/Contents/Frameworks/libTSCLicensing.dylib
       0x109a82000 -        0x109bf5fff +libCSRenderLib.dylib (0) <A188FF1B-D16B-3638-9B94-6E8D76FD17B5> /Applications/Camtasia 2019.app/Contents/Frameworks/libCSRenderLib.dylib
       0x109d9f000 -        0x109da6fff +libCSAudioAnalyzer.dylib (0) <17596B0E-BEB4-3B21-9E67-F6C2B1CF5AF7> /Applications/Camtasia 2019.app/Contents/Frameworks/libCSAudioAnalyzer.dylib
       0x109dbb000 -        0x10a316fff +libCSMediaLib.dylib (0) <85F258D7-CB31-303F-89FB-F92A3CEC6DA6> /Applications/Camtasia 2019.app/Contents/Frameworks/libCSMediaLib.dylib
       0x10a9a0000 -        0x10aa96fff +librui_5.2.0.x64.dylib (0) <9EAF4F8D-409F-3F51-BB0A-EA2C995041DF> /Applications/Camtasia 2019.app/Contents/Frameworks/librui_5.2.0.x64.dylib
       0x10aab8000 -        0x10aabffff +libCSMediaLibUtl.dylib (0) <315BDB99-509E-3546-9EFC-5F9E135BCDC1> /Applications/Camtasia 2019.app/Contents/Frameworks/libCSMediaLibUtl.dylib
       0x10aade000 -        0x10aaf3fff +com.techsmith.TSCVST (1.0 - 1) <6A7B7B93-0643-36D4-9BE4-88DB48748EDC> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCVST.framework/Versions/A/TSCVST
       0x10ab20000 -        0x10b62cfff +libXRenderLib.dylib (0) <ED0F346F-031B-3D09-A4EA-A9B9AAB9CEA5> /Applications/Camtasia 2019.app/Contents/Frameworks/libXRenderLib.dylib
       0x10b9f4000 -        0x10ba00fff +com.techsmith.TSCWriter.TSCWriter-Framework- (1.0 - 1) <9B505C75-C750-3367-AA56-EED90AB58D88> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCWriter.framework/Versions/A/TSCWriter
       0x10ba26000 -        0x10ba28fff +com.techsmith.ACEInstaller (1.0 - 1) <CD06B3E9-A867-3760-8B16-B536523495F1> /Applications/Camtasia 2019.app/Contents/Frameworks/ACEInstaller.framework/Versions/A/ACEInstaller
       0x10ba30000 -        0x10ba33fff +com.kulakov.PTHotKey (2.0) <73F1E771-E710-3476-A00C-E3DEB8ECDA40> /Applications/Camtasia 2019.app/Contents/Frameworks/PTHotKey.framework/Versions/A/PTHotKey
       0x10ba3f000 -        0x10ba56fff +org.mantle.Mantle (1.0 - ???) <930F61E7-D838-35D7-9A85-DC3C1E0B26E0> /Applications/Camtasia 2019.app/Contents/Frameworks/Mantle.framework/Versions/A/Mantle
       0x10ba6a000 -        0x10ba8bfff +com.TechSmith.TSCStorage (1.0 - 1) <65C2FAA4-E64B-3E6A-97D8-3A185261789B> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCStorage.framework/Versions/A/TSCStorage
       0x10baa7000 -        0x10baa8fff +com.techsmith.TSCEntitlement (1.0 - 1) <DA54AFD7-B543-3CE0-B5C9-C755082C80E0> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCEntitlement.framework/Versions/A/TSCEntitlement
       0x10bab2000 -        0x10bac2fff +libAudioExtractionLib.dylib (0) <2CBF4651-56DA-3BB4-80A8-077A1111C061> /Applications/Camtasia 2019.app/Contents/Frameworks/libAudioExtractionLib.dylib
       0x10baea000 -        0x10bb1efff +com.techsmith.TSCConnectServer (1.0 - 1) <84DE428E-91B0-3036-86B3-2F2D85CC0F52> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCConnectServer.framework/Versions/A/TSCConnectServer
       0x10bb51000 -        0x10bb71fff +com.alamofire.AFNetworking (3.0.0 - 3.1.0) <83215663-DFFB-3B93-AD61-AB13CE629818> /Applications/Camtasia 2019.app/Contents/Frameworks/AFNetworking.framework/Versions/A/AFNetworking
       0x10bb96000 -        0x10bb9bfff +com.techsmith.TSCCloudServices (1.0 - 1) <CFDD6922-8C01-3313-8197-54F1EA3CD894> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCCloudServices.framework/Versions/A/TSCCloudServices
       0x10bbae000 -        0x10bbc8fff +com.techsmith.TSCCloud.TSCCloud (1.0 - 1) <B9C31B0E-9E78-3433-871B-75C36198DB64> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCCloud.framework/Versions/A/TSCCloud
       0x10bc10000 -        0x10bc1afff +com.TechSmith.TSCAccount (1.0 - 1) <F6AA5337-9F8F-3F8B-8B4D-B6BF7D7702EA> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCAccount.framework/Versions/A/TSCAccount
       0x10bc29000 -        0x10c3e2fff +com.TechSmith.CocoaCSEditor (0.1 - 1) <0FA3FEF0-F2BD-3B43-8CCD-797571543809> /Applications/Camtasia 2019.app/Contents/Frameworks/CocoaCSEditor.framework/Versions/A/CocoaCSEditor
       0x10ca73000 -        0x10ca7dfff +com.techsmith.GIFMaker (1.0 - 1) <AD7A1233-78AC-3809-93D1-639D1F8B8486> /Applications/Camtasia 2019.app/Contents/Frameworks/GIFMaker.framework/Versions/A/GIFMaker
       0x10ca90000 -        0x10ca96fff +libSmartFocusCmds.dylib (0) <21C5327D-3999-33FE-8691-0C5625650C21> /Applications/Camtasia 2019.app/Contents/Frameworks/libSmartFocusCmds.dylib
       0x10caa8000 -        0x10caaffff +com.techsmith.TechSmithZip (1.0 - 1) <B01C4F4E-D9AD-3A88-BF5C-F629D92A68CC> /Applications/Camtasia 2019.app/Contents/Frameworks/TechSmithZip.framework/Versions/A/TechSmithZip
       0x10cabc000 -        0x10cb2afff +libCamtasiaCommon.dylib (0) <4B4026F0-E55B-30BE-9C88-9EC546C19D4A> /Applications/Camtasia 2019.app/Contents/Frameworks/libCamtasiaCommon.dylib
       0x10cba9000 -        0x10cbbcfff +com.yourcompany.yourcocoaframework (1.0) <F1822A00-CB42-33F5-9DBA-C6904106BE4B> /Applications/Camtasia 2019.app/Contents/Frameworks/ScreencastFramework.framework/Versions/A/ScreencastFramework
       0x10cbd8000 -        0x10cbfefff +libSmartFocus.dylib (0) <94CFD256-93C7-358F-9C6F-5BBA7037952D> /Applications/Camtasia 2019.app/Contents/Frameworks/libSmartFocus.dylib
       0x10cc21000 -        0x10cc2cfff +com.mainconcept.mc.config.avc (10.0 - 10.0.14.2531) <E862E269-A68A-3A36-B276-41ED09F405DA> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_config_avc.framework/Versions/10/mc_config_avc
       0x10cc36000 -        0x10cc71fff +com.techsmith.mc-dec-aac (1.0 - 1) <F4837B8A-031B-332D-BD31-DCE9DD560486> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_dec_aac.framework/Versions/10/mc_dec_aac
       0x10cc7b000 -        0x10ce84fff +com.techsmith.mc-dec-avc (1.0 - 1) <C8FB6C3C-3F66-38DC-866A-56B6D610B843> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_dec_avc.framework/Versions/10/mc_dec_avc
       0x10ce9b000 -        0x10ced4fff +com.techsmith.mc-enc-aac (1.0 - 1) <567E4C2E-1938-3E30-B38E-3D107117E6AD> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_enc_aac.framework/Versions/10/mc_enc_aac
       0x10cede000 -        0x10d270fff +CSEditorLib.dylib (0) <FCFFA4D3-ADDB-31B6-87BB-DE9632A0974B> /Applications/Camtasia 2019.app/Contents/Frameworks/CSEditorLib.dylib
       0x10d749000 -        0x10da7dfff +com.techsmith.mc-enc-avc (1.0 - 1) <9D208970-2BF3-38DD-B785-C93D120BC83D> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_enc_avc.framework/Versions/10/mc_enc_avc
       0x10dab1000 -        0x10de92fff +com.mainconcept.mc.mux.mp4 (10.0 - 10.0.14.2531) <37D00BD7-6CB2-3004-B425-2ECBE5EC89B4> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/10/mc_mux_mp4
       0x10ded0000 -        0x10ded1fff +com.techsmith.PdfSupport (1.0 - 1) <800B6587-0E01-3429-B7BF-B985448B1AD9> /Applications/Camtasia 2019.app/Contents/Frameworks/PdfSupport.framework/Versions/A/PdfSupport
       0x10dee2000 -        0x10df4afff +com.techsmith.RemixCallouts (1.0 - 1) <64C232BB-D26E-3178-A8BA-79D28527E2D8> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/RemixCallouts
       0x10e026000 -        0x10e0aafff +com.techsmith.TechSmithKit (1.0 - 1) <89D7415A-8B06-370C-80A6-2B2DB657EE7A> /Applications/Camtasia 2019.app/Contents/Frameworks/TechSmithKit.framework/Versions/A/TechSmithKit
       0x10e146000 -        0x10e1d1fff +com.techsmith.GTL (2.0) <F3DF20A8-9A7B-30D4-8FC8-F75115153387> /Applications/Camtasia 2019.app/Contents/Frameworks/GTL.framework/Versions/A/GTL
       0x10e258000 -        0x10e32efff +com.techsmith.TSCCapture (1.0 - 1) <160F0C26-8CE0-3AF7-8A25-9E523539BB40> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCCapture.framework/Versions/A/TSCCapture
       0x10e480000 -        0x10e48cfff +com.kulakov.ShortcutRecorder (2.0) <35616DF8-0B7B-3680-B315-421528FA8777> /Applications/Camtasia 2019.app/Contents/Frameworks/ShortcutRecorder.framework/Versions/A/ShortcutRecorder
       0x10e49e000 -        0x10e4d4fff +com.techsmith.TSCRegionSelection (1.0) <482B4E48-EA5A-3CF2-85CF-25BE9B14C0FC> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCRegionSelection.framework/Versions/A/TSCRegionSelection
       0x10e502000 -        0x10e50ffff +com.techsmith.TSCSharing (1.0 - 1) <845FD71B-6A80-3D5A-923D-4BD2D843E170> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCSharing.framework/Versions/A/TSCSharing
       0x10e525000 -        0x10e52bfff +com.techsmith.TSCSharingPlugin (1.0 - 1) <5D47E3F2-AD78-301F-A53D-70881A7CD02A> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCSharingPlugin.framework/Versions/A/TSCSharingPlugin
       0x10e538000 -        0x10e77efff +com.techsmith.StatsLoaders (1.0 - 1) <A5A5F743-891E-3C69-AB75-11C982DB23C7> /Applications/Camtasia 2019.app/Contents/Frameworks/StatsLoaders.framework/Versions/A/StatsLoaders
       0x10e9a8000 -        0x10e9d6fff +libfontconfig.1.dylib (0) <9875A1E4-324A-353E-A9B3-0D8863DBFFF9> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libfontconfig.1.dylib
       0x10e9f0000 -        0x10ea9cfff +libcairo.2.dylib (0) <D651C1D8-8146-3CF1-8CBB-8E7444679EEF> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libcairo.2.dylib
       0x10ead1000 -        0x10eb4efff +libfreetype.6.dylib (0) <6A0A1CF7-9729-3B75-A1C3-75B6A4D10E95> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libfreetype.6.dylib
       0x10eb71000 -        0x10eb9dfff +libpango-1.0.0.dylib (0) <C0056E53-306C-3DF5-8CDB-FC08ADBBC672> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpango-1.0.0.dylib
       0x10ebba000 -        0x10ebc6fff +libpangoft2-1.0.0.dylib (0) <91C9F8C4-884E-379A-93F1-59D19FF3BA21> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpangoft2-1.0.0.dylib
       0x10ebdb000 -        0x10ebe4fff +libpangocairo-1.0.0.dylib (0) <2587A8C1-EA83-3BE1-B847-0E70B58C5B71> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpangocairo-1.0.0.dylib
       0x10ebf5000 -        0x10ebfafff +libffi.6.dylib (0) <700FEC96-07A8-3D27-9458-60B8BEB7070E> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libffi.6.dylib
       0x10ec04000 -        0x10ec0dfff +libintl.8.dylib (0) <901CA836-8F7A-392A-8201-10CDEDF4F8F9> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libintl.8.dylib
       0x10ec1c000 -        0x10ec3ffff +libpng16.16.dylib (0) <FA0BEF1C-677C-30F2-B904-B569D6F4D533> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpng16.16.dylib
       0x10ec4e000 -        0x10ed52fff +libgio-2.0.0.dylib (0) <1FA5213D-7E29-3082-8ABC-14C628CDE889> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libgio-2.0.0.dylib
       0x10edcd000 -        0x10ee9bfff +libglib-2.0.0.dylib (0) <95E0497B-72E1-3DD8-B114-82DBD3646166> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libglib-2.0.0.dylib
       0x10eece000 -        0x10eed2fff +libgmodule-2.0.0.dylib (0) <B24CBC1D-8A99-3844-B26B-314424472384> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libgmodule-2.0.0.dylib
       0x10eedd000 -        0x10ef56fff +libpixman-1.0.dylib (0) <F43AA1C9-41F6-330A-AE25-168FB5077A6E> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpixman-1.0.dylib
       0x10ef74000 -        0x10efa8fff +libgobject-2.0.0.dylib (0) <D36577DF-8525-368F-9106-0A0D5C61FF72> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libgobject-2.0.0.dylib
       0x10efc0000 -        0x10efc3fff +libgthread-2.0.0.dylib (0) <6A010CFC-7297-3A7D-B47D-0606705C7ACF> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libgthread-2.0.0.dylib
       0x10efcf000 -        0x10efe7fff +libfribidi.0.dylib (0) <A3C6AE05-965B-3728-A61E-BDDD897D95EB> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libfribidi.0.dylib
       0x10eff3000 -        0x10f05bfff +libpcre.1.dylib (0) <BB83A439-9634-333B-9B10-604C57C703DE> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpcre.1.dylib
       0x10f069000 -        0x10f0e8fff +libharfbuzz.0.dylib (0) <374D2AA1-33D2-346E-87F6-220E804EF022> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libharfbuzz.0.dylib
       0x10f10a000 -        0x10f11afff +com.rogueamoeba.ACE (11.0.0 - 11.0.0) <5FB661E7-50DF-385B-98D9-DBF75A484952> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCCapture.framework/Versions/A/Frameworks/ACE.framework/Versions/A/ACE
       0x10f12f000 -        0x10f32cfff +libDecoderLib.dylib (0) <69A6A3A2-C932-3719-AFF3-602CC50C9291> /Applications/Camtasia 2019.app/Contents/Frameworks/libDecoderLib.dylib
       0x10f4b0000 -        0x10f4b6fff +libCSThumbnailer.dylib (0) <CAC36A79-9292-3CE6-BF32-1955322B26F3> /Applications/Camtasia 2019.app/Contents/Frameworks/libCSThumbnailer.dylib
       0x10f504000 -        0x10f515fff +at.nih.libzip (1.3.1a - 1) <45E4772F-A697-3582-8AD7-E93D7AA0BFDC> /Applications/Camtasia 2019.app/Contents/Frameworks/libzip.framework/Versions/A/libzip
       0x115407000 -        0x1154a2fff  dyld (852.2) <14C5D17F-5032-37A2-9CD8-F437EB4A3992> /usr/lib/dyld
    0x7fff200eb000 -     0x7fff200ecfff  libsystem_blocks.dylib (79) <4DF6D8F5-D9C2-3A96-8DE4-5E99D6B73DC8> /usr/lib/system/libsystem_blocks.dylib
    0x7fff200ed000 -     0x7fff20122fff  libxpc.dylib (2038.120.1) <0397FC9F-BD11-31FC-882E-9EDAA1E5CA65> /usr/lib/system/libxpc.dylib
    0x7fff20123000 -     0x7fff2013afff  libsystem_trace.dylib (1277.120.1) <0A24EB90-5396-36B0-A7E6-E9288702856D> /usr/lib/system/libsystem_trace.dylib
    0x7fff2013b000 -     0x7fff201d8fff  libcorecrypto.dylib (1000.140.4) <57E7471E-3960-3398-8918-20DF446EA99B> /usr/lib/system/libcorecrypto.dylib
    0x7fff201d9000 -     0x7fff20205fff  libsystem_malloc.dylib (317.140.5) <10C22FD0-FC7B-3325-852E-FEC4E88D2BC5> /usr/lib/system/libsystem_malloc.dylib
    0x7fff20206000 -     0x7fff2024afff  libdispatch.dylib (1271.120.2) <BA7AD614-F2C2-3E89-9043-43DD548AE5B1> /usr/lib/system/libdispatch.dylib
    0x7fff2024b000 -     0x7fff20284fff  libobjc.A.dylib (824) <712AAE11-4AB9-39A1-A860-A5BF2CD4B932> /usr/lib/libobjc.A.dylib
    0x7fff20285000 -     0x7fff20287fff  libsystem_featureflags.dylib (28.60.1) <6EB33926-8E22-3000-B2F1-C6182B8CBD8F> /usr/lib/system/libsystem_featureflags.dylib
    0x7fff20288000 -     0x7fff20310fff  libsystem_c.dylib (1439.141.1) <8447A4B8-0751-3EF1-AA9B-042E40EFA07D> /usr/lib/system/libsystem_c.dylib
    0x7fff20311000 -     0x7fff20366fff  libc++.1.dylib (905.6) <81674ADB-670F-3B19-AF5D-F3F66CB93D44> /usr/lib/libc++.1.dylib
    0x7fff20367000 -     0x7fff2037cfff  libc++abi.dylib (905.6) <78CE7863-E224-3D0B-98F1-E5E3E382322D> /usr/lib/libc++abi.dylib
    0x7fff2037d000 -     0x7fff203acfff  libsystem_kernel.dylib (7195.141.8) <8DFE5B9F-B718-3D48-ABB1-238122989218> /usr/lib/system/libsystem_kernel.dylib
    0x7fff203ad000 -     0x7fff203b8fff  libsystem_pthread.dylib (454.120.2) <49670AEC-4D5D-3383-906C-23F568351FCB> /usr/lib/system/libsystem_pthread.dylib
    0x7fff203b9000 -     0x7fff203f4fff  libdyld.dylib (852.2) <5FBD0E1A-ACCE-36DB-B11C-622F26C85132> /usr/lib/system/libdyld.dylib
    0x7fff203f5000 -     0x7fff203fefff  libsystem_platform.dylib (254.80.2) <A85D12B6-6213-34EE-84D8-8E993C19E330> /usr/lib/system/libsystem_platform.dylib
    0x7fff203ff000 -     0x7fff2042afff  libsystem_info.dylib (542.40.3) <36329FC6-9982-306A-87F9-D018E7F49F4B> /usr/lib/system/libsystem_info.dylib
    0x7fff2042b000 -     0x7fff208c9fff  com.apple.CoreFoundation (6.9 - 1778.101) <4A04F6EA-DE8D-3EBB-B9BA-8C90C6F019DD> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff208ca000 -     0x7fff20afffff  com.apple.LaunchServices (1122.45 - 1122.45) <2E70B4AB-38AF-37CC-A45B-ABEE3421A3A0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff20b00000 -     0x7fff20bd4fff  com.apple.gpusw.MetalTools (1.0 - 1) <72B42432-B432-381F-8EA6-F1B829C3EE5D> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff20bd5000 -     0x7fff20d5bfff  libBLAS.dylib (1336.140.1) <2C2F4402-DB7D-3F4C-AB33-2774B4016A17> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff20d5c000 -     0x7fff20da9fff  com.apple.Lexicon-framework (1.0 - 86.2) <FE0BC1AF-D1A0-3A6B-A404-A187AEF07704> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff20daa000 -     0x7fff20e18fff  libSparse.dylib (106) <95043C27-910C-3B53-ADE7-0E7907E579C9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff20e19000 -     0x7fff20e96fff  com.apple.SystemConfiguration (1.20 - 1.20) <AE4BE9DB-6F7D-3D4A-BA51-D86DDFC6B5B2> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff20e97000 -     0x7fff20ecbfff  libCRFSuite.dylib (50) <95816B40-6F71-33EB-9324-E2942543DDD4> /usr/lib/libCRFSuite.dylib
    0x7fff20ecc000 -     0x7fff21104fff  libmecabra.dylib (929.10) <1E492E01-642F-3A9D-8A04-CF648C32696C> /usr/lib/libmecabra.dylib
    0x7fff21105000 -     0x7fff21463fff  com.apple.Foundation (6.9 - 1778.101) <68B22A79-76E0-3BE4-9B53-0F38991C5A08> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff21464000 -     0x7fff2154cfff  com.apple.LanguageModeling (1.0 - 247.3) <D7E3186D-41DD-3826-85C8-D9ECC7D17197> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff2154d000 -     0x7fff21683fff  com.apple.CoreDisplay (237.4 - 237.4) <07520DBC-E1BB-310C-AD92-6F313820D60E> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff21684000 -     0x7fff218f4fff  com.apple.audio.AudioToolboxCore (1.0 - 1181.72.1) <92B2E9B6-7FA8-3BE5-AD1A-25A2BC36821E> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
    0x7fff218f5000 -     0x7fff21adafff  com.apple.CoreText (677.6.0.2 - 677.6.0.2) <4C194C5B-3B53-347A-B558-AF0070B6D27B> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff21adb000 -     0x7fff2216cfff  com.apple.audio.CoreAudio (5.0 - 5.0) <7178815E-1890-3A3D-B0FD-F93EBB529E78> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff2216d000 -     0x7fff224c4fff  com.apple.security (7.0 - 59754.141.1) <7EC1D1C5-672E-3DFD-902C-D511ECE6C110> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff224c5000 -     0x7fff22724fff  libicucore.A.dylib (66112) <251FC896-7EA1-3505-A9AA-80BAE7A6FD2B> /usr/lib/libicucore.A.dylib
    0x7fff22725000 -     0x7fff2272efff  libsystem_darwin.dylib (1439.141.1) <29F82ABE-E1A0-3BC2-B91E-ADC010CF23FA> /usr/lib/system/libsystem_darwin.dylib
    0x7fff2272f000 -     0x7fff22a1afff  com.apple.CoreServices.CarbonCore (1307.3 - 1307.3) <8191DB78-205F-3709-8E42-E257F3AD4459> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff22a5a000 -     0x7fff22a94fff  com.apple.CSStore (1122.45 - 1122.45) <AF990E23-4698-33A2-B1E0-665D4619D6C4> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
    0x7fff22a95000 -     0x7fff22b43fff  com.apple.framework.IOKit (2.0.2 - 1845.120.6) <61CDC69E-EC9E-32B1-8A63-532619BA310F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff22b44000 -     0x7fff22b4ffff  libsystem_notify.dylib (279.40.4) <608B5A07-D31A-3BEC-86BF-C2E498C085AF> /usr/lib/system/libsystem_notify.dylib
    0x7fff22b50000 -     0x7fff22b9dfff  libsandbox.1.dylib (1441.141.4) <3848F6F5-6C83-37D2-A591-4EA4393F0372> /usr/lib/libsandbox.1.dylib
    0x7fff22b9e000 -     0x7fff238e9fff  com.apple.AppKit (6.9 - 2022.60.128) <39481583-0997-3314-B9C2-0854C9B56C0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff238ea000 -     0x7fff23b38fff  com.apple.UIFoundation (1.0 - 728.9) <A7628FB1-C04A-3F24-A14A-DDCD4CE67A00> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff23b39000 -     0x7fff23b4bfff  com.apple.UniformTypeIdentifiers (637 - 637) <5C5C0766-21EC-3C7C-9887-3DF23CBFCB84> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
    0x7fff23b4c000 -     0x7fff23cd6fff  com.apple.desktopservices (1.21 - 1346.6.1) <F2D70A76-BF47-31DC-8337-D4D929DA4A27> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff23cd7000 -     0x7fff23ce9fff  com.apple.metadata.SpotlightLinguistics (1.0 - 1) <21E29156-2D46-3743-8E89-518EE82E083F> /System/Library/PrivateFrameworks/SpotlightLinguistics.framework/Versions/A/SpotlightLinguistics
    0x7fff23cea000 -     0x7fff23ef8fff  com.apple.CoreDuet (1.0 - 1) <EA0886E1-AC18-3A4C-A9BB-0870D2DA3CF0> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
    0x7fff23fb6000 -     0x7fff2463cfff  libnetwork.dylib (2288.140.7) <6D702F3B-34C0-3809-8CEC-1D59D58CF8BB> /usr/lib/libnetwork.dylib
    0x7fff2463d000 -     0x7fff24adbfff  com.apple.CFNetwork (1240.0.4 - 1240.0.4) <5AC97239-B546-33F2-80B0-ACBFD66C0E58> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff24adc000 -     0x7fff24aeafff  libsystem_networkextension.dylib (1295.140.3) <022BE26C-C058-3CC7-8E0B-348B3D3B639C> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff24aeb000 -     0x7fff24aebfff  libenergytrace.dylib (22.100.1) <13CE770E-37DA-35D5-84A7-2F6C07F3B707> /usr/lib/libenergytrace.dylib
    0x7fff24aec000 -     0x7fff24b48fff  libMobileGestalt.dylib (978.140.1) <23C1C24D-9C1B-323A-9B84-42221F9257AC> /usr/lib/libMobileGestalt.dylib
    0x7fff24b49000 -     0x7fff24b5ffff  libsystem_asl.dylib (385) <47B99A49-749E-356F-9D81-6D3A0B1544AB> /usr/lib/system/libsystem_asl.dylib
    0x7fff24b60000 -     0x7fff24b78fff  com.apple.TCC (1.0 - 1) <0C03114C-CBE1-3E8F-945E-CC11F0845978> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff24b79000 -     0x7fff24edefff  com.apple.SkyLight (1.600.0 - 588.8) <338D12B6-9059-3AED-B409-61EA90715BDA> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff24edf000 -     0x7fff25591fff  com.apple.CoreGraphics (2.0 - 1463.18.4.1) <C6A2258D-84FF-3442-B1C3-4B78B0F71645> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff25592000 -     0x7fff25688fff  com.apple.ColorSync (4.13.0 - 3473.5.3) <475BCA90-8D51-3695-AD75-29F5024C4515> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff25689000 -     0x7fff256e4fff  com.apple.HIServices (1.22 - 716) <6118C8D4-70EA-3FD5-A375-0B500896506A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff256e5000 -     0x7fff25723fff  libAWDSupport.dylib (951) <DD7F429A-3750-31AF-A344-776C63EAB960> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
    0x7fff25724000 -     0x7fff25780fff  libprotobuf.dylib (4205) <7B397A12-BA3F-3B18-9669-79FFA52F48AF> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
    0x7fff25781000 -     0x7fff25792fff  libprotobuf-lite.dylib (4205) <659388D5-1B65-3DD9-9ECF-2DE5C4264D31> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
    0x7fff25793000 -     0x7fff257d7fff  com.apple.awd (1.0 - 951) <170D4BE0-FE3D-3EDC-AF7E-BAC00F506733> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
    0x7fff257d8000 -     0x7fff25998fff  com.apple.Montreal (1.0 - 142) <2BA11519-6F86-3EC3-98DB-248C9832B6CE> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
    0x7fff25999000 -     0x7fff25a8afff  com.apple.NLP (1.0 - 210.2) <F9671A0A-467B-385C-BC4A-451DE2309476> /System/Library/PrivateFrameworks/NLP.framework/Versions/A/NLP
    0x7fff25a8b000 -     0x7fff25ebbfff  com.apple.CoreData (120 - 1048) <66C2F919-F7E8-32BB-927B-7C2656D7BFF9> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff25ebc000 -     0x7fff25ed1fff  com.apple.ProtocolBuffer (1 - 285.24.10.20.1) <A2E727C2-659A-3791-8076-2DA387C440F9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff25ed2000 -     0x7fff26080fff  libsqlite3.dylib (321.3) <07A2B3EB-504A-316C-85B3-051F47DD2F73> /usr/lib/libsqlite3.dylib
    0x7fff26081000 -     0x7fff260fdfff  com.apple.Accounts (113 - 113) <A4533970-D42E-3A4E-8244-2ACC60504923> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff260fe000 -     0x7fff26115fff  com.apple.commonutilities (8.0 - 900) <56BAD997-43B7-3AF5-8E99-9F0810619899> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
    0x7fff26116000 -     0x7fff26195fff  com.apple.BaseBoard (526 - 526) <A59E4406-C169-3723-9CC5-396A3ED80F49> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
    0x7fff26196000 -     0x7fff261defff  com.apple.RunningBoardServices (1.0 - 505.100.9) <596F75F9-6D8E-3113-BE54-B4CA556D2770> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
    0x7fff261df000 -     0x7fff26253fff  com.apple.AE (918.6 - 918.6) <2AC07F95-A6EB-3D82-B8AC-D6516E42C60F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff26254000 -     0x7fff2625afff  libdns_services.dylib (1310.140.1) <9D69602C-7ADF-3701-8A4E-F7C7B0A1AC37> /usr/lib/libdns_services.dylib
    0x7fff2625b000 -     0x7fff26262fff  libsystem_symptoms.dylib (1431.140.1) <EA6435E7-8F85-315B-8AED-C20A07DE7F96> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff26263000 -     0x7fff263eefff  com.apple.Network (1.0 - 1) <95AC4C13-4BD4-36AB-B0CE-BFB9B0812930> /System/Library/Frameworks/Network.framework/Versions/A/Network
    0x7fff263ef000 -     0x7fff2641efff  com.apple.analyticsd (1.0 - 1) <13CBC16D-996E-3FCC-B5FA-787896CC6CED> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
    0x7fff2641f000 -     0x7fff26421fff  libDiagnosticMessagesClient.dylib (112) <2FCF6C74-5FAF-3968-AE36-294C9EF3AA75> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff26422000 -     0x7fff2646efff  com.apple.spotlight.metadata.utilities (1.0 - 2150.26) <2775C636-B8B5-3ED3-A8FC-7C2CB8C737A9> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
    0x7fff2646f000 -     0x7fff26509fff  com.apple.Metadata (10.7.0 - 2150.26) <A3A109B8-0C44-3377-A1BA-482D7AC72C0E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff2650a000 -     0x7fff26510fff  com.apple.DiskArbitration (2.7 - 2.7) <C121EA04-ABB5-34B6-80DD-360A75945764> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff26511000 -     0x7fff26e7cfff  com.apple.vImage (8.1 - 544.4) <B929FC15-2D42-3DB3-95E2-5A805B0D0110> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff26e7d000 -     0x7fff2715afff  com.apple.QuartzCore (1.11 - 927.24) <5330EF82-E120-34A4-B9DF-68F4C7C13DCF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff2715b000 -     0x7fff2719cfff  libFontRegistry.dylib (309) <ACF99477-688E-33DA-8100-3191721EB052> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff2719d000 -     0x7fff272ddfff  com.apple.coreui (2.1 - 692.1) <CC1F2421-0338-3912-86BE-A15BFDDF5C00> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff272de000 -     0x7fff273c9fff  com.apple.ViewBridge (553.1 - 553.1) <B5CC51A9-EA5C-3BE2-914C-5672C30A0311> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff273ca000 -     0x7fff273d5fff  com.apple.PerformanceAnalysis (1.278.3 - 278.3) <4460D0DF-74B4-3EDB-9391-733525F1D0C6> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff273d6000 -     0x7fff273e5fff  com.apple.OpenDirectory (11.6 - 230.40.1) <E204DA2B-17DA-3A4B-A03C-8F3B673D5CCD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff273e6000 -     0x7fff27405fff  com.apple.CFOpenDirectory (11.6 - 230.40.1) <9294B2FA-1269-3173-AB57-E80EBD2FE3E1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff27406000 -     0x7fff27412fff  com.apple.CoreServices.FSEvents (1290.120.5 - 1290.120.5) <87C05C54-DD61-3555-8246-F56E535072D2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff27413000 -     0x7fff27437fff  com.apple.coreservices.SharedFileList (144 - 144) <FC634ADE-7F29-3A8D-AEB4-2F5A34685C88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff27438000 -     0x7fff2743afff  libapp_launch_measurement.dylib (14.1) <34296F0E-D81B-383B-8B45-137CA086BC4D> /usr/lib/libapp_launch_measurement.dylib
    0x7fff2743b000 -     0x7fff27482fff  com.apple.CoreAutoLayout (1.0 - 21.10.1) <0AA28C77-F6DE-3B5B-BD3B-6BDCE805B634> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
    0x7fff27483000 -     0x7fff27565fff  libxml2.2.dylib (34.10) <6750E272-224C-3FDD-9A1C-87249E63DA07> /usr/lib/libxml2.2.dylib
    0x7fff27566000 -     0x7fff275b3fff  com.apple.CoreVideo (1.8 - 414.7) <7E4736C8-AB84-3A3A-BB7C-A6A9A36BCE79> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff275b4000 -     0x7fff275b6fff  com.apple.loginsupport (1.0 - 1) <F0181B5E-C653-3769-B7D2-8AEB1210898C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff275b7000 -     0x7fff275defff  com.apple.aps.framework (4.0 - 4.0) <26AA00EA-98DF-397D-A610-A64BB735EB76> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff275df000 -     0x7fff275fafff  com.apple.UserManagement (1.0 - 1) <844C9F98-08E1-36EB-978D-660B4F4FA17E> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
    0x7fff275fb000 -     0x7fff2778cfff  com.apple.cloudkit.CloudKit (990 - 990) <DB51AB84-4B93-383A-B485-FD897CDFC83E> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff2778d000 -     0x7fff2780efff  com.apple.CloudDocs (1.0 - 738.3) <17D4DA33-00D8-39AC-A6A8-E379D7DBB619> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff2780f000 -     0x7fff27b9efff  com.apple.CoreML (1.0 - 1) <60D26BDF-5B31-3780-9BB9-44202D6DB00F> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
    0x7fff27b9f000 -     0x7fff284f0fff  libwebrtc.dylib (7611.3.10.1.6) <47BE79FE-DB6C-36E1-BF7F-53EB467A4B34> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
    0x7fff284f1000 -     0x7fff2856dfff  com.apple.corelocation (2420.19.23 - 2420.19.23) <5CD8DDEE-0438-3A38-8877-10227C5A0A56> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff2856e000 -     0x7fff2857efff  libsystem_containermanager.dylib (318.100.4) <E0A89571-6D3E-3184-9F39-C6094C87B92B> /usr/lib/system/libsystem_containermanager.dylib
    0x7fff2857f000 -     0x7fff28590fff  com.apple.IOSurface (290.8.1 - 290.8.1) <9D6CA654-3E6F-3719-B9B9-65C4CDA41BC5> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff28591000 -     0x7fff2859afff  com.apple.IOAccelerator (442.9 - 442.9) <CF36BA06-85BA-3CCF-B59D-6A92EAB5EABB> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff2859b000 -     0x7fff286befff  com.apple.Metal (244.303 - 244.303) <1A5DBC62-5F40-3407-8BBA-FE2B56CFA993> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff286bf000 -     0x7fff286dbfff  com.apple.audio.caulk (1.0 - 70) <B2CA358A-CC85-3B89-810C-B0209F0EEAEA> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
    0x7fff286dc000 -     0x7fff287c6fff  com.apple.CoreMedia (1.0 - 2780.10.4.1) <FDE1187A-BDBD-3B4E-A200-A3E2E22694B5> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff287c7000 -     0x7fff28923fff  libFontParser.dylib (305.6.0.4) <7A6DF449-3B4B-34FC-9D5C-B00FE59E6031> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
    0x7fff28924000 -     0x7fff28c1ffff  com.apple.HIToolbox (2.1.1 - 1062) <028D8F63-A386-33B9-A797-FF5C82B44C2F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff28c20000 -     0x7fff28c33fff  com.apple.framework.DFRFoundation (1.0 - 267) <236EDA40-6A75-3BFE-9300-F9E4AAD36256> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff28c34000 -     0x7fff28c37fff  com.apple.dt.XCTTargetBootstrap (1.0 - 18119.1) <EAD6AFB0-E0FC-32FE-866B-8D017C12D868> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
    0x7fff28c38000 -     0x7fff28c61fff  com.apple.CoreSVG (1.0 - 149) <01655535-CA23-3F54-A8CE-92423D73CC99> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
    0x7fff28c62000 -     0x7fff28ea2fff  com.apple.ImageIO (3.3.0 - 2130.7.3) <85D4DBE0-4882-370C-966C-8DF37F986E37> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff28ea3000 -     0x7fff2921efff  com.apple.CoreImage (16.3.0 - 1140.2) <E05C48FC-81E3-3270-A37C-D206F364FF62> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff2921f000 -     0x7fff29285fff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <6AE9618A-B8C9-3D0F-A389-71382F438DF8> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff29286000 -     0x7fff29289fff  libsystem_configuration.dylib (1109.140.1) <89E70992-616F-3DD3-9430-67025F759A1B> /usr/lib/system/libsystem_configuration.dylib
    0x7fff2928a000 -     0x7fff2928efff  libsystem_sandbox.dylib (1441.141.4) <087B0ADD-EF39-3E80-800F-F111FD65ABBA> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff2928f000 -     0x7fff29290fff  com.apple.AggregateDictionary (1.0 - 1) <9FD9D68F-7B02-31A6-9583-EFF60B2A9F1C> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
    0x7fff29291000 -     0x7fff29294fff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <0B523600-B02C-359B-BDD7-6EADCE8B5AD8> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff29295000 -     0x7fff29296fff  liblangid.dylib (136) <5645ED02-635B-3BA0-ACEF-D6C8BC74FAF0> /usr/lib/liblangid.dylib
    0x7fff29297000 -     0x7fff2933bfff  com.apple.CoreNLP (1.0 - 245.2) <24291100-1C4C-361B-B53B-B99CB4B53906> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fff2933c000 -     0x7fff29342fff  com.apple.LinguisticData (1.0 - 399) <55FF3554-9E14-3351-8E3C-3280C9CB664B> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff29343000 -     0x7fff2993efff  libBNNS.dylib (288.100.5) <CF9C3646-9299-3DF7-A75B-9BD26A484201> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff2993f000 -     0x7fff29accfff  libvDSP.dylib (760.100.3) <7704318F-6565-3188-8C5D-31C290F68685> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff29acd000 -     0x7fff29adefff  com.apple.CoreEmoji (1.0 - 128.4) <37352743-CFF8-3196-8234-6AF30E531759> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff29adf000 -     0x7fff29ae9fff  com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <A6497A63-1658-3652-91ED-D3AF0EFAFABD> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
    0x7fff29aea000 -     0x7fff29bbcfff  com.apple.framework.CoreWLAN (16.0 - 1657) <5887F6C3-D272-3B6C-8CC8-262701FD9862> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff29bbd000 -     0x7fff29dbefff  com.apple.CoreUtils (6.6 - 660.37) <CC8A07A0-797C-3943-BEFF-A9E3466A0B7C> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff29dbf000 -     0x7fff29de1fff  com.apple.MobileKeyBag (2.0 - 1.0) <70A80CF0-3682-32A6-AB83-8647FD8B2E52> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff29de2000 -     0x7fff29df2fff  com.apple.AssertionServices (1.0 - 505.100.9) <968E021C-1BCD-3249-BBAD-FEE64370EB1F> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
    0x7fff29df3000 -     0x7fff29e7efff  com.apple.securityfoundation (6.0 - 55240.40.4) <DB010D41-F904-3592-9301-BB75A0FA2FD4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff29e7f000 -     0x7fff29e88fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <B222BEB6-CE24-3D70-903B-A9034D6FC6F6> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff29e89000 -     0x7fff29e8dfff  com.apple.xpc.ServiceManagement (1.0 - 1) <E1167FFF-E757-3C96-B26A-C0CE98EAA899> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff29e8e000 -     0x7fff29e90fff  libquarantine.dylib (119.40.2) <B1418CB0-CDC7-3EB2-ABC3-8609ADC92BC4> /usr/lib/system/libquarantine.dylib
    0x7fff29e91000 -     0x7fff29e9cfff  libCheckFix.dylib (31) <AA2CA9EF-88C2-3DB6-89E4-7E946131788D> /usr/lib/libCheckFix.dylib
    0x7fff29e9d000 -     0x7fff29eb4fff  libcoretls.dylib (169.100.1) <972397D6-A93B-302D-9CA3-C8B12C93899B> /usr/lib/libcoretls.dylib
    0x7fff29eb5000 -     0x7fff29ec5fff  libbsm.0.dylib (68.40.1) <FEA138A5-B03E-3AD5-9E21-3F35405D147F> /usr/lib/libbsm.0.dylib
    0x7fff29ec6000 -     0x7fff29f0ffff  libmecab.dylib (929.10) <E391699C-D139-338C-8919-1B2817BC1E25> /usr/lib/libmecab.dylib
    0x7fff29f10000 -     0x7fff29f15fff  libgermantok.dylib (24) <3DF990AD-8806-36B2-8168-4F18762C74A4> /usr/lib/libgermantok.dylib
    0x7fff29f16000 -     0x7fff29f2bfff  libLinearAlgebra.dylib (1336.140.1) <6CE0B7EF-EC7A-34A1-B590-A05851FE42D9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff29f2c000 -     0x7fff2a14afff  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <5B727E28-3ACF-3DBB-B787-B1633CFB2413> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff2a14b000 -     0x7fff2a19afff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <315027A8-ADFD-3DC7-9B2A-6F1457E4D32E> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
    0x7fff2a19b000 -     0x7fff2a2fcfff  com.apple.MLCompute (1.0 - 1) <E0A748E2-21DA-319C-8B28-80A853090B86> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
    0x7fff2a2fd000 -     0x7fff2a333fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <5D3C245B-BF53-31B0-B405-E4EB0FA608ED> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff2a334000 -     0x7fff2a38afff  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <C251786D-BC17-3C99-94E7-10EC828139D4> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
    0x7fff2a38b000 -     0x7fff2a41bfff  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <AAE88278-E296-3976-9FCC-345F71C8005D> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff2a41c000 -     0x7fff2a42bfff  com.apple.AppleFSCompression (125 - 1.0) <EAA1DBD4-02EE-3E39-A9F8-C40AA535C32A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff2a42c000 -     0x7fff2a438fff  libbz2.1.0.dylib (44) <90425CDA-B4E1-3004-800B-7E4A87DCBCD2> /usr/lib/libbz2.1.0.dylib
    0x7fff2a439000 -     0x7fff2a43dfff  libsystem_coreservices.dylib (127.1) <7AE405FC-6A44-34A0-86AD-6BD80B0050BB> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff2a43e000 -     0x7fff2a46bfff  com.apple.CoreServices.OSServices (1122.45 - 1122.45) <8D3DFB6A-1621-38D0-BA1C-A972C343D839> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff2a46c000 -     0x7fff2a59bfff  com.apple.AuthKit (1.0 - 1) <BE5EBFF1-F354-3F16-9B16-B30B6867ED3E> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
    0x7fff2a59c000 -     0x7fff2a5cafff  com.apple.UserNotifications (1.0 - 348.5) <F6D81ADE-EDF8-39FA-995A-4249DDC7E696> /System/Library/Frameworks/UserNotifications.framework/Versions/A/UserNotifications
    0x7fff2a5cb000 -     0x7fff2a639fff  com.apple.CoreSpotlight (1.0 - 2150.26) <A6A2E008-5AD4-3A09-AB41-98284756E61B> /System/Library/Frameworks/CoreSpotlight.framework/Versions/A/CoreSpotlight
    0x7fff2a63a000 -     0x7fff2a64cfff  libz.1.dylib (76) <73C471D3-07CE-307D-A531-92C5D0E4C0E9> /usr/lib/libz.1.dylib
    0x7fff2a64d000 -     0x7fff2a698fff  libsystem_m.dylib (3186.100.3) <10F86B94-7CEE-35AB-86DC-E91032378BC7> /usr/lib/system/libsystem_m.dylib
    0x7fff2a699000 -     0x7fff2a699fff  libcharset.1.dylib (59) <E389024B-7CAC-32A5-BF12-DF20C8A3B050> /usr/lib/libcharset.1.dylib
    0x7fff2a69a000 -     0x7fff2a69ffff  libmacho.dylib (980) <1FCE2BE3-4F6F-3EAA-9BC5-A9892A45CF0D> /usr/lib/system/libmacho.dylib
    0x7fff2a6a0000 -     0x7fff2a6bbfff  libkxld.dylib (7195.141.8) <A4FF718B-9B75-339A-BDDF-987C38610870> /usr/lib/system/libkxld.dylib
    0x7fff2a6bc000 -     0x7fff2a6c7fff  libcommonCrypto.dylib (60178.120.3) <7E242F29-1CB6-30EF-8C9A-C768A90FDBA0> /usr/lib/system/libcommonCrypto.dylib
    0x7fff2a6c8000 -     0x7fff2a6d2fff  libunwind.dylib (201) <A5B040A8-847F-36EE-B13D-5DD1F5CD5BED> /usr/lib/system/libunwind.dylib
    0x7fff2a6d3000 -     0x7fff2a6dafff  liboah.dylib (203.58) <26D08622-69F5-32DB-80D2-9B4651A9F0CC> /usr/lib/liboah.dylib
    0x7fff2a6db000 -     0x7fff2a6e5fff  libcopyfile.dylib (173.40.2) <8C783785-0F5F-3DC5-B815-B29CEBA75737> /usr/lib/system/libcopyfile.dylib
    0x7fff2a6e6000 -     0x7fff2a6edfff  libcompiler_rt.dylib (102.2) <1FDC92D1-8A17-30AF-8E72-4F0517AEA157> /usr/lib/system/libcompiler_rt.dylib
    0x7fff2a6ee000 -     0x7fff2a6f0fff  libsystem_collections.dylib (1439.141.1) <11D5775A-AD4C-35ED-BC05-616AB67ACBBE> /usr/lib/system/libsystem_collections.dylib
    0x7fff2a6f1000 -     0x7fff2a6f3fff  libsystem_secinit.dylib (87.60.1) <27982311-637E-3308-9F55-4871762736F4> /usr/lib/system/libsystem_secinit.dylib
    0x7fff2a6f4000 -     0x7fff2a6f6fff  libremovefile.dylib (49.120.1) <5973CED7-797B-3288-9589-C1856752F91A> /usr/lib/system/libremovefile.dylib
    0x7fff2a6f7000 -     0x7fff2a6f7fff  libkeymgr.dylib (31) <AAA929A0-45E5-3186-8ABD-37EB25B2C939> /usr/lib/system/libkeymgr.dylib
    0x7fff2a6f8000 -     0x7fff2a6fffff  libsystem_dnssd.dylib (1310.140.1) <4A85F13B-E3AD-3C44-B327-091F56D35CC1> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff2a700000 -     0x7fff2a705fff  libcache.dylib (83) <435668CB-666B-3379-AD65-F604A72099F4> /usr/lib/system/libcache.dylib
    0x7fff2a706000 -     0x7fff2a707fff  libSystem.B.dylib (1292.120.1) <2553EE0F-3C42-3ACE-9400-EF055BD5BE8E> /usr/lib/libSystem.B.dylib
    0x7fff2a708000 -     0x7fff2a70bfff  libfakelink.dylib (3) <C7E36B51-4FD6-3704-975E-AB9B46DF6D30> /usr/lib/libfakelink.dylib
    0x7fff2a70c000 -     0x7fff2a70cfff  com.apple.SoftLinking (1.0 - 1) <AF16BDE9-8995-39F5-A0ED-C65232A61095> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
    0x7fff2a70d000 -     0x7fff2a744fff  libpcap.A.dylib (98.100.3) <7EB940E4-BB5E-327D-B7F8-951F22F27D72> /usr/lib/libpcap.A.dylib
    0x7fff2a745000 -     0x7fff2a835fff  libiconv.2.dylib (59) <1F132286-CEA4-37A4-93F7-3C0A60C3645B> /usr/lib/libiconv.2.dylib
    0x7fff2a836000 -     0x7fff2a847fff  libcmph.dylib (8) <8A5DF97C-1CDA-36BC-86E8-EF8B7F314EDC> /usr/lib/libcmph.dylib
    0x7fff2a848000 -     0x7fff2a8b9fff  libarchive.2.dylib (83.100.2) <BAF76083-029C-3AC5-96E5-AE54786574A6> /usr/lib/libarchive.2.dylib
    0x7fff2a8ba000 -     0x7fff2a921fff  com.apple.SearchKit (1.4.1 - 1.4.1) <7B3B1E70-2C63-30E2-B5CF-6BC8EE7EA418> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff2a922000 -     0x7fff2a923fff  libThaiTokenizer.dylib (3) <84E7B443-74C5-386F-AEFF-FD48B94A04EB> /usr/lib/libThaiTokenizer.dylib
    0x7fff2a924000 -     0x7fff2a946fff  com.apple.applesauce (1.0 - 16.28) <0F9016E9-9DBB-3047-A1C3-A9FC85BAFE20> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff2a947000 -     0x7fff2a95efff  libapple_nghttp2.dylib (1.41) <B730D1A0-8F61-3497-B63A-5661EB887E73> /usr/lib/libapple_nghttp2.dylib
    0x7fff2a95f000 -     0x7fff2a971fff  libSparseBLAS.dylib (1336.140.1) <D18578FF-C9A9-38EF-86D9-18C0D4FFCE5E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff2a972000 -     0x7fff2a973fff  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <295CF572-CFF5-3C5D-8006-F63988CFB5B7> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff2a974000 -     0x7fff2a978fff  libpam.2.dylib (28.40.1) <B2457D3D-DADD-3157-8BFD-CF76F982FC13> /usr/lib/libpam.2.dylib
    0x7fff2a979000 -     0x7fff2a999fff  libcompression.dylib (96.120.1) <FAAB6617-1DDB-3B53-9290-8ACDEFF1510B> /usr/lib/libcompression.dylib
    0x7fff2a99a000 -     0x7fff2a99ffff  libQuadrature.dylib (7) <EA417A8F-8395-32AC-A67A-FA75DC2110CB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff2a9a0000 -     0x7fff2ad44fff  libLAPACK.dylib (1336.140.1) <EF9A0E29-BFF1-3A1A-A19E-4361F085EB13> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff2ad45000 -     0x7fff2ad94fff  com.apple.DictionaryServices (1.2 - 341) <960CC0D7-B2C6-3308-A120-C86F41A2301C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff2ad95000 -     0x7fff2adadfff  liblzma.5.dylib (16) <933D5DEC-E8E8-3946-A16E-1056F2075602> /usr/lib/liblzma.5.dylib
    0x7fff2adae000 -     0x7fff2adaffff  libcoretls_cfhelpers.dylib (169.100.1) <E2AC5901-93EC-3F67-A8B1-738E76B49804> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff2adb0000 -     0x7fff2aeabfff  com.apple.APFS (1677.141.2 - 1677.141.2) <C4CDA06B-22D5-35A4-BA73-856DC272FAB5> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff2aeac000 -     0x7fff2aeb9fff  libxar.1.dylib (452.0.4) <F45E7073-9E81-30DE-9DCB-FABA46E5DBBC> /usr/lib/libxar.1.dylib
    0x7fff2aeba000 -     0x7fff2aebdfff  libutil.dylib (58.40.2) <AE460378-5737-3BD8-90D9-E4E7603C4002> /usr/lib/libutil.dylib
    0x7fff2aebe000 -     0x7fff2aee6fff  libxslt.1.dylib (17.6) <BFB2EA40-332D-3DB4-AA3E-025966219E88> /usr/lib/libxslt.1.dylib
    0x7fff2aee7000 -     0x7fff2aef1fff  libChineseTokenizer.dylib (37.1) <344E5492-4BD5-354A-8274-047F8388A826> /usr/lib/libChineseTokenizer.dylib
    0x7fff2aef2000 -     0x7fff2b068fff  libvMisc.dylib (760.100.3) <135DB3B5-6CCC-3FD4-992B-98B2B766D151> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff2b069000 -     0x7fff2b19afff  libate.dylib (3.0.6) <AD713B5B-0048-3127-9D03-C6B6AA4337DF> /usr/lib/libate.dylib
    0x7fff2b19b000 -     0x7fff2b1a2fff  libIOReport.dylib (64.100.1) <4690B952-7BCF-31DB-A796-996D8094AB24> /usr/lib/libIOReport.dylib
    0x7fff2b1a3000 -     0x7fff2b1b6fff  com.apple.CrashReporterSupport (10.13 - 15053.1) <4DF43384-1E50-3AB8-9DA7-5C328381A847> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff2b1ce000 -     0x7fff2b24bfff  com.apple.CVNLP (1.0 - 119) <2800BA19-1061-3032-8C0D-0E8FC72274C5> /System/Library/PrivateFrameworks/CVNLP.framework/Versions/A/CVNLP
    0x7fff2b26d000 -     0x7fff2b2a3fff  com.apple.pluginkit.framework (1.0 - 1) <545963FE-A289-3F66-B6EA-9122340016DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
    0x7fff2b2a4000 -     0x7fff2b2abfff  libMatch.1.dylib (38) <E1296A96-E533-39A6-A519-05A0AE78181E> /usr/lib/libMatch.1.dylib
    0x7fff2b2ac000 -     0x7fff2b337fff  libCoreStorage.dylib (554.140.2) <AEE8AC91-7058-3275-90D4-B0217A41BED6> /usr/lib/libCoreStorage.dylib
    0x7fff2b338000 -     0x7fff2b38bfff  com.apple.AppleVAFramework (6.1.3 - 6.1.3) <DC3B87A5-AA7D-3534-BF4F-089E16226C0D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff2b38c000 -     0x7fff2b3a5fff  libexpat.1.dylib (26.141.1) <F579645F-A493-3F2D-A9DB-C77664A1BCA1> /usr/lib/libexpat.1.dylib
    0x7fff2b3a6000 -     0x7fff2b3affff  libheimdal-asn1.dylib (597.140.2) <D59F68F4-A2E2-3F98-8167-DD5DDDAB568B> /usr/lib/libheimdal-asn1.dylib
    0x7fff2b3b0000 -     0x7fff2b3c4fff  com.apple.IconFoundation (479.4 - 479.4) <6B77361F-69AF-393F-97B8-9BDED38304B0> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
    0x7fff2b3c5000 -     0x7fff2b431fff  com.apple.IconServices (479.4 - 479.4) <727B7BC3-AC02-31F7-9149-0014FDBCF17B> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff2b432000 -     0x7fff2b4d0fff  com.apple.MediaExperience (1.0 - 1) <B71F329D-70E3-34A8-A789-82D7ACA63C34> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
    0x7fff2b4d1000 -     0x7fff2b4f9fff  com.apple.persistentconnection (1.0 - 1.0) <E05B6AF9-376E-3E4D-B2F5-3A7A85D7CBB3> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
    0x7fff2b4fa000 -     0x7fff2b508fff  com.apple.GraphVisualizer (1.0 - 100.1) <09C716AC-B62A-3EF0-85A1-98A949EB88B3> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff2b509000 -     0x7fff2b924fff  com.apple.vision.FaceCore (4.3.2 - 4.3.2) <0E25BE9A-551C-3457-B7E8-7ED414223E3A> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff2b925000 -     0x7fff2b96cfff  com.apple.OTSVG (1.0 - 677.6.0.2) <53E2913D-E023-3685-9161-A14608F89DC1> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
    0x7fff2b96d000 -     0x7fff2b973fff  com.apple.xpc.AppServerSupport (1.0 - 2038.120.1) <523B9C03-A39E-3FF4-8216-34309C158113> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
    0x7fff2b974000 -     0x7fff2b986fff  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <53477D30-E8A6-3935-A3B1-7CBDE387210A> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
    0x7fff2b987000 -     0x7fff2b989fff  libspindump.dylib (295.2) <003C7E84-C242-311A-A2FA-4622B66E3F24> /usr/lib/libspindump.dylib
    0x7fff2b98a000 -     0x7fff2ba4afff  com.apple.Heimdal (4.0 - 2.0) <22D8BF25-5FD0-3EE3-A547-B3F55FC09330> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff2ba4b000 -     0x7fff2ba65fff  com.apple.login (3.0 - 3.0) <6A0F479C-875F-3280-A99F-4424C3ED9448> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
    0x7fff2ba66000 -     0x7fff2bb3dfff  com.apple.corebrightness (1.0 - 1) <D9088C56-2629-305D-B664-479950849BE1> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
    0x7fff2bbea000 -     0x7fff2bc26fff  com.apple.bom (14.0 - 235) <8C9005F1-FC51-3CF3-9CAC-264C1D8031F7> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff2bc27000 -     0x7fff2bc70fff  com.apple.AppleJPEG (1.0 - 1) <D751A39A-DC50-3E2E-9C2D-70284574EC84> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff2bc71000 -     0x7fff2bd4ffff  libJP2.dylib (2130.7.3) <8D977418-51A1-3935-80BB-3E9B70FA64DF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff2bd50000 -     0x7fff2bd53fff  com.apple.WatchdogClient.framework (1.0 - 98.120.2) <13BB2B82-DF17-33C3-A19B-432E03744896> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
    0x7fff2bd54000 -     0x7fff2bd8afff  com.apple.MultitouchSupport.framework (4440.3 - 4440.3) <8B7FB5F9-E38B-3193-98AC-51EF565F61CB> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff2bd8b000 -     0x7fff2bee9fff  com.apple.VideoToolbox (1.0 - 2780.10.4.1) <1134D8C6-EA97-32B4-BD4C-DD02901F4B0B> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff2beea000 -     0x7fff2bf1dfff  libAudioToolboxUtility.dylib (1181.72.1) <3043E7BD-6B6A-39EA-B482-4BDB39E1DF85> /usr/lib/libAudioToolboxUtility.dylib
    0x7fff2bf1e000 -     0x7fff2bf3efff  libPng.dylib (2130.7.3) <BB3D23A8-ABE2-3F19-B48E-C13E88F4D46B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff2bf3f000 -     0x7fff2bf9efff  libTIFF.dylib (2130.7.3) <224A082C-2A78-3E08-B433-79AEE6500E04> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff2bf9f000 -     0x7fff2bfbbfff  com.apple.IOPresentment (58 - 37) <990B304C-15B6-397D-8B7E-636DA14AE1D3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff2bfbc000 -     0x7fff2bfc3fff  com.apple.GPUWrangler (6.3.5 - 6.3.5) <E07D5D60-104E-3141-90CC-F81074D95E0D> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
    0x7fff2bfc4000 -     0x7fff2bfc6fff  libRadiance.dylib (2130.7.3) <311E41C5-E8AA-38DF-AAF7-706E5AEC1DC8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff2bfc7000 -     0x7fff2bfccfff  com.apple.DSExternalDisplay (3.1 - 380) <DCD6682A-9C61-3779-A81D-8E1FBED38C69> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff2bfcd000 -     0x7fff2bff1fff  libJPEG.dylib (2130.7.3) <D3C4DD82-71F8-3DAA-AABA-93D6F1FFF485> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff2bff2000 -     0x7fff2c021fff  com.apple.ATSUI (1.0 - 1) <92428504-C766-3ACE-BC36-89F1A5CAB61C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
    0x7fff2c022000 -     0x7fff2c026fff  libGIF.dylib (2130.7.3) <30DDD320-77E2-3A77-A741-A0545B34149B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff2c027000 -     0x7fff2c030fff  com.apple.CMCaptureCore (1.0 - 82.6) <C1960208-BCA3-3D47-9DBE-CF1A81C2053B> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
    0x7fff2c031000 -     0x7fff2c078fff  com.apple.print.framework.PrintCore (16.1 - 531.1) <8139D1A2-7037-3B4F-AB8F-2BF38D64D798> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff2c079000 -     0x7fff2c146fff  com.apple.TextureIO (3.10.9 - 3.10.9) <0E29AC8D-246E-3F7F-A8A0-10E09DD64603> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff2c147000 -     0x7fff2c14ffff  com.apple.InternationalSupport (1.0 - 61.1) <8E0C26AC-7462-34B5-B608-0DB611CCB687> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
    0x7fff2c150000 -     0x7fff2c1cafff  com.apple.datadetectorscore (8.0 - 674) <3E182298-355E-337F-A398-B266DEC5E6F3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff2c1cb000 -     0x7fff2c228fff  com.apple.UserActivity (439 - 439) <E011EB02-BB18-3154-8010-AD4C6D21792B> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
    0x7fff2c229000 -     0x7fff2c9c5fff  com.apple.MediaToolbox (1.0 - 2780.10.4.1) <A90F330D-ACB5-30FC-9F25-CA12F6D8DE3C> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff2ca2f000 -     0x7fff2ce05fff  libswiftCore.dylib (5.4 - 1205.0.24.15) <B074D36E-07D2-37D0-A8FC-E23C030B9D8E> /usr/lib/swift/libswiftCore.dylib
    0x7fff2ce06000 -     0x7fff2ce6cfff  com.apple.imfoundation (10.0 - 1000) <32F0B225-1249-3EAF-9F71-5D2D11F7778B> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
    0x7fff2ce6d000 -     0x7fff2ce95fff  com.apple.locationsupport (2420.19.23 - 2420.19.23) <0CED90D1-F2D8-34B3-8501-236B0EAA8C7F> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
    0x7fff2ce96000 -     0x7fff2cec7fff  libSessionUtility.dylib (76.69) <E6D8E0BB-3C76-343B-B8EA-03C411971A6C> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
    0x7fff2cec8000 -     0x7fff2cffcfff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <7C7D69A5-6686-3040-88F4-87B892B96C0D> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff2cffd000 -     0x7fff2d062fff  com.apple.audio.AudioSession (1.0 - 76.69) <3E7FD009-AC1B-398E-A5BE-D892725A73C7> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
    0x7fff2d063000 -     0x7fff2d075fff  libAudioStatistics.dylib (27.64) <2072394F-C2D4-3EBE-8259-CEBBC87DB2C7> /usr/lib/libAudioStatistics.dylib
    0x7fff2d076000 -     0x7fff2d085fff  com.apple.speech.synthesis.framework (9.0.66 - 9.0.66) <3FADC203-0E7D-3208-9BF7-CD8AE1B9D204> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff2d086000 -     0x7fff2d0f2fff  com.apple.ApplicationServices.ATS (377 - 516) <79E67A4C-DAED-3E60-AF13-23BF0C11A3CA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff2d0f3000 -     0x7fff2d10bfff  libresolv.9.dylib (68) <E2B9E465-C557-3CEA-85F9-4DAF5D550503> /usr/lib/libresolv.9.dylib
    0x7fff2d18c000 -     0x7fff2d1bffff  com.apple.securityinterface (10.0 - 55149.120.1) <F804A124-CA96-3542-9037-30B9F1ED462E> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fff2d1d9000 -     0x7fff2d23dfff  com.apple.CoreMediaIO (1000.0 - 5325) <4139F0CF-51D7-3742-80CB-ED04E249D254> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fff2d23e000 -     0x7fff2d31dfff  libSMC.dylib (20) <B45BD314-B645-3948-B1C2-1FDA40453078> /usr/lib/libSMC.dylib
    0x7fff2d31e000 -     0x7fff2d37dfff  libcups.2.dylib (494.3) <353033B4-E6E6-375A-8BC7-0EE2F67FC8C3> /usr/lib/libcups.2.dylib
    0x7fff2d37e000 -     0x7fff2d38dfff  com.apple.LangAnalysis (1.7.0 - 254) <EE21E044-0B25-3D3E-A892-A276452D8EC8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff2d38e000 -     0x7fff2d398fff  com.apple.NetAuth (6.2 - 6.2) <08F7BAF1-D834-3FAF-9FCC-7FBC32BAF037> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff2d399000 -     0x7fff2d3a0fff  com.apple.ColorSyncLegacy (4.13.0 - 1) <67ED2EE7-B12F-301E-B164-059F452084DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff2d3a1000 -     0x7fff2d3acfff  com.apple.QD (4.0 - 416) <41CBD1BE-1975-3983-B4E0-32E511997BB5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff2d3ad000 -     0x7fff2da01fff  com.apple.audio.AudioResourceArbitration (1.0 - 1) <882F280D-B129-3299-B098-D1E59B78841A> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
    0x7fff2da02000 -     0x7fff2da0dfff  com.apple.perfdata (1.0 - 67.40.1) <B80E66C3-5A5F-391A-9475-15DB16BA72E8> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
    0x7fff2da0e000 -     0x7fff2da1cfff  libperfcheck.dylib (41) <A9A6BE18-57EA-35F6-96BC-D71C49013A09> /usr/lib/libperfcheck.dylib
    0x7fff2da1d000 -     0x7fff2da2cfff  com.apple.Kerberos (3.0 - 1) <06AAAB8C-AA8B-344E-A3F3-4CEDF0AF8C78> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff2da2d000 -     0x7fff2da7dfff  com.apple.GSS (4.0 - 2.0) <604B241D-5B83-3F6C-85D3-F3AB29C950D8> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff2da7e000 -     0x7fff2da8efff  com.apple.CommonAuth (4.0 - 2.0) <90C46CDE-4DD0-338C-9609-68F4BCDD3F03> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff2da8f000 -     0x7fff2dab6fff  com.apple.MobileAssets (1.0 - 659.100.21) <5516BEA4-1FAC-353E-8195-23EEFFA08AB7> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
    0x7fff2dab7000 -     0x7fff2dae3fff  com.apple.CacheDelete (1.0 - 1) <DB62C46F-B802-3F37-9B1D-94D5631A8080> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
    0x7fff2dae4000 -     0x7fff2db03fff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <92FFAD21-9FA8-3194-8764-946F3D8F429E> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
    0x7fff2db04000 -     0x7fff2db0cfff  com.apple.CorePhoneNumbers (1.0 - 1) <A667EA02-1F06-36D7-8290-0B6CD36F89BC> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff2db0d000 -     0x7fff2db96fff  libTelephonyUtilDynamic.dylib (5359.1) <77A0F846-3480-31C8-9373-80A8D0056B54> /usr/lib/libTelephonyUtilDynamic.dylib
    0x7fff2dc5f000 -     0x7fff2dc5ffff  liblaunch.dylib (2038.120.1) <A3F46CC6-BD89-39DB-8732-C885B881A635> /usr/lib/system/liblaunch.dylib
    0x7fff2df58000 -     0x7fff2e1e3fff  com.apple.NetworkExtension (1.0 - 1) <D5C908CF-8818-37F7-970E-B507A3466C47> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
    0x7fff2e1e4000 -     0x7fff2e2e5fff  com.apple.ids (10.0 - 1000) <24E1ADD5-184F-352E-8C97-D9B62974F29E> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
    0x7fff2e2e6000 -     0x7fff2e440fff  com.apple.idsfoundation (10.0 - 1000) <80BAA3A4-590A-335C-81C3-13BE067F9E62> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
    0x7fff2e441000 -     0x7fff2e58cfff  com.apple.Sharing (1630 - 1630) <76D1A200-27A3-3B3E-8B30-4026ABD24217> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff2e58d000 -     0x7fff2e6aefff  com.apple.Bluetooth (8.0.5 - 8.0.5d7) <2197F126-63A6-39DE-B3AB-6DD8B1F79398> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff2e6af000 -     0x7fff2e6c3fff  com.apple.AppContainer (4.0 - 509.140.3) <74319AC9-E412-3C61-8C9E-458E433542FD> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff2e6c4000 -     0x7fff2e6c7fff  com.apple.SecCodeWrapper (4.0 - 509.140.3) <FB661B58-5C98-37A2-937D-6CF8F4B34F65> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff2e6c8000 -     0x7fff2e721fff  com.apple.ProtectedCloudStorage (1.0 - 1) <4BCCB350-CAA2-3217-8AE6-6A6B25755D9F> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff2e722000 -     0x7fff2e781fff  com.apple.QuickLookFramework (5.0 - 928.5) <F2695014-0FAE-389B-8099-5933BC9CF6B6> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff2e782000 -     0x7fff2e79dfff  com.apple.MetalKit (147.1 - 147.1) <53DEED6A-862C-3ADA-8146-071DDD34DBFD> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
    0x7fff2e886000 -     0x7fff2e980fff  com.apple.combine (1.0 - 252.158) <9EE8B2DA-E5DC-3E18-8B2A-D87BAB666328> /System/Library/Frameworks/Combine.framework/Versions/A/Combine
    0x7fff2e981000 -     0x7fff2fe7cfff  com.apple.GeoServices (1.0 - 1757.26.6.2.2) <6DA1AB95-612F-3B54-B5FC-C817C9FF609F> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff2fe89000 -     0x7fff2feb0fff  com.apple.RemoteViewServices (2.0 - 163) <5A16528F-4822-3B0C-BB89-A79459F3AF87> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff2feb1000 -     0x7fff2fec0fff  com.apple.SpeechRecognitionCore (6.1.25 - 6.1.25) <80F52037-912C-335F-B1DA-22AFD73DBDA2> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff2fec1000 -     0x7fff2fec8fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <00007833-3C2A-3F10-97ED-838FB606B5FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff2fec9000 -     0x7fff2fed9fff  com.apple.AppleLDAP (11.6 - 54) <2D4D19D0-2849-3BFB-9152-A47776F46D0B> /System/Library/PrivateFrameworks/AppleLDAP.framework/Versions/A/AppleLDAP
    0x7fff300f6000 -     0x7fff300f6fff  libsystem_product_info_filter.dylib (8.40.1) <6CA8DEA4-5BD4-375F-9AA7-3338135306C5> /usr/lib/system/libsystem_product_info_filter.dylib
    0x7fff3016e000 -     0x7fff30185fff  libnetworkextension.dylib (1295.140.3) <8B28ADBC-CF77-3F16-911D-8F5A2391BA3F> /usr/lib/libnetworkextension.dylib
    0x7fff301ce000 -     0x7fff301cefff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <AB0631EC-4898-3FA1-8A55-769D815EC2E2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff301f4000 -     0x7fff301f4fff  com.apple.CoreServices (1122.45 - 1122.45) <0B568FBF-B224-3C1C-8602-8124A23112CB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff303b0000 -     0x7fff303b0fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <1C9D7B74-C680-3548-B16F-2841666146FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff303d1000 -     0x7fff303f0fff  com.apple.AssetCacheServices (118 - 118) <D084499C-BD9C-3394-AC1D-FF727CDEF4EC> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fff303f1000 -     0x7fff303fcfff  com.apple.MediaAccessibility (1.0 - 130) <9F936D44-8663-3C49-9B14-3D906CEC361C> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff303fd000 -     0x7fff3041cfff  com.apple.networking.AlgosScoreFramework (1.0 - 1) <D0286FFC-1658-30C0-A2C6-FBE9C94331EB> /System/Library/PrivateFrameworks/AlgosScoreFramework.framework/Versions/A/AlgosScoreFramework
    0x7fff3041d000 -     0x7fff30421fff  com.apple.AppleSRP (5.0 - 1) <DA2F374E-D025-3E62-B688-8D2772B23FC0> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff30422000 -     0x7fff3042dfff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <657A98E1-0365-3F99-9B79-8091C19A4BAD> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff30466000 -     0x7fff3073efff  com.apple.VN (4.3.1 - 4.3.1) <2AE1121C-E1C4-3C62-A3E1-DE8238C6B8DD> /System/Library/Frameworks/Vision.framework/Versions/A/Vision
    0x7fff3073f000 -     0x7fff30897fff  libswiftFoundation.dylib (25.103) <7F1F4968-2556-35BC-8D73-77EAED71F95A> /usr/lib/swift/libswiftFoundation.dylib
    0x7fff30898000 -     0x7fff3091bfff  com.apple.AddressBook.ContactsFoundation (8.0 - 1151.2) <E42749F4-6E8E-3A97-9280-3D5B1958E7F0> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
    0x7fff3091c000 -     0x7fff3095efff  com.apple.contacts.ContactsPersistence (1.0 - 3497.5) <EAFD2B43-01FD-3710-A889-2AC289363549> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
    0x7fff3095f000 -     0x7fff30a95fff  com.apple.AddressBook.core (1.0 - 2452.7) <E521C2AB-2931-31ED-ACF4-C2D79A47BB4D> /System/Library/PrivateFrameworks/AddressBookCore.framework/Versions/A/AddressBookCore
    0x7fff30a96000 -     0x7fff30bcafff  com.apple.contacts (1.0 - 3497.5) <5750DD98-BDB6-3244-909B-C7EE313F547C> /System/Library/Frameworks/Contacts.framework/Versions/A/Contacts
    0x7fff30bcb000 -     0x7fff30bd8fff  com.apple.PersonaKit (1.0 - 1) <1E50BB74-27F9-377B-AE20-5EE3976A4A44> /System/Library/PrivateFrameworks/PersonaKit.framework/Versions/A/PersonaKit
    0x7fff30bf2000 -     0x7fff30c57fff  com.apple.CoreBluetooth (1.0 - 1) <3045519A-D711-3CD1-9E87-D7581A430423> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff30c58000 -     0x7fff30c61fff  com.apple.SymptomDiagnosticReporter (1.0 - 79.120.1) <22A34196-22AD-3021-88CD-CC9A7C0AF006> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
    0x7fff30c62000 -     0x7fff30c74fff  com.apple.PowerLog (1.0 - 1) <134B88CE-59B5-3B92-91E0-A3079C8B3952> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
    0x7fff30c75000 -     0x7fff30c81fff  com.apple.AppleIDAuthSupport (1.0 - 1) <B80B4F16-3756-303D-A349-3486A08B2216> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
    0x7fff30c82000 -     0x7fff30d2afff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <647A8433-AFF3-3F20-A07E-3471F427DA80> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff30d2b000 -     0x7fff30d5efff  com.apple.MediaKit (16 - 927.40.2) <88268EAB-5430-3BCB-9263-E3B4BCC34609> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff30d5f000 -     0x7fff30e4afff  com.apple.DiskManagement (14.0 - 1733.140.2) <4BF7BFA4-4950-3582-B43B-25A4B6A3E7B7> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
    0x7fff30e4b000 -     0x7fff31205fff  com.apple.CoreAUC (326.2.0 - 326.2.0) <2CA2A80E-FEA5-3631-AD13-A8CC304C7FF7> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff31206000 -     0x7fff31209fff  com.apple.Mangrove (1.0 - 25) <00241832-3B38-3D76-88DA-0F0ADEEBFAAC> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fff3120a000 -     0x7fff31237fff  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <D4FFFBBA-0AD9-31D0-99A1-7FC249867A20> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff31238000 -     0x7fff31387fff  com.apple.FileProvider (349.141.1 - 349.141.1) <B17CE44C-07C0-3C92-BA3B-40CF881F4C78> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
    0x7fff31388000 -     0x7fff313aafff  com.apple.GenerationalStorage (2.0 - 323) <9419BDA9-3F2D-32A8-8ABD-5CAF5B6DB77F> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff313c7000 -     0x7fff313ddfff  com.apple.CPAnalytics (1.0 - 361.0.100) <50BB2901-28E8-3CDD-9BAB-E726C3FF3C1B> /System/Library/PrivateFrameworks/CPAnalytics.framework/Versions/A/CPAnalytics
    0x7fff31720000 -     0x7fff317eefff  com.apple.CoreTelephony (113 - 8260.1) <3D3D1409-4F24-3964-97E6-7A8C3B6B69C0> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
    0x7fff317ef000 -     0x7fff317fcfff  com.apple.AppSandbox (4.0 - 509.140.3) <B8CA84EA-D8AB-3CA5-B0DC-41C0D3480FDE> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fff317fd000 -     0x7fff31812fff  libswiftDispatch.dylib (4.100.1) <6CB6A353-7D77-3B38-9DEB-2875BDC809F2> /usr/lib/swift/libswiftDispatch.dylib
    0x7fff31813000 -     0x7fff319a7fff  com.apple.AVFCore (1.0 - 2020.10) <70A422C7-FCC6-3C1F-A78E-686B861847F4> /System/Library/PrivateFrameworks/AVFCore.framework/Versions/A/AVFCore
    0x7fff319a8000 -     0x7fff31a17fff  com.apple.FrontBoardServices (703.16 - 703.16) <1B6F7F55-D9F7-342F-8361-E66465F2A617> /System/Library/PrivateFrameworks/FrontBoardServices.framework/Versions/A/FrontBoardServices
    0x7fff31a18000 -     0x7fff31a41fff  com.apple.BoardServices (1.0 - 526) <12D89B26-4E91-34A2-83D9-3023D199255C> /System/Library/PrivateFrameworks/BoardServices.framework/Versions/A/BoardServices
    0x7fff31a42000 -     0x7fff31a6dfff  com.apple.contacts.vCard (1.0 - 3497.5) <2FBB0F61-22C1-3E10-9843-EDACBC152E15> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
    0x7fff31a83000 -     0x7fff31a9efff  com.apple.ExtensionKit (19.4 - 19.4) <A9753B92-EFA2-32EF-AF39-58E5605FBB61> /System/Library/PrivateFrameworks/ExtensionKit.framework/Versions/A/ExtensionKit
    0x7fff31a9f000 -     0x7fff31aa5fff  com.apple.ExtensionFoundation (19.4 - 19.4) <2D46CB26-6391-398E-A8DA-F2D370D0A0CE> /System/Library/PrivateFrameworks/ExtensionFoundation.framework/Versions/A/ExtensionFoundation
    0x7fff31b31000 -     0x7fff31ba4fff  com.apple.avfoundationcf (2.0 - 430.4.1) <BE6892F7-91CB-3C90-89F2-8756DB3C1515> /System/Library/PrivateFrameworks/AVFoundationCF.framework/Versions/A/AVFoundationCF
    0x7fff31bf4000 -     0x7fff31c33fff  com.apple.AppleVPAFramework (3.26.1 - 3.26.1) <07AE0E16-85CC-30F2-A575-A51458366DD9> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
    0x7fff31ce6000 -     0x7fff31d21fff  com.apple.DebugSymbols (195.1 - 195.1) <C94557E3-11DD-3007-B001-DC2509CFE14D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff31d22000 -     0x7fff31dd7fff  com.apple.CoreSymbolication (12.5 - 64544.81.1) <1D4A9F11-AB1C-3F5F-90A1-38C3EAA7BE1F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff31dd8000 -     0x7fff31de1fff  com.apple.CoreTime (284.0.4) <FC81E173-26AA-349F-BF34-21EEF521B84F> /System/Library/PrivateFrameworks/CoreTime.framework/Versions/A/CoreTime
    0x7fff31de2000 -     0x7fff31e57fff  com.apple.Rapport (2.6.0 - 260.3) <F0117B24-BE94-300E-936F-19019FE81850> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
    0x7fff3272c000 -     0x7fff32778fff  com.apple.coreduetcontext (1.0 - 1) <9DB089D7-90D0-3073-BFAE-3DB94AB3A876> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
    0x7fff32779000 -     0x7fff32ce5fff  com.apple.Intents (1.0 - 1) <EBAA7FE2-516C-3C64-9569-280DE870B0B4> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
    0x7fff32ce6000 -     0x7fff32d49fff  com.apple.framework.Apple80211 (17.0 - 1728) <533F7734-3B2E-3F8C-AAF6-971011659A95> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff32d4a000 -     0x7fff32e9bfff  com.apple.CoreWiFi (3.0 - 341) <B6423C61-FA72-35FD-9D43-4F6CC39F23CB> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff32e9c000 -     0x7fff32eb6fff  com.apple.BackBoardServices (1.0 - 1.0) <A7D65AAF-EFEF-3BC9-BF87-973374EBA5D7> /System/Library/PrivateFrameworks/BackBoardServices.framework/Versions/A/BackBoardServices
    0x7fff32eef000 -     0x7fff32ef0fff  com.apple.TrustEvaluationAgent (2.0 - 35) <2F6327D6-E9A1-3CC5-93C8-CA189B5C2D22> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff330d5000 -     0x7fff3310bfff  com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <72DFE637-46E4-3CF1-8233-6B88CDB4855B> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
    0x7fff3310c000 -     0x7fff3311bfff  com.apple.RemoteServiceDiscovery (1.0 - 1.120.1) <4D674B64-AC7B-3654-8A51-E256FCD9D524> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
    0x7fff33134000 -     0x7fff33178fff  com.apple.DataDetectorsNaturalLanguage (1.0 - 159.1) <1585D871-706E-33FF-919D-EE45FD698C2A> /System/Library/PrivateFrameworks/DataDetectorsNaturalLanguage.framework/Versions/A/DataDetectorsNaturalLanguage
    0x7fff33179000 -     0x7fff3317cfff  com.apple.help (1.3.8 - 71) <F94CF2A6-2886-3552-A1E5-8D83452AE773> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff3317d000 -     0x7fff33184fff  com.apple.EFILogin (2.0 - 2) <A86695A6-1567-330B-870D-805FDB9EE437> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff33185000 -     0x7fff33190fff  libcsfde.dylib (554.140.2) <678CA1E1-733D-3709-A327-2208B49C6C1A> /usr/lib/libcsfde.dylib
    0x7fff33200000 -     0x7fff33262fff  com.apple.AppSupport (1.0.0 - 29) <9DF0F117-4F1B-3E0B-A4E3-BDCAB2EB1740> /System/Library/PrivateFrameworks/AppSupport.framework/Versions/A/AppSupport
    0x7fff333cf000 -     0x7fff333cffff  com.apple.ApplicationServices (48 - 50) <4F5BA3E6-0A85-3250-AEA7-B7F3897B2113> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff333d0000 -     0x7fff333d2fff  com.apple.InternationalTextSearch (1.0 - 1) <D2F8FE9C-8B84-390F-8578-7B3CCABB996A> /System/Library/PrivateFrameworks/InternationalTextSearch.framework/Versions/A/InternationalTextSearch
    0x7fff333d3000 -     0x7fff3344bfff  com.apple.ClassKit (1.2 - 146.6) <EC19C4F1-D161-30BD-8CAA-0248F3F4D60C> /System/Library/Frameworks/ClassKit.framework/Versions/A/ClassKit
    0x7fff3344c000 -     0x7fff33590fff  com.apple.AppleAccount (1.0 - 1.0) <86661655-1BD4-32D0-96DB-5011830EE6CB> /System/Library/PrivateFrameworks/AppleAccount.framework/Versions/A/AppleAccount
    0x7fff33591000 -     0x7fff335d0fff  com.apple.AppleIDSSOAuthentication (1.0 - 1) <836444C4-6FDD-3659-81EB-1F366C9F1C71> /System/Library/PrivateFrameworks/AppleIDSSOAuthentication.framework/Versions/A/AppleIDSSOAuthentication
    0x7fff335d1000 -     0x7fff33628fff  com.apple.CorePrediction (1.0 - 1) <EAA60434-D01F-3117-9596-C544DC0EB782> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
    0x7fff336e4000 -     0x7fff336e4fff  libHeimdalProxy.dylib (79) <2572CF4E-C22E-346A-A72F-9BD07BA56057> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
    0x7fff33797000 -     0x7fff33797fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <92D76741-76FC-3010-A9C1-8885E9D5DE18> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff337bb000 -     0x7fff337fefff  com.apple.StreamingZip (1.0 - 1) <7F9BB412-0B57-3261-BAC1-8FAA2704710E> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
    0x7fff337ff000 -     0x7fff3381dfff  com.apple.DuetActivityScheduler (1.0 - 1) <7B51AE4F-579A-318D-93B6-FB58DE7402C3> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
    0x7fff3381e000 -     0x7fff3381ffff  libswiftObjectiveC.dylib (3) <6B9E4AF2-89A1-3607-868F-CDEAB81AA32A> /usr/lib/swift/libswiftObjectiveC.dylib
    0x7fff33820000 -     0x7fff33831fff  libswiftos.dylib (1000.120.2) <7225483D-DE38-3D00-87F8-583066CFC5B1> /usr/lib/swift/libswiftos.dylib
    0x7fff33832000 -     0x7fff3383efff  com.apple.IntentsFoundation (1.0 - 1) <AAEE66E2-F3D5-3689-B09B-6E1768FABC53> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
    0x7fff3383f000 -     0x7fff33844fff  com.apple.PushKit (1.0 - 1) <31E9D56F-55EF-3840-905E-BD487ABB1747> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
    0x7fff33845000 -     0x7fff33878fff  com.apple.C2 (1.3 - 573) <CFEF2E5F-94C4-3DEA-8F06-F68ED73E13EF> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
    0x7fff33879000 -     0x7fff338a9fff  com.apple.QuickLookThumbnailing (1.0 - 135.5) <5681E46A-FF2A-3D9C-BC39-C20EA57D0D6A> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
    0x7fff338aa000 -     0x7fff340abfff  com.apple.vision.EspressoFramework (1.0 - 256.4.4) <A207A19F-47D1-38C7-A792-9E0CCC778EF3> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
    0x7fff340ac000 -     0x7fff340c3fff  com.apple.ANEServices (4.76 - 4.76) <3C70C879-5C89-3890-AEE6-A72BA53ACCFC> /System/Library/PrivateFrameworks/ANEServices.framework/Versions/A/ANEServices
    0x7fff340c4000 -     0x7fff34129fff  com.apple.proactive.support.ProactiveSupport (1.0 - 294.7) <88ABAF1D-B37F-38C1-AD2B-6C12A0F989D6> /System/Library/PrivateFrameworks/ProactiveSupport.framework/Versions/A/ProactiveSupport
    0x7fff3412a000 -     0x7fff34134fff  com.apple.corerecents (1.0 - 1) <EF6A10A4-9E1E-32B5-BF92-9A31500F12E2> /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/CoreRecents
    0x7fff34135000 -     0x7fff34166fff  com.apple.iCalendar (7.0 - 833) <C1A36E58-BF77-3F34-89A7-BE12400E0972> /System/Library/PrivateFrameworks/iCalendar.framework/Versions/A/iCalendar
    0x7fff34167000 -     0x7fff341d7fff  com.apple.CalendarFoundation (8.0 - 1178.5.2) <6AC24A3A-8A95-3FA3-A42A-D7DBB3961EA2> /System/Library/PrivateFrameworks/CalendarFoundation.framework/Versions/A/CalendarFoundation
    0x7fff341d8000 -     0x7fff341dafff  com.apple.CoreDuetDebugLogging (1.0 - 1) <C2B49AAE-5792-397F-AB3A-5F59B36A7733> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
    0x7fff341db000 -     0x7fff341e7fff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <D4989410-F136-3A95-8F83-9672F4869DD1> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
    0x7fff3447b000 -     0x7fff3474efff  com.apple.spotlight.index (10.7.0 - 2150.26) <40FF1E73-F746-32C4-AC00-4BE570B6C178> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
    0x7fff34767000 -     0x7fff347b7fff  com.apple.ChunkingLibrary (334.1 - 334.1) <1F0C24A0-F8F0-3773-91FF-39956CF3A1F8> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff348ee000 -     0x7fff3493dfff  com.apple.CalDAV (8.0 - 795) <780700B4-7D80-3602-9167-959782C3477A> /System/Library/PrivateFrameworks/CalDAV.framework/Versions/A/CalDAV
    0x7fff3493e000 -     0x7fff349dbfff  com.apple.CoreSuggestions (1.0 - 1115.519) <FC2400C4-2100-373E-B788-49D22640439B> /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/CoreSuggestions
    0x7fff349dc000 -     0x7fff34b66fff  com.apple.ical.EventKit (3.0 - 1414.5.1) <0720E6DA-613F-377E-B802-F4EE2FCAA3C5> /System/Library/Frameworks/EventKit.framework/Versions/A/EventKit
    0x7fff34b67000 -     0x7fff34e38fff  com.apple.CalendarPersistence (8.0 - 1071.4.4) <0A2092B0-DEAB-3293-9A8A-DCE2ED2026E0> /System/Library/PrivateFrameworks/CalendarPersistence.framework/Versions/A/CalendarPersistence
    0x7fff34e39000 -     0x7fff34e5efff  com.apple.CalendarAgentLink (8.0 - 250) <CBB68C55-9675-3AF3-8448-F8A510973BCF> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
    0x7fff34e5f000 -     0x7fff34e69fff  com.apple.RTCReporting (11.85.2 - 11.85.2) <C94EB3D2-585A-3BEE-ADF4-77696968FA2A> /System/Library/PrivateFrameworks/RTCReporting.framework/Versions/A/RTCReporting
    0x7fff34e6a000 -     0x7fff35010fff  com.apple.WebKitLegacy (16611 - 16611.3.10.1.6) <E61927E1-3589-37AE-B8F3-5124FDA7128D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
    0x7fff3502b000 -     0x7fff35040fff  com.apple.CoreML.AppleNeuralEngine (1.0 - 1) <14E9F653-6DB2-3E6B-805F-C3FA91EAF4FC> /System/Library/PrivateFrameworks/AppleNeuralEngine.framework/Versions/A/AppleNeuralEngine
    0x7fff35096000 -     0x7fff35101fff  com.apple.audio.midi.CoreMIDI (2.0 - 88) <074EA20A-790C-31D1-B240-05F8C937EB04> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x7fff351c7000 -     0x7fff351cafff  com.apple.Cocoa (6.11 - 23) <E8E14342-DDF9-3351-B93D-8DEDBA5CAABA> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff35c6f000 -     0x7fff35cf1fff  com.apple.PhotoFoundation (6.0 - 361.0.100) <3567A3B0-243D-3688-A012-FB71BEEF11C4> /System/Library/PrivateFrameworks/PhotoFoundation.framework/Versions/A/PhotoFoundation
    0x7fff35db4000 -     0x7fff35dbbfff  com.apple.DisplayServicesFW (3.1 - 380) <8054192B-AB2B-36CB-99F3-30EBC04E451F> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fff362f5000 -     0x7fff36589fff  libAWDSupportFramework.dylib (4205) <0EA22A3B-3DA1-3E4B-95C1-5457C3828A15> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
    0x7fff365fd000 -     0x7fff3662dfff  libtidy.A.dylib (18.2) <44E1E390-C730-33FE-A15E-4AB62ED52FBA> /usr/lib/libtidy.A.dylib
    0x7fff3662e000 -     0x7fff3664efff  com.apple.MarkupUI (1.0 - 383.6) <16B68DE7-3443-31D9-AB85-6A2988EF8F1C> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
    0x7fff3664f000 -     0x7fff36662fff  com.apple.Engram (1.0 - 1) <3CAB051B-160A-3137-AE2C-DB078C0FF830> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
    0x7fff36663000 -     0x7fff36686fff  com.apple.openscripting (1.7 - 190) <96A579D8-4148-31DD-9752-D41F9E121051> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff36687000 -     0x7fff3668afff  com.apple.securityhi (9.0 - 55008) <4933616C-D994-3E1E-AFEA-E1E460A1A39E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff3668b000 -     0x7fff3668efff  com.apple.ink.framework (10.15 - 227) <FDE6A6E5-DDD2-31DE-9695-6148EE88005B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff3668f000 -     0x7fff36692fff  com.apple.CommonPanels (1.2.6 - 101) <623B24C3-6256-388A-949B-C7A37AD72690> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff36693000 -     0x7fff3669afff  com.apple.ImageCapture (1711.5.2.1 - 1711.5.2.1) <DF34BF94-579A-3CD7-8785-F49C06525E50> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff3669b000 -     0x7fff3788bfff  com.apple.JavaScriptCore (16611 - 16611.3.10.1.6) <C81585E1-7118-3D00-849C-16485B8668C7> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff378f7000 -     0x7fff37a09fff  com.apple.AVFCapture (1.0 - 82.6) <119E6F65-DB53-38B4-B4FA-7AFB5645476D> /System/Library/PrivateFrameworks/AVFCapture.framework/Versions/A/AVFCapture
    0x7fff37a0a000 -     0x7fff37a9dfff  com.apple.Quagga (47 - 47) <7DABFA1D-0B1C-3F38-8B71-FDA918DF066E> /System/Library/PrivateFrameworks/Quagga.framework/Versions/A/Quagga
    0x7fff37a9e000 -     0x7fff37ce8fff  com.apple.CMCapture (1.0 - 82.6) <FBCE95F0-81D5-38F1-8B39-88F51E3EC323> /System/Library/PrivateFrameworks/CMCapture.framework/Versions/A/CMCapture
    0x7fff38084000 -     0x7fff38131fff  com.apple.accounts.AccountsDaemon (113 - 113) <B538A8B2-0BF0-3C16-9FD7-95DD757FD754> /System/Library/PrivateFrameworks/AccountsDaemon.framework/Versions/A/AccountsDaemon
    0x7fff38132000 -     0x7fff38134fff  com.apple.OAuth (25 - 25) <457FF7AF-025F-338F-B8FD-86A5D7C22794> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
    0x7fff386e4000 -     0x7fff386f3fff  com.apple.HID (1.0 - 1) <B6B1791D-B625-337C-8D2F-05C9F95F494B> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
    0x7fff386f4000 -     0x7fff3881bfff  com.apple.QuickLookUIFramework (5.0 - 928.5) <8661B2DA-061A-309C-BD42-9DEE6D7F9E3E> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fff38bee000 -     0x7fff38c74fff  com.apple.coredav (1.0.1 - 889) <423466E8-387E-353F-A134-618BAD13AB7A> /System/Library/PrivateFrameworks/CoreDAV.framework/Versions/A/CoreDAV
    0x7fff38c75000 -     0x7fff38ccbfff  com.apple.ExchangeWebServices (8.0 - 814.100.1) <661EFC35-04D2-3733-A806-5C1956F0C00C> /System/Library/PrivateFrameworks/ExchangeWebServices.framework/Versions/A/ExchangeWebServices
    0x7fff38e08000 -     0x7fff38e08fff  com.apple.marco (10.0 - 1000) <10CD3F3D-C1ED-313F-BD24-0CDD95926844> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
    0x7fff38fee000 -     0x7fff39026fff  com.apple.contacts.ContactsAutocomplete (1.0 - 1152.4) <6F168917-1552-3A8B-B7F8-DAA21468349E> /System/Library/PrivateFrameworks/ContactsAutocomplete.framework/Versions/A/ContactsAutocomplete
    0x7fff39027000 -     0x7fff39033fff  com.apple.KerberosHelper (4.0 - 1.0) <8E7333D0-DCA2-3599-90FE-0B2F50C3EB64> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
    0x7fff39034000 -     0x7fff39077fff  com.apple.ResponseKit (1.0 - 165.2) <D996529D-562A-3E6E-A9D6-5C9A45446703> /System/Library/PrivateFrameworks/ResponseKit.framework/Versions/A/ResponseKit
    0x7fff39078000 -     0x7fff39097fff  com.apple.proactive.support.ProactiveEventTracker (1.0 - 294.7) <15483C77-7686-336C-BDAF-E16AFC986711> /System/Library/PrivateFrameworks/ProactiveEventTracker.framework/Versions/A/ProactiveEventTracker
    0x7fff394bb000 -     0x7fff394bbfff  com.apple.PhoneNumbers (1.0 - 1) <3C3718A2-FD55-37F3-B45B-7328BE28F8CC> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fff394bc000 -     0x7fff394c3fff  com.apple.URLFormatting (146 - 146.22) <22DEF2D9-9562-3894-B49E-EABD33DD746B> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
    0x7fff394c4000 -     0x7fff394d2fff  com.apple.accessibility.AXCoreUtilities (1.0 - 1) <203FB146-6AA7-38B4-90E4-7E6321B04D56> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
    0x7fff394d3000 -     0x7fff394eafff  libAccessibility.dylib (2885.49.1) <3686A929-B308-3045-B64E-3B78F9631DAD> /usr/lib/libAccessibility.dylib
    0x7fff394eb000 -     0x7fff3bc35fff  com.apple.WebCore (16611 - 16611.3.10.1.6) <405F670D-0966-3694-B279-FA641D46767A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
    0x7fff3bf25000 -     0x7fff3bf47fff  com.apple.quicklook.QuickLookSupport (1.0 - 135.5) <B6FB31F8-4790-3A43-9051-58FDB5A0BB88> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
    0x7fff3bf48000 -     0x7fff3bfdffff  com.apple.AirPlaySync (1.0 - 2780.10.4.1) <AD221FBA-7DFB-310F-AB9C-760D0F1F37B2> /System/Library/PrivateFrameworks/AirPlaySync.framework/Versions/A/AirPlaySync
    0x7fff3bfe4000 -     0x7fff3c0a5fff  com.apple.siri.parsec.CoreParsec (1.0 - 386.6.3) <047BED34-8377-3EF0-AE87-FF0C4D3D8C23> /System/Library/PrivateFrameworks/CoreParsec.framework/Versions/A/CoreParsec
    0x7fff3c1b2000 -     0x7fff3c1bcfff  libswiftCoreGraphics.dylib (2) <72BFB4DB-2627-3687-83C8-9F6875038F64> /usr/lib/swift/libswiftCoreGraphics.dylib
    0x7fff3c1bd000 -     0x7fff3c1c6fff  libswiftDarwin.dylib (??? - ???) <3A8833E7-2C6E-3FE2-BF58-602D4812E4CB> /usr/lib/swift/libswiftDarwin.dylib
    0x7fff3c213000 -     0x7fff3c261fff  com.apple.Safari.SafeBrowsing (16611 - 16611.3.10.1.6) <6445E8FE-D90A-38AA-80F2-834993AD7C50> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
    0x7fff3c262000 -     0x7fff3ca41fff  com.apple.WebKit (16611 - 16611.3.10.1.6) <8BEF50B1-DA9A-3BF0-9EC8-86D652883769> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x7fff3cb70000 -     0x7fff3cbf3fff  com.apple.CorePDF (4.0 - 529) <24987CDD-9F92-3359-AA4C-F3E9C2E9DD13> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fff3cbf4000 -     0x7fff3cbf7fff  com.apple.print.framework.Print (15 - 271) <47961FDE-D450-3357-948E-CFDEFA763A7B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff3cbf8000 -     0x7fff3cbfbfff  com.apple.Carbon (160 - 164) <0939DBF6-0BC9-3342-8053-1AD741298E3C> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff3ccf4000 -     0x7fff3ccf4fff  com.apple.avfoundation (2.0 - 2020.10) <19FE20E3-D0AC-3846-A30D-E1B9EC6731C3> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff3ceae000 -     0x7fff3cecdfff  com.apple.private.SystemPolicy (1.0 - 1) <328482A7-11FC-3DF4-B4B3-C73796A1FEA1> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
    0x7fff3d071000 -     0x7fff3d08efff  com.apple.sidecar-core (1.0 - 231.0.1) <0D792284-3B63-3245-AC0C-B30AB7028133> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
    0x7fff3d08f000 -     0x7fff3d092fff  com.apple.QuickLookNonBaseSystem (1.0 - 1) <D371CEC5-4326-3218-A9A4-280DA8DF6D85> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
    0x7fff3d252000 -     0x7fff3d26cfff  com.apple.mediastream (1.0 - 361.0.100) <B91A82EC-8466-3A1E-8B72-AE0CB85F43B9> /System/Library/PrivateFrameworks/MediaStream.framework/Versions/A/MediaStream
    0x7fff3d4a5000 -     0x7fff3d4a9fff  com.apple.CoreOptimization (1.0 - 1) <FDE8D61F-3821-38CE-8990-A45D4E88BB28> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
    0x7fff3d621000 -     0x7fff3d638fff  com.apple.SafariServices.framework (16611 - 16611.3.10.1.6) <A204D970-9F32-371A-B194-A9A652A7B2AE> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fff3d77a000 -     0x7fff3d7eafff  com.apple.LoggingSupport (1.0 - 1277.120.1) <07B8B384-3E3E-3A54-9F77-23A172A2494D> /System/Library/PrivateFrameworks/LoggingSupport.framework/Versions/A/LoggingSupport
    0x7fff3d7eb000 -     0x7fff3d7f6fff  com.apple.MallocStackLogging (1.0 - 1) <80F5AFE5-59AD-39BF-9A19-C055FE2468F1> /System/Library/PrivateFrameworks/MallocStackLogging.framework/Versions/A/MallocStackLogging
    0x7fff3d80b000 -     0x7fff3d81dfff  libmis.dylib (274.140.2) <F4EE6883-6A50-33B0-9AF9-5131DA07E3D3> /usr/lib/libmis.dylib
    0x7fff3d822000 -     0x7fff3d82afff  libswiftCoreAudio.dylib (1.1) <ED7E115B-DCF7-3FE9-8616-B3DE7F220651> /usr/lib/swift/libswiftCoreAudio.dylib
    0x7fff3d82b000 -     0x7fff3d82bfff  libswiftCoreFoundation.dylib (1.6) <7089C022-D5D4-30F1-905C-A6CED670A0AC> /usr/lib/swift/libswiftCoreFoundation.dylib
    0x7fff3d837000 -     0x7fff3d837fff  libswiftXPC.dylib (1.1) <AA894831-E21A-343D-85CD-AC6ABD45B39D> /usr/lib/swift/libswiftXPC.dylib
    0x7fff3d838000 -     0x7fff3d838fff  libswiftCoreImage.dylib (1) <C2D47675-3935-3356-BDE2-B99896B23823> /usr/lib/swift/libswiftCoreImage.dylib
    0x7fff3d839000 -     0x7fff3d839fff  libswiftIOKit.dylib (1) <3A1876ED-315D-3BCD-BDE3-C7438114B2CA> /usr/lib/swift/libswiftIOKit.dylib
    0x7fff3d83a000 -     0x7fff3d9a9fff  com.apple.CoreHandwriting (161 - 1.2) <4A2F7C42-4376-3AB3-8B82-5E9CB99C8378> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
    0x7fff3d9aa000 -     0x7fff3dc05fff  com.apple.imageKit (3.0 - 1100) <BB7249A7-AABA-39D2-8632-609871885248> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fff3dc06000 -     0x7fff3dd1cfff  com.apple.PencilKit (1.0 - 1) <3B310B07-A578-356A-B7B6-696EAC2CB933> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
    0x7fff3dd1d000 -     0x7fff3dd2efff  com.apple.sidecar-ui (1.0 - 231.0.1) <2BFBDB5D-449F-312D-8DB0-BAF97EAA1C5D> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
    0x7fff3dd3a000 -     0x7fff3dd3dfff  com.apple.WebInspectorUI (16611 - 16611.3.10.1.6) <71070A03-166E-309D-BE24-EFBF5273E5BA> /System/Library/PrivateFrameworks/WebInspectorUI.framework/Versions/A/WebInspectorUI
    0x7fff3df91000 -     0x7fff3e117fff  com.apple.SearchFoundation (1.0 - 386.6.3) <24C725DF-CEB5-3FE4-95F2-F4C91283138D> /System/Library/PrivateFrameworks/SearchFoundation.framework/Versions/A/SearchFoundation
    0x7fff3e118000 -     0x7fff3e350fff  com.apple.Photos (1.0 - 361.0.100) <121607ED-8881-3658-93B2-6E68C1A1F344> /System/Library/Frameworks/Photos.framework/Versions/A/Photos
    0x7fff3e351000 -     0x7fff3e3b3fff  com.apple.ImageCaptureCore (1711.5.2.1 - 1711.5.2.1) <B2AF26AA-B52B-3B72-8AB2-CD9EE596838B> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fff3e3b4000 -     0x7fff3e3d9fff  com.apple.quartzfilters (1.10.0 - 98) <2B9E46C1-57D6-3432-BADF-A1F3A96B138D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fff3e407000 -     0x7fff3e431fff  com.apple.ToneLibrary (1.0 - 1) <CDE1D4D5-1259-3117-90A6-111691FDE9B2> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
    0x7fff3ea95000 -     0x7fff3ebc1fff  com.apple.AnnotationKit (1.0 - 383.6) <4351CE42-686C-38AD-AFB1-14409718883A> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
    0x7fff3ebc2000 -     0x7fff3f062fff  com.apple.QuartzComposer (5.1 - 383) <28A84577-F578-3CCC-8163-F4417FEBCA57> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fff3f063000 -     0x7fff3f14bfff  com.apple.PDFKit (1.0 - 950.40.3) <A9CE6759-E17D-3C9C-81A4-5ABEDFC6E236> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fff3fde5000 -     0x7fff3fdfefff  libswiftsimd.dylib (1.3) <1FE0258C-4147-3F73-91F1-C4EDC5C96B81> /usr/lib/swift/libswiftsimd.dylib
    0x7fff403ca000 -     0x7fff40485fff  com.apple.AssetsLibraryServices (1.0 - 361.0.100) <C1192BB7-1D2D-326D-B09E-A15B7572192A> /System/Library/PrivateFrameworks/AssetsLibraryServices.framework/Versions/A/AssetsLibraryServices
    0x7fff40486000 -     0x7fff40b72fff  com.apple.PhotoLibraryServices (1.0 - 361.0.100) <359E552D-72B4-3F8B-A6D8-C2F3649320D5> /System/Library/PrivateFrameworks/PhotoLibraryServices.framework/Versions/A/PhotoLibraryServices
    0x7fff40b73000 -     0x7fff40bacfff  com.apple.siri.DistributedEvaluation (1.0 - 36.3) <9F47A6C4-DEE3-3591-B8D5-8BDC13127A9A> /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/DistributedEvaluation
    0x7fff40c53000 -     0x7fff40c5efff  com.apple.CaptiveNetworkSupport (13.0 - 1) <240BA909-E91B-3F24-A2EC-8D6A02931F5D> /System/Library/PrivateFrameworks/CaptiveNetwork.framework/Versions/A/CaptiveNetwork
    0x7fff410aa000 -     0x7fff410adfff  com.apple.quartzframework (1.5 - 25) <33CBA95A-CD84-3348-9187-F5255FF5966C> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fff414f0000 -     0x7fff414f1fff  libswiftCoreLocation.dylib (5) <35F180EB-670F-31BF-AABB-DA98D6275EC9> /usr/lib/swift/libswiftCoreLocation.dylib
    0x7fff414f2000 -     0x7fff414fbfff  libswiftCoreMIDI.dylib (2) <E37D2757-4D96-3B46-ADB8-6E98B50F7FF0> /usr/lib/swift/libswiftCoreMIDI.dylib
    0x7fff41de7000 -     0x7fff41debfff  libswiftCoreData.dylib (3) <730565F1-62BD-3367-8D3E-96B019628488> /usr/lib/swift/libswiftCoreData.dylib
    0x7fff42b6f000 -     0x7fff438cffff  libfaceCore.dylib (4.3.1) <71AE1B46-AE0E-3E12-9175-97654FDB7384> /System/Library/Frameworks/Vision.framework/libfaceCore.dylib
    0x7fff438d0000 -     0x7fff439e3fff  com.apple.TextRecognition (1.0 - 157) <45029F8D-0C5C-338F-ADAF-D5E15A538AE1> /System/Library/PrivateFrameworks/TextRecognition.framework/Versions/A/TextRecognition
    0x7fff439e4000 -     0x7fff439fcfff  com.apple.Futhark (1.0 - 1) <2170A7F5-ED10-3E79-B950-8A6A1A4E7F71> /System/Library/PrivateFrameworks/Futhark.framework/Versions/A/Futhark
    0x7fff45c4c000 -     0x7fff45cf8fff  com.apple.MMCS (1.3 - 573) <F9100BFC-83BB-3C69-ACB0-4DB6210611A4> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fff45cf9000 -     0x7fff45d65fff  com.apple.acg.InertiaCam (1.0 - 1) <624C1078-697B-3AE6-B6B7-DCCF5236B594> /System/Library/PrivateFrameworks/InertiaCam.framework/Versions/A/InertiaCam
    0x7fff45ed9000 -     0x7fff45edefff  libswiftMetal.dylib (1.3.1) <4BF4F0EE-7AEF-3246-8C2B-24F30C00E582> /usr/lib/swift/libswiftMetal.dylib
    0x7fff45ee5000 -     0x7fff45ef0fff  libswiftCloudKit.dylib (990) <49044D72-AE08-3AC5-8227-F4426CB989C3> /usr/lib/swift/libswiftCloudKit.dylib
    0x7fff47bfa000 -     0x7fff47c3afff  com.apple.osanalytics.OSAnalytics (1.0 - 1) <0827F522-B66F-33E7-8670-7DC967961979> /System/Library/PrivateFrameworks/OSAnalytics.framework/Versions/A/OSAnalytics
    0x7fff47d75000 -     0x7fff47eeafff  com.apple.CloudPhotoLibrary (1.0 - 361.0.100) <D0D2920C-25CC-3A86-BE74-8504DE8D22DD> /System/Library/PrivateFrameworks/CloudPhotoLibrary.framework/Versions/A/CloudPhotoLibrary
    0x7fff47eeb000 -     0x7fff47ef7fff  com.apple.DCIMServices (1.0 - 361.0.100) <652F02D5-F70D-341A-87BF-9A285DCAEDBF> /System/Library/PrivateFrameworks/DCIMServices.framework/Versions/A/DCIMServices
    0x7fff4846f000 -     0x7fff48483fff  libswiftAppKit.dylib (104) <ADE56277-3204-363A-8D8F-A63935022C60> /usr/lib/swift/libswiftAppKit.dylib
    0x7fff48484000 -     0x7fff48485fff  libswiftQuartzCore.dylib (1) <C97D1F92-3C90-386C-91D9-0F6EFF8338AC> /usr/lib/swift/libswiftQuartzCore.dylib
    0x7fff48b13000 -     0x7fff48b3afff  com.apple.photo.MediaConversionService (6.0 - 361.0.100) <E517D643-657C-3139-AE7E-9FD7AE10A362> /System/Library/PrivateFrameworks/MediaConversionService.framework/Versions/A/MediaConversionService
    0x7fff497c4000 -     0x7fff499c5fff  com.apple.photo.NeutrinoCore (1.0 - 361.0.100) <7674BF37-3C1F-3138-9410-E865F76831ED> /System/Library/PrivateFrameworks/NeutrinoCore.framework/Versions/A/NeutrinoCore
    0x7fff4a76e000 -     0x7fff4a7dafff  com.apple.PhotosFormats (1.0 - 361.0.100) <B900A11B-7BE8-36BC-A65F-74EBF6E9F7E7> /System/Library/PrivateFrameworks/PhotosFormats.framework/Versions/A/PhotosFormats
    0x7fff4bb51000 -     0x7fff4bc5cfff  com.apple.CoreMediaStream (1.0 - 361.0.100) <B7454289-09A9-3825-9B65-B68DA62CEC77> /System/Library/PrivateFrameworks/CoreMediaStream.framework/Versions/A/CoreMediaStream
    0x7fff4bc5d000 -     0x7fff4bc6ffff  libswiftUniformTypeIdentifiers.dylib (637) <7BE0DCE3-4501-3EC8-801D-9515A9F3A2A5> /usr/lib/swift/libswiftUniformTypeIdentifiers.dylib
    0x7fff4d508000 -     0x7fff4d65efff  com.apple.photo.PhotoImaging (1.0 - 361.0.100) <D1789D00-8403-3FDD-A85D-1F2D3E81BC07> /System/Library/PrivateFrameworks/PhotoImaging.framework/Versions/A/PhotoImaging
    0x7fff4de99000 -     0x7fff4dee3fff  com.apple.PhotosImagingFoundation (6.0 - 361.0.100) <C2789A85-110B-33FA-A570-4B0A3A1E29FF> /System/Library/PrivateFrameworks/PhotosImagingFoundation.framework/Versions/A/PhotosImagingFoundation
    0x7fff4dee4000 -     0x7fff4deeefff  com.apple.CloudPhotoServices (1.0 - 361.0.100) <F70C9CC6-0D71-3BD3-B405-EDFB26DE1D1C> /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/CloudPhotoServices
    0x7fff4deef000 -     0x7fff4df4afff  com.apple.acg.AutoLoop (1.0 - 1) <A2AF33D5-E928-34C6-A3CB-C1264E9419A9> /System/Library/PrivateFrameworks/AutoLoop.framework/Versions/A/AutoLoop
    0x7fff4e460000 -     0x7fff4e498fff  libswiftCoreMedia.dylib (1) <83BAE990-F5E8-3140-8EAA-790003640039> /usr/lib/swift/libswiftCoreMedia.dylib
    0x7fff4ef4b000 -     0x7fff4ef4cfff  libswiftOSLog.dylib (1) <110E5984-F615-349C-A936-EBDF79253237> /usr/lib/swift/libswiftOSLog.dylib
    0x7fff4effc000 -     0x7fff4f002fff  libswiftAVFoundation.dylib (2020.10) <6B04BD80-9F5E-384D-9F59-04F9FE5CC500> /usr/lib/swift/libswiftAVFoundation.dylib
    0x7fff518b9000 -     0x7fff51958fff  com.apple.Symbolication (12.5 - 64544.70.1) <6D9C8333-6369-3964-A972-5BF99B0AC549> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff53e17000 -     0x7fff53e23fff  com.apple.OSLog (1.0 - 1277.120.1) <BB2562DB-6D07-3A93-953B-A423D71CF9E3> /System/Library/Frameworks/OSLog.framework/Versions/A/OSLog
    0x7fff53f64000 -     0x7fff53f79fff  com.apple.ScriptingBridge (1.4 - 80) <CDB2C881-3762-30FD-ABC6-D9A0EC17AED6> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
    0x7fff53fd0000 -     0x7fff540f8fff  com.apple.InternalSwiftProtobuf (1.0 - 1.14.0) <65A487DB-39B1-34A8-A3E7-4EFAAF5AAEC7> /System/Library/PrivateFrameworks/InternalSwiftProtobuf.framework/Versions/A/InternalSwiftProtobuf
    0x7fff6bd63000 -     0x7fff6bd69fff  libCoreFSCache.dylib (200.11) <A10745F3-1533-329E-B42A-6DE60871F7C0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff6bd6a000 -     0x7fff6bd6efff  libCoreVMClient.dylib (200.11) <3370F902-DA03-3297-804C-EB5F7FD67A01> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff6bd6f000 -     0x7fff6bd7efff  com.apple.opengl (18.5.9 - 18.5.9) <2A421CC5-4D60-339C-9772-3AC991232BD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff6bd7f000 -     0x7fff6bd81fff  libCVMSPluginSupport.dylib (18.5.9) <BF44FEB3-FB8E-3FD8-8988-AD56AD53CFD4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff6bd82000 -     0x7fff6bd8afff  libGFXShared.dylib (18.5.9) <C4751529-359A-3ECC-84B2-74A23EFAD42A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff6bd8b000 -     0x7fff6bdbefff  libGLImage.dylib (18.5.9) <C153E192-20A3-3F7D-A897-533DACE748EC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff6bdbf000 -     0x7fff6bdfbfff  libGLU.dylib (18.5.9) <8275A6AB-AAD5-3222-A80B-411C0FAFCA63> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff6bf90000 -     0x7fff6bf9afff  libGL.dylib (18.5.9) <C6BE589B-CD26-3142-BD18-10C13D404904> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff6d3da000 -     0x7fff6d432fff  com.apple.opencl (4.6 - 4.6) <79DA4138-12AB-3561-9967-D49EFB14B437> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff6e4e4000 -     0x7fff6e5cbfff  com.apple.audio.AVFAudio (1.0 - 477.88) <B2C8331B-60D4-3651-B9A0-B9914A230C36> /System/Library/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fff6fb4d000 -     0x7fff6fb5ffff  com.apple.CMImaging (1.0 - 82.6) <F60EEDA0-C221-3B51-B537-EE2FE48E19E9> /System/Library/PrivateFrameworks/CMImaging.framework/Versions/A/CMImaging
    0x7fff71e72000 -     0x7fff725fbfff  com.apple.PegasusAPI (1.0 - 386.6.3) <C23212FD-EEE7-3928-B0E1-049D80E4F45C> /System/Library/PrivateFrameworks/PegasusAPI.framework/Versions/A/PegasusAPI
    0x7fff77c12000 -     0x7fff77c19fff  libRosetta.dylib (203.58) <26D08622-69F5-32DB-80D2-9B4651A9F0CC> /usr/lib/libRosetta.dylib
    0x7fff77e81000 -     0x7fff77f6cfff  libcrypto.0.9.8.dylib (80) <0D035BEF-BB52-3237-B734-66EDBB33EF23> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff7832c000 -     0x7fff7837ffff  libstdc++.6.dylib (104.1) <72E707D0-D277-3AA2-980E-02302FAEE5BC> /usr/lib/libstdc++.6.dylib
    0x7fff78414000 -     0x7fff78414fff  libswiftPhotos.dylib (361.0.100) <41146949-00A7-38E5-B05F-D8C634D01F1E> /usr/lib/swift/libswiftPhotos.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=933.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=933.5M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Kernel Alloc Once                    8K        1
MALLOC                           178.5M       17
MALLOC guard page                   24K        4
MALLOC_MEDIUM (reserved)         360.0M        3         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
STACK GUARD                       56.0M        1
Stack                             8192K        1
VM_ALLOCATE                        208K        3
__DATA                            31.3M      583
__DATA_CONST                      31.1M      342
__DATA_DIRTY                      1868K      228
__FONT_DATA                          4K        1
__LINKEDIT                       527.6M       71
__OBJC_RO                         70.3M        1
__OBJC_RW                         2480K        2
__TEXT                           495.2M      571
__UNICODE                          588K        1
shared memory                        4K        1
TOTAL                              2.1G     1832
TOTAL, minus reserved VM space     1.4G     1832
Edited by Driftwood
Link to post
On 10/19/2021 at 8:44 AM, fabiosun said:
Have you patched all three mandatory plugin ? (you can find in this thread)
Which Premiere version Exactly?
And which Puget benchmark version exactly?
Thank you
Edit it hangs here also on an Intel platform:
Maybe a permission problem in Privacy -> Automation to be fixed...
5 hours ago, Driftwood said:
@tomnic Excellent work! Gonna try this on Photoshop beta 23.
Could you take a look at this for Camtasia 2019? (Camtasia 2 mid version works in AMD but ever since Oct 2016 version onwards of Camtasia 2 and upto version 2020 it fails. Here's the Camtasia 2019 lib failure.
  Reveal hidden contents
Process:               Camtasia 2019 [12254]
Path:                  /Applications/Camtasia 2019.app/Contents/MacOS/Camtasia 2019
Identifier:            com.techsmith.camtasia2019
Version:               2019.0.7 (109599)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Camtasia 2019 [12254]
User ID:               501
Date/Time:             2021-10-20 16:26:07.674 +0100
OS Version:            macOS 11.6.1 (20G221)
Report Version:        12
Anonymous UUID:        CFD7290E-9754-1ABA-09FD-A8BF8CD3C8BB
Time Awake Since Boot: 100000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x00007ffee5a51ff8
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [12254]
VM Regions Near 0x7ffee5a51ff8:
    MALLOC_MEDIUM (reserved) 7f9ef0800000-7f9ef8000000 [120.0M] rw-/rwx SM=NUL  reserved VM address space (unallocated)
--> STACK GUARD              7ffee2252000-7ffee5a52000 [ 56.0M] ---/rwx SM=NUL  stack guard for thread 0
    Stack                    7ffee5a52000-7ffee6252000 [ 8192K] rw-/rwx SM=SHM  thread 0
Application Specific Information:
/Applications/Camtasia 2019.app/Contents/MacOS/../Frameworks/StatsLoaders.framework/Versions/A/StatsLoaders
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   com.techsmith.StatsLoaders        0x000000010e732841 _intel_fast_memset.A + 1
1   dyld                              0x0000000115424f52 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 40
2   dyld                              0x000000011541fae6 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 492
3   dyld                              0x000000011541fa51 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 343
4   dyld                              0x000000011541fa51 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 343
5   dyld                              0x000000011541d89f ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 191
6   dyld                              0x000000011541d940 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 82
7   dyld                              0x00000001154098b1 dyld::initializeMainExecutable() + 199
8   dyld                              0x0000000115410041 dyld::_main(macho_header const*, unsigned long, int, char const**, char const**, char const**, unsigned long*) + 9098
9   dyld                              0x0000000115408224 dyldbootstrap::start(dyld3::MachOLoaded const*, int, char const**, dyld3::MachOLoaded const*, unsigned long*) + 450
10  dyld                              0x0000000115408025 _dyld_start + 37
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x000000010e86d6e0  rbx: 0x000000010e5952f0  rcx: 0x00000007389d97ff  rdx: 0x0000000000001000
  rdi: 0x000000010e7a3a28  rsi: 0x00000000ffffffff  rbp: 0x00007ffee6249dd0  rsp: 0x00007ffee5a52000
   r8: 0x0000000000000001   r9: 0x0000000000000006  r10: 0x0000000000000000  r11: 0x0000000000000000
  r12: 0x000000010e7a3220  r13: 0x00007ffee6249c80  r14: 0x00007fff806ebd78  r15: 0x0000000000000000
  rip: 0x000000010e732841  rfl: 0x0000000000010202  cr2: 0x00007ffee5a51ff8
Logical CPU:     34
Error Code:      0x00000006 (no mapping for user data write)
Trap Number:     14
Thread 0 instruction stream:
  41 81 e1 ff 01 00 00 41-81 f9 ff 01 00 00 75 09  A......A......u.
  48 83 c4 08 e9 46 ff ff-ff 44 8a 00 41 80 e0 7f  H....F...D..A...
  41 80 f8 7f 75 09 48 83-c4 08 e9 20 ff ff ff f6  A...u.H.... ....
  00 01 74 09 48 83 c4 08-e9 02 ff ff ff e8 cd ee  ..t.H...........
  ff ff e9 6a ff ff ff 0f-1f 84 00 00 00 00 00 90  ...j............
  90 90 90 90 90 90 90 90-90 90 90 90 90 90 90 56  ...............V
 [e8]3a 00 00 00 59 c3 0f-1f 84 00 00 00 00 00 e9  .:...Y..........    <==
  bb 74 00 00 0f 1f 40 00-0f 1f 80 00 00 00 00 e9  .t....@.........
  ab 4c 00 00 0f 1f 40 00-0f 1f 80 00 00 00 00 e9  .L....@.........
  4b 1c 00 00 0f 1f 40 00-0f 1f 80 00 00 00 00 56  K.....@........V
  48 b9 ff 97 9d 38 07 00-00 00 48 8d 05 4e ae 13  H....8....H..N..
  00 4c 8b 00 4c 23 c1 4c-3b c1 75 09 48 83 c4 08  .L..L#.L;.u.H...
Thread 0 last branch register state not available.
Binary Images:
       0x1099ae000 -        0x1099c6fff +com.techsmith.camtasia2019 (2019.0.7 - 109599) <91BF2823-2D02-33AC-ACDB-8E19A21D28D1> /Applications/Camtasia 2019.app/Contents/MacOS/Camtasia 2019
       0x1099d7000 -        0x109a15fff +org.sparkle-project.Sparkle (1.16.0 1-g03abfe27 - 1.16.0) <7C18DCA0-8C47-3900-B07B-5A126FA9A415> /Applications/Camtasia 2019.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
       0x109a5d000 -        0x109a6cfff +libTSCLicensing.dylib (0) <B2E828AA-EECB-3498-883F-3079C89E2562> /Applications/Camtasia 2019.app/Contents/Frameworks/libTSCLicensing.dylib
       0x109a82000 -        0x109bf5fff +libCSRenderLib.dylib (0) <A188FF1B-D16B-3638-9B94-6E8D76FD17B5> /Applications/Camtasia 2019.app/Contents/Frameworks/libCSRenderLib.dylib
       0x109d9f000 -        0x109da6fff +libCSAudioAnalyzer.dylib (0) <17596B0E-BEB4-3B21-9E67-F6C2B1CF5AF7> /Applications/Camtasia 2019.app/Contents/Frameworks/libCSAudioAnalyzer.dylib
       0x109dbb000 -        0x10a316fff +libCSMediaLib.dylib (0) <85F258D7-CB31-303F-89FB-F92A3CEC6DA6> /Applications/Camtasia 2019.app/Contents/Frameworks/libCSMediaLib.dylib
       0x10a9a0000 -        0x10aa96fff +librui_5.2.0.x64.dylib (0) <9EAF4F8D-409F-3F51-BB0A-EA2C995041DF> /Applications/Camtasia 2019.app/Contents/Frameworks/librui_5.2.0.x64.dylib
       0x10aab8000 -        0x10aabffff +libCSMediaLibUtl.dylib (0) <315BDB99-509E-3546-9EFC-5F9E135BCDC1> /Applications/Camtasia 2019.app/Contents/Frameworks/libCSMediaLibUtl.dylib
       0x10aade000 -        0x10aaf3fff +com.techsmith.TSCVST (1.0 - 1) <6A7B7B93-0643-36D4-9BE4-88DB48748EDC> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCVST.framework/Versions/A/TSCVST
       0x10ab20000 -        0x10b62cfff +libXRenderLib.dylib (0) <ED0F346F-031B-3D09-A4EA-A9B9AAB9CEA5> /Applications/Camtasia 2019.app/Contents/Frameworks/libXRenderLib.dylib
       0x10b9f4000 -        0x10ba00fff +com.techsmith.TSCWriter.TSCWriter-Framework- (1.0 - 1) <9B505C75-C750-3367-AA56-EED90AB58D88> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCWriter.framework/Versions/A/TSCWriter
       0x10ba26000 -        0x10ba28fff +com.techsmith.ACEInstaller (1.0 - 1) <CD06B3E9-A867-3760-8B16-B536523495F1> /Applications/Camtasia 2019.app/Contents/Frameworks/ACEInstaller.framework/Versions/A/ACEInstaller
       0x10ba30000 -        0x10ba33fff +com.kulakov.PTHotKey (2.0) <73F1E771-E710-3476-A00C-E3DEB8ECDA40> /Applications/Camtasia 2019.app/Contents/Frameworks/PTHotKey.framework/Versions/A/PTHotKey
       0x10ba3f000 -        0x10ba56fff +org.mantle.Mantle (1.0 - ???) <930F61E7-D838-35D7-9A85-DC3C1E0B26E0> /Applications/Camtasia 2019.app/Contents/Frameworks/Mantle.framework/Versions/A/Mantle
       0x10ba6a000 -        0x10ba8bfff +com.TechSmith.TSCStorage (1.0 - 1) <65C2FAA4-E64B-3E6A-97D8-3A185261789B> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCStorage.framework/Versions/A/TSCStorage
       0x10baa7000 -        0x10baa8fff +com.techsmith.TSCEntitlement (1.0 - 1) <DA54AFD7-B543-3CE0-B5C9-C755082C80E0> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCEntitlement.framework/Versions/A/TSCEntitlement
       0x10bab2000 -        0x10bac2fff +libAudioExtractionLib.dylib (0) <2CBF4651-56DA-3BB4-80A8-077A1111C061> /Applications/Camtasia 2019.app/Contents/Frameworks/libAudioExtractionLib.dylib
       0x10baea000 -        0x10bb1efff +com.techsmith.TSCConnectServer (1.0 - 1) <84DE428E-91B0-3036-86B3-2F2D85CC0F52> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCConnectServer.framework/Versions/A/TSCConnectServer
       0x10bb51000 -        0x10bb71fff +com.alamofire.AFNetworking (3.0.0 - 3.1.0) <83215663-DFFB-3B93-AD61-AB13CE629818> /Applications/Camtasia 2019.app/Contents/Frameworks/AFNetworking.framework/Versions/A/AFNetworking
       0x10bb96000 -        0x10bb9bfff +com.techsmith.TSCCloudServices (1.0 - 1) <CFDD6922-8C01-3313-8197-54F1EA3CD894> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCCloudServices.framework/Versions/A/TSCCloudServices
       0x10bbae000 -        0x10bbc8fff +com.techsmith.TSCCloud.TSCCloud (1.0 - 1) <B9C31B0E-9E78-3433-871B-75C36198DB64> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCCloud.framework/Versions/A/TSCCloud
       0x10bc10000 -        0x10bc1afff +com.TechSmith.TSCAccount (1.0 - 1) <F6AA5337-9F8F-3F8B-8B4D-B6BF7D7702EA> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCAccount.framework/Versions/A/TSCAccount
       0x10bc29000 -        0x10c3e2fff +com.TechSmith.CocoaCSEditor (0.1 - 1) <0FA3FEF0-F2BD-3B43-8CCD-797571543809> /Applications/Camtasia 2019.app/Contents/Frameworks/CocoaCSEditor.framework/Versions/A/CocoaCSEditor
       0x10ca73000 -        0x10ca7dfff +com.techsmith.GIFMaker (1.0 - 1) <AD7A1233-78AC-3809-93D1-639D1F8B8486> /Applications/Camtasia 2019.app/Contents/Frameworks/GIFMaker.framework/Versions/A/GIFMaker
       0x10ca90000 -        0x10ca96fff +libSmartFocusCmds.dylib (0) <21C5327D-3999-33FE-8691-0C5625650C21> /Applications/Camtasia 2019.app/Contents/Frameworks/libSmartFocusCmds.dylib
       0x10caa8000 -        0x10caaffff +com.techsmith.TechSmithZip (1.0 - 1) <B01C4F4E-D9AD-3A88-BF5C-F629D92A68CC> /Applications/Camtasia 2019.app/Contents/Frameworks/TechSmithZip.framework/Versions/A/TechSmithZip
       0x10cabc000 -        0x10cb2afff +libCamtasiaCommon.dylib (0) <4B4026F0-E55B-30BE-9C88-9EC546C19D4A> /Applications/Camtasia 2019.app/Contents/Frameworks/libCamtasiaCommon.dylib
       0x10cba9000 -        0x10cbbcfff +com.yourcompany.yourcocoaframework (1.0) <F1822A00-CB42-33F5-9DBA-C6904106BE4B> /Applications/Camtasia 2019.app/Contents/Frameworks/ScreencastFramework.framework/Versions/A/ScreencastFramework
       0x10cbd8000 -        0x10cbfefff +libSmartFocus.dylib (0) <94CFD256-93C7-358F-9C6F-5BBA7037952D> /Applications/Camtasia 2019.app/Contents/Frameworks/libSmartFocus.dylib
       0x10cc21000 -        0x10cc2cfff +com.mainconcept.mc.config.avc (10.0 - 10.0.14.2531) <E862E269-A68A-3A36-B276-41ED09F405DA> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_config_avc.framework/Versions/10/mc_config_avc
       0x10cc36000 -        0x10cc71fff +com.techsmith.mc-dec-aac (1.0 - 1) <F4837B8A-031B-332D-BD31-DCE9DD560486> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_dec_aac.framework/Versions/10/mc_dec_aac
       0x10cc7b000 -        0x10ce84fff +com.techsmith.mc-dec-avc (1.0 - 1) <C8FB6C3C-3F66-38DC-866A-56B6D610B843> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_dec_avc.framework/Versions/10/mc_dec_avc
       0x10ce9b000 -        0x10ced4fff +com.techsmith.mc-enc-aac (1.0 - 1) <567E4C2E-1938-3E30-B38E-3D107117E6AD> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_enc_aac.framework/Versions/10/mc_enc_aac
       0x10cede000 -        0x10d270fff +CSEditorLib.dylib (0) <FCFFA4D3-ADDB-31B6-87BB-DE9632A0974B> /Applications/Camtasia 2019.app/Contents/Frameworks/CSEditorLib.dylib
       0x10d749000 -        0x10da7dfff +com.techsmith.mc-enc-avc (1.0 - 1) <9D208970-2BF3-38DD-B785-C93D120BC83D> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_enc_avc.framework/Versions/10/mc_enc_avc
       0x10dab1000 -        0x10de92fff +com.mainconcept.mc.mux.mp4 (10.0 - 10.0.14.2531) <37D00BD7-6CB2-3004-B425-2ECBE5EC89B4> /Applications/Camtasia 2019.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/10/mc_mux_mp4
       0x10ded0000 -        0x10ded1fff +com.techsmith.PdfSupport (1.0 - 1) <800B6587-0E01-3429-B7BF-B985448B1AD9> /Applications/Camtasia 2019.app/Contents/Frameworks/PdfSupport.framework/Versions/A/PdfSupport
       0x10dee2000 -        0x10df4afff +com.techsmith.RemixCallouts (1.0 - 1) <64C232BB-D26E-3178-A8BA-79D28527E2D8> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/RemixCallouts
       0x10e026000 -        0x10e0aafff +com.techsmith.TechSmithKit (1.0 - 1) <89D7415A-8B06-370C-80A6-2B2DB657EE7A> /Applications/Camtasia 2019.app/Contents/Frameworks/TechSmithKit.framework/Versions/A/TechSmithKit
       0x10e146000 -        0x10e1d1fff +com.techsmith.GTL (2.0) <F3DF20A8-9A7B-30D4-8FC8-F75115153387> /Applications/Camtasia 2019.app/Contents/Frameworks/GTL.framework/Versions/A/GTL
       0x10e258000 -        0x10e32efff +com.techsmith.TSCCapture (1.0 - 1) <160F0C26-8CE0-3AF7-8A25-9E523539BB40> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCCapture.framework/Versions/A/TSCCapture
       0x10e480000 -        0x10e48cfff +com.kulakov.ShortcutRecorder (2.0) <35616DF8-0B7B-3680-B315-421528FA8777> /Applications/Camtasia 2019.app/Contents/Frameworks/ShortcutRecorder.framework/Versions/A/ShortcutRecorder
       0x10e49e000 -        0x10e4d4fff +com.techsmith.TSCRegionSelection (1.0) <482B4E48-EA5A-3CF2-85CF-25BE9B14C0FC> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCRegionSelection.framework/Versions/A/TSCRegionSelection
       0x10e502000 -        0x10e50ffff +com.techsmith.TSCSharing (1.0 - 1) <845FD71B-6A80-3D5A-923D-4BD2D843E170> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCSharing.framework/Versions/A/TSCSharing
       0x10e525000 -        0x10e52bfff +com.techsmith.TSCSharingPlugin (1.0 - 1) <5D47E3F2-AD78-301F-A53D-70881A7CD02A> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCSharingPlugin.framework/Versions/A/TSCSharingPlugin
       0x10e538000 -        0x10e77efff +com.techsmith.StatsLoaders (1.0 - 1) <A5A5F743-891E-3C69-AB75-11C982DB23C7> /Applications/Camtasia 2019.app/Contents/Frameworks/StatsLoaders.framework/Versions/A/StatsLoaders
       0x10e9a8000 -        0x10e9d6fff +libfontconfig.1.dylib (0) <9875A1E4-324A-353E-A9B3-0D8863DBFFF9> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libfontconfig.1.dylib
       0x10e9f0000 -        0x10ea9cfff +libcairo.2.dylib (0) <D651C1D8-8146-3CF1-8CBB-8E7444679EEF> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libcairo.2.dylib
       0x10ead1000 -        0x10eb4efff +libfreetype.6.dylib (0) <6A0A1CF7-9729-3B75-A1C3-75B6A4D10E95> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libfreetype.6.dylib
       0x10eb71000 -        0x10eb9dfff +libpango-1.0.0.dylib (0) <C0056E53-306C-3DF5-8CDB-FC08ADBBC672> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpango-1.0.0.dylib
       0x10ebba000 -        0x10ebc6fff +libpangoft2-1.0.0.dylib (0) <91C9F8C4-884E-379A-93F1-59D19FF3BA21> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpangoft2-1.0.0.dylib
       0x10ebdb000 -        0x10ebe4fff +libpangocairo-1.0.0.dylib (0) <2587A8C1-EA83-3BE1-B847-0E70B58C5B71> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpangocairo-1.0.0.dylib
       0x10ebf5000 -        0x10ebfafff +libffi.6.dylib (0) <700FEC96-07A8-3D27-9458-60B8BEB7070E> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libffi.6.dylib
       0x10ec04000 -        0x10ec0dfff +libintl.8.dylib (0) <901CA836-8F7A-392A-8201-10CDEDF4F8F9> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libintl.8.dylib
       0x10ec1c000 -        0x10ec3ffff +libpng16.16.dylib (0) <FA0BEF1C-677C-30F2-B904-B569D6F4D533> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpng16.16.dylib
       0x10ec4e000 -        0x10ed52fff +libgio-2.0.0.dylib (0) <1FA5213D-7E29-3082-8ABC-14C628CDE889> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libgio-2.0.0.dylib
       0x10edcd000 -        0x10ee9bfff +libglib-2.0.0.dylib (0) <95E0497B-72E1-3DD8-B114-82DBD3646166> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libglib-2.0.0.dylib
       0x10eece000 -        0x10eed2fff +libgmodule-2.0.0.dylib (0) <B24CBC1D-8A99-3844-B26B-314424472384> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libgmodule-2.0.0.dylib
       0x10eedd000 -        0x10ef56fff +libpixman-1.0.dylib (0) <F43AA1C9-41F6-330A-AE25-168FB5077A6E> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpixman-1.0.dylib
       0x10ef74000 -        0x10efa8fff +libgobject-2.0.0.dylib (0) <D36577DF-8525-368F-9106-0A0D5C61FF72> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libgobject-2.0.0.dylib
       0x10efc0000 -        0x10efc3fff +libgthread-2.0.0.dylib (0) <6A010CFC-7297-3A7D-B47D-0606705C7ACF> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libgthread-2.0.0.dylib
       0x10efcf000 -        0x10efe7fff +libfribidi.0.dylib (0) <A3C6AE05-965B-3728-A61E-BDDD897D95EB> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libfribidi.0.dylib
       0x10eff3000 -        0x10f05bfff +libpcre.1.dylib (0) <BB83A439-9634-333B-9B10-604C57C703DE> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libpcre.1.dylib
       0x10f069000 -        0x10f0e8fff +libharfbuzz.0.dylib (0) <374D2AA1-33D2-346E-87F6-220E804EF022> /Applications/Camtasia 2019.app/Contents/Frameworks/RemixCallouts.framework/Versions/A/Resources/lib/libharfbuzz.0.dylib
       0x10f10a000 -        0x10f11afff +com.rogueamoeba.ACE (11.0.0 - 11.0.0) <5FB661E7-50DF-385B-98D9-DBF75A484952> /Applications/Camtasia 2019.app/Contents/Frameworks/TSCCapture.framework/Versions/A/Frameworks/ACE.framework/Versions/A/ACE
       0x10f12f000 -        0x10f32cfff +libDecoderLib.dylib (0) <69A6A3A2-C932-3719-AFF3-602CC50C9291> /Applications/Camtasia 2019.app/Contents/Frameworks/libDecoderLib.dylib
       0x10f4b0000 -        0x10f4b6fff +libCSThumbnailer.dylib (0) <CAC36A79-9292-3CE6-BF32-1955322B26F3> /Applications/Camtasia 2019.app/Contents/Frameworks/libCSThumbnailer.dylib
       0x10f504000 -        0x10f515fff +at.nih.libzip (1.3.1a - 1) <45E4772F-A697-3582-8AD7-E93D7AA0BFDC> /Applications/Camtasia 2019.app/Contents/Frameworks/libzip.framework/Versions/A/libzip
       0x115407000 -        0x1154a2fff  dyld (852.2) <14C5D17F-5032-37A2-9CD8-F437EB4A3992> /usr/lib/dyld
    0x7fff200eb000 -     0x7fff200ecfff  libsystem_blocks.dylib (79) <4DF6D8F5-D9C2-3A96-8DE4-5E99D6B73DC8> /usr/lib/system/libsystem_blocks.dylib
    0x7fff200ed000 -     0x7fff20122fff  libxpc.dylib (2038.120.1) <0397FC9F-BD11-31FC-882E-9EDAA1E5CA65> /usr/lib/system/libxpc.dylib
    0x7fff20123000 -     0x7fff2013afff  libsystem_trace.dylib (1277.120.1) <0A24EB90-5396-36B0-A7E6-E9288702856D> /usr/lib/system/libsystem_trace.dylib
    0x7fff2013b000 -     0x7fff201d8fff  libcorecrypto.dylib (1000.140.4) <57E7471E-3960-3398-8918-20DF446EA99B> /usr/lib/system/libcorecrypto.dylib
    0x7fff201d9000 -     0x7fff20205fff  libsystem_malloc.dylib (317.140.5) <10C22FD0-FC7B-3325-852E-FEC4E88D2BC5> /usr/lib/system/libsystem_malloc.dylib
    0x7fff20206000 -     0x7fff2024afff  libdispatch.dylib (1271.120.2) <BA7AD614-F2C2-3E89-9043-43DD548AE5B1> /usr/lib/system/libdispatch.dylib
    0x7fff2024b000 -     0x7fff20284fff  libobjc.A.dylib (824) <712AAE11-4AB9-39A1-A860-A5BF2CD4B932> /usr/lib/libobjc.A.dylib
    0x7fff20285000 -     0x7fff20287fff  libsystem_featureflags.dylib (28.60.1) <6EB33926-8E22-3000-B2F1-C6182B8CBD8F> /usr/lib/system/libsystem_featureflags.dylib
    0x7fff20288000 -     0x7fff20310fff  libsystem_c.dylib (1439.141.1) <8447A4B8-0751-3EF1-AA9B-042E40EFA07D> /usr/lib/system/libsystem_c.dylib
    0x7fff20311000 -     0x7fff20366fff  libc++.1.dylib (905.6) <81674ADB-670F-3B19-AF5D-F3F66CB93D44> /usr/lib/libc++.1.dylib
    0x7fff20367000 -     0x7fff2037cfff  libc++abi.dylib (905.6) <78CE7863-E224-3D0B-98F1-E5E3E382322D> /usr/lib/libc++abi.dylib
    0x7fff2037d000 -     0x7fff203acfff  libsystem_kernel.dylib (7195.141.8) <8DFE5B9F-B718-3D48-ABB1-238122989218> /usr/lib/system/libsystem_kernel.dylib
    0x7fff203ad000 -     0x7fff203b8fff  libsystem_pthread.dylib (454.120.2) <49670AEC-4D5D-3383-906C-23F568351FCB> /usr/lib/system/libsystem_pthread.dylib
    0x7fff203b9000 -     0x7fff203f4fff  libdyld.dylib (852.2) <5FBD0E1A-ACCE-36DB-B11C-622F26C85132> /usr/lib/system/libdyld.dylib
    0x7fff203f5000 -     0x7fff203fefff  libsystem_platform.dylib (254.80.2) <A85D12B6-6213-34EE-84D8-8E993C19E330> /usr/lib/system/libsystem_platform.dylib
    0x7fff203ff000 -     0x7fff2042afff  libsystem_info.dylib (542.40.3) <36329FC6-9982-306A-87F9-D018E7F49F4B> /usr/lib/system/libsystem_info.dylib
    0x7fff2042b000 -     0x7fff208c9fff  com.apple.CoreFoundation (6.9 - 1778.101) <4A04F6EA-DE8D-3EBB-B9BA-8C90C6F019DD> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff208ca000 -     0x7fff20afffff  com.apple.LaunchServices (1122.45 - 1122.45) <2E70B4AB-38AF-37CC-A45B-ABEE3421A3A0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff20b00000 -     0x7fff20bd4fff  com.apple.gpusw.MetalTools (1.0 - 1) <72B42432-B432-381F-8EA6-F1B829C3EE5D> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff20bd5000 -     0x7fff20d5bfff  libBLAS.dylib (1336.140.1) <2C2F4402-DB7D-3F4C-AB33-2774B4016A17> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff20d5c000 -     0x7fff20da9fff  com.apple.Lexicon-framework (1.0 - 86.2) <FE0BC1AF-D1A0-3A6B-A404-A187AEF07704> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff20daa000 -     0x7fff20e18fff  libSparse.dylib (106) <95043C27-910C-3B53-ADE7-0E7907E579C9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff20e19000 -     0x7fff20e96fff  com.apple.SystemConfiguration (1.20 - 1.20) <AE4BE9DB-6F7D-3D4A-BA51-D86DDFC6B5B2> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff20e97000 -     0x7fff20ecbfff  libCRFSuite.dylib (50) <95816B40-6F71-33EB-9324-E2942543DDD4> /usr/lib/libCRFSuite.dylib
    0x7fff20ecc000 -     0x7fff21104fff  libmecabra.dylib (929.10) <1E492E01-642F-3A9D-8A04-CF648C32696C> /usr/lib/libmecabra.dylib
    0x7fff21105000 -     0x7fff21463fff  com.apple.Foundation (6.9 - 1778.101) <68B22A79-76E0-3BE4-9B53-0F38991C5A08> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff21464000 -     0x7fff2154cfff  com.apple.LanguageModeling (1.0 - 247.3) <D7E3186D-41DD-3826-85C8-D9ECC7D17197> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff2154d000 -     0x7fff21683fff  com.apple.CoreDisplay (237.4 - 237.4) <07520DBC-E1BB-310C-AD92-6F313820D60E> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff21684000 -     0x7fff218f4fff  com.apple.audio.AudioToolboxCore (1.0 - 1181.72.1) <92B2E9B6-7FA8-3BE5-AD1A-25A2BC36821E> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
    0x7fff218f5000 -     0x7fff21adafff  com.apple.CoreText (677.6.0.2 - 677.6.0.2) <4C194C5B-3B53-347A-B558-AF0070B6D27B> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff21adb000 -     0x7fff2216cfff  com.apple.audio.CoreAudio (5.0 - 5.0) <7178815E-1890-3A3D-B0FD-F93EBB529E78> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff2216d000 -     0x7fff224c4fff  com.apple.security (7.0 - 59754.141.1) <7EC1D1C5-672E-3DFD-902C-D511ECE6C110> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff224c5000 -     0x7fff22724fff  libicucore.A.dylib (66112) <251FC896-7EA1-3505-A9AA-80BAE7A6FD2B> /usr/lib/libicucore.A.dylib
    0x7fff22725000 -     0x7fff2272efff  libsystem_darwin.dylib (1439.141.1) <29F82ABE-E1A0-3BC2-B91E-ADC010CF23FA> /usr/lib/system/libsystem_darwin.dylib
    0x7fff2272f000 -     0x7fff22a1afff  com.apple.CoreServices.CarbonCore (1307.3 - 1307.3) <8191DB78-205F-3709-8E42-E257F3AD4459> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff22a5a000 -     0x7fff22a94fff  com.apple.CSStore (1122.45 - 1122.45) <AF990E23-4698-33A2-B1E0-665D4619D6C4> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
    0x7fff22a95000 -     0x7fff22b43fff  com.apple.framework.IOKit (2.0.2 - 1845.120.6) <61CDC69E-EC9E-32B1-8A63-532619BA310F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff22b44000 -     0x7fff22b4ffff  libsystem_notify.dylib (279.40.4) <608B5A07-D31A-3BEC-86BF-C2E498C085AF> /usr/lib/system/libsystem_notify.dylib
    0x7fff22b50000 -     0x7fff22b9dfff  libsandbox.1.dylib (1441.141.4) <3848F6F5-6C83-37D2-A591-4EA4393F0372> /usr/lib/libsandbox.1.dylib
    0x7fff22b9e000 -     0x7fff238e9fff  com.apple.AppKit (6.9 - 2022.60.128) <39481583-0997-3314-B9C2-0854C9B56C0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff238ea000 -     0x7fff23b38fff  com.apple.UIFoundation (1.0 - 728.9) <A7628FB1-C04A-3F24-A14A-DDCD4CE67A00> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff23b39000 -     0x7fff23b4bfff  com.apple.UniformTypeIdentifiers (637 - 637) <5C5C0766-21EC-3C7C-9887-3DF23CBFCB84> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
    0x7fff23b4c000 -     0x7fff23cd6fff  com.apple.desktopservices (1.21 - 1346.6.1) <F2D70A76-BF47-31DC-8337-D4D929DA4A27> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff23cd7000 -     0x7fff23ce9fff  com.apple.metadata.SpotlightLinguistics (1.0 - 1) <21E29156-2D46-3743-8E89-518EE82E083F> /System/Library/PrivateFrameworks/SpotlightLinguistics.framework/Versions/A/SpotlightLinguistics
    0x7fff23cea000 -     0x7fff23ef8fff  com.apple.CoreDuet (1.0 - 1) <EA0886E1-AC18-3A4C-A9BB-0870D2DA3CF0> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
    0x7fff23fb6000 -     0x7fff2463cfff  libnetwork.dylib (2288.140.7) <6D702F3B-34C0-3809-8CEC-1D59D58CF8BB> /usr/lib/libnetwork.dylib
    0x7fff2463d000 -     0x7fff24adbfff  com.apple.CFNetwork (1240.0.4 - 1240.0.4) <5AC97239-B546-33F2-80B0-ACBFD66C0E58> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff24adc000 -     0x7fff24aeafff  libsystem_networkextension.dylib (1295.140.3) <022BE26C-C058-3CC7-8E0B-348B3D3B639C> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff24aeb000 -     0x7fff24aebfff  libenergytrace.dylib (22.100.1) <13CE770E-37DA-35D5-84A7-2F6C07F3B707> /usr/lib/libenergytrace.dylib
    0x7fff24aec000 -     0x7fff24b48fff  libMobileGestalt.dylib (978.140.1) <23C1C24D-9C1B-323A-9B84-42221F9257AC> /usr/lib/libMobileGestalt.dylib
    0x7fff24b49000 -     0x7fff24b5ffff  libsystem_asl.dylib (385) <47B99A49-749E-356F-9D81-6D3A0B1544AB> /usr/lib/system/libsystem_asl.dylib
    0x7fff24b60000 -     0x7fff24b78fff  com.apple.TCC (1.0 - 1) <0C03114C-CBE1-3E8F-945E-CC11F0845978> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff24b79000 -     0x7fff24edefff  com.apple.SkyLight (1.600.0 - 588.8) <338D12B6-9059-3AED-B409-61EA90715BDA> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff24edf000 -     0x7fff25591fff  com.apple.CoreGraphics (2.0 - 1463.18.4.1) <C6A2258D-84FF-3442-B1C3-4B78B0F71645> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff25592000 -     0x7fff25688fff  com.apple.ColorSync (4.13.0 - 3473.5.3) <475BCA90-8D51-3695-AD75-29F5024C4515> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff25689000 -     0x7fff256e4fff  com.apple.HIServices (1.22 - 716) <6118C8D4-70EA-3FD5-A375-0B500896506A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff256e5000 -     0x7fff25723fff  libAWDSupport.dylib (951) <DD7F429A-3750-31AF-A344-776C63EAB960> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
    0x7fff25724000 -     0x7fff25780fff  libprotobuf.dylib (4205) <7B397A12-BA3F-3B18-9669-79FFA52F48AF> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
    0x7fff25781000 -     0x7fff25792fff  libprotobuf-lite.dylib (4205) <659388D5-1B65-3DD9-9ECF-2DE5C4264D31> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
    0x7fff25793000 -     0x7fff257d7fff  com.apple.awd (1.0 - 951) <170D4BE0-FE3D-3EDC-AF7E-BAC00F506733> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
    0x7fff257d8000 -     0x7fff25998fff  com.apple.Montreal (1.0 - 142) <2BA11519-6F86-3EC3-98DB-248C9832B6CE> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
    0x7fff25999000 -     0x7fff25a8afff  com.apple.NLP (1.0 - 210.2) <F9671A0A-467B-385C-BC4A-451DE2309476> /System/Library/PrivateFrameworks/NLP.framework/Versions/A/NLP
    0x7fff25a8b000 -     0x7fff25ebbfff  com.apple.CoreData (120 - 1048) <66C2F919-F7E8-32BB-927B-7C2656D7BFF9> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff25ebc000 -     0x7fff25ed1fff  com.apple.ProtocolBuffer (1 - 285.24.10.20.1) <A2E727C2-659A-3791-8076-2DA387C440F9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff25ed2000 -     0x7fff26080fff  libsqlite3.dylib (321.3) <07A2B3EB-504A-316C-85B3-051F47DD2F73> /usr/lib/libsqlite3.dylib
    0x7fff26081000 -     0x7fff260fdfff  com.apple.Accounts (113 - 113) <A4533970-D42E-3A4E-8244-2ACC60504923> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff260fe000 -     0x7fff26115fff  com.apple.commonutilities (8.0 - 900) <56BAD997-43B7-3AF5-8E99-9F0810619899> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
    0x7fff26116000 -     0x7fff26195fff  com.apple.BaseBoard (526 - 526) <A59E4406-C169-3723-9CC5-396A3ED80F49> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
    0x7fff26196000 -     0x7fff261defff  com.apple.RunningBoardServices (1.0 - 505.100.9) <596F75F9-6D8E-3113-BE54-B4CA556D2770> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
    0x7fff261df000 -     0x7fff26253fff  com.apple.AE (918.6 - 918.6) <2AC07F95-A6EB-3D82-B8AC-D6516E42C60F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff26254000 -     0x7fff2625afff  libdns_services.dylib (1310.140.1) <9D69602C-7ADF-3701-8A4E-F7C7B0A1AC37> /usr/lib/libdns_services.dylib
    0x7fff2625b000 -     0x7fff26262fff  libsystem_symptoms.dylib (1431.140.1) <EA6435E7-8F85-315B-8AED-C20A07DE7F96> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff26263000 -     0x7fff263eefff  com.apple.Network (1.0 - 1) <95AC4C13-4BD4-36AB-B0CE-BFB9B0812930> /System/Library/Frameworks/Network.framework/Versions/A/Network
    0x7fff263ef000 -     0x7fff2641efff  com.apple.analyticsd (1.0 - 1) <13CBC16D-996E-3FCC-B5FA-787896CC6CED> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
    0x7fff2641f000 -     0x7fff26421fff  libDiagnosticMessagesClient.dylib (112) <2FCF6C74-5FAF-3968-AE36-294C9EF3AA75> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff26422000 -     0x7fff2646efff  com.apple.spotlight.metadata.utilities (1.0 - 2150.26) <2775C636-B8B5-3ED3-A8FC-7C2CB8C737A9> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
    0x7fff2646f000 -     0x7fff26509fff  com.apple.Metadata (10.7.0 - 2150.26) <A3A109B8-0C44-3377-A1BA-482D7AC72C0E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff2650a000 -     0x7fff26510fff  com.apple.DiskArbitration (2.7 - 2.7) <C121EA04-ABB5-34B6-80DD-360A75945764> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff26511000 -     0x7fff26e7cfff  com.apple.vImage (8.1 - 544.4) <B929FC15-2D42-3DB3-95E2-5A805B0D0110> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff26e7d000 -     0x7fff2715afff  com.apple.QuartzCore (1.11 - 927.24) <5330EF82-E120-34A4-B9DF-68F4C7C13DCF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff2715b000 -     0x7fff2719cfff  libFontRegistry.dylib (309) <ACF99477-688E-33DA-8100-3191721EB052> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff2719d000 -     0x7fff272ddfff  com.apple.coreui (2.1 - 692.1) <CC1F2421-0338-3912-86BE-A15BFDDF5C00> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff272de000 -     0x7fff273c9fff  com.apple.ViewBridge (553.1 - 553.1) <B5CC51A9-EA5C-3BE2-914C-5672C30A0311> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff273ca000 -     0x7fff273d5fff  com.apple.PerformanceAnalysis (1.278.3 - 278.3) <4460D0DF-74B4-3EDB-9391-733525F1D0C6> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff273d6000 -     0x7fff273e5fff  com.apple.OpenDirectory (11.6 - 230.40.1) <E204DA2B-17DA-3A4B-A03C-8F3B673D5CCD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff273e6000 -     0x7fff27405fff  com.apple.CFOpenDirectory (11.6 - 230.40.1) <9294B2FA-1269-3173-AB57-E80EBD2FE3E1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff27406000 -     0x7fff27412fff  com.apple.CoreServices.FSEvents (1290.120.5 - 1290.120.5) <87C05C54-DD61-3555-8246-F56E535072D2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff27413000 -     0x7fff27437fff  com.apple.coreservices.SharedFileList (144 - 144) <FC634ADE-7F29-3A8D-AEB4-2F5A34685C88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff27438000 -     0x7fff2743afff  libapp_launch_measurement.dylib (14.1) <34296F0E-D81B-383B-8B45-137CA086BC4D> /usr/lib/libapp_launch_measurement.dylib
    0x7fff2743b000 -     0x7fff27482fff  com.apple.CoreAutoLayout (1.0 - 21.10.1) <0AA28C77-F6DE-3B5B-BD3B-6BDCE805B634> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
    0x7fff27483000 -     0x7fff27565fff  libxml2.2.dylib (34.10) <6750E272-224C-3FDD-9A1C-87249E63DA07> /usr/lib/libxml2.2.dylib
    0x7fff27566000 -     0x7fff275b3fff  com.apple.CoreVideo (1.8 - 414.7) <7E4736C8-AB84-3A3A-BB7C-A6A9A36BCE79> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff275b4000 -     0x7fff275b6fff  com.apple.loginsupport (1.0 - 1) <F0181B5E-C653-3769-B7D2-8AEB1210898C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff275b7000 -     0x7fff275defff  com.apple.aps.framework (4.0 - 4.0) <26AA00EA-98DF-397D-A610-A64BB735EB76> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff275df000 -     0x7fff275fafff  com.apple.UserManagement (1.0 - 1) <844C9F98-08E1-36EB-978D-660B4F4FA17E> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
    0x7fff275fb000 -     0x7fff2778cfff  com.apple.cloudkit.CloudKit (990 - 990) <DB51AB84-4B93-383A-B485-FD897CDFC83E> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff2778d000 -     0x7fff2780efff  com.apple.CloudDocs (1.0 - 738.3) <17D4DA33-00D8-39AC-A6A8-E379D7DBB619> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff2780f000 -     0x7fff27b9efff  com.apple.CoreML (1.0 - 1) <60D26BDF-5B31-3780-9BB9-44202D6DB00F> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
    0x7fff27b9f000 -     0x7fff284f0fff  libwebrtc.dylib (7611.3.10.1.6) <47BE79FE-DB6C-36E1-BF7F-53EB467A4B34> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
    0x7fff284f1000 -     0x7fff2856dfff  com.apple.corelocation (2420.19.23 - 2420.19.23) <5CD8DDEE-0438-3A38-8877-10227C5A0A56> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff2856e000 -     0x7fff2857efff  libsystem_containermanager.dylib (318.100.4) <E0A89571-6D3E-3184-9F39-C6094C87B92B> /usr/lib/system/libsystem_containermanager.dylib
    0x7fff2857f000 -     0x7fff28590fff  com.apple.IOSurface (290.8.1 - 290.8.1) <9D6CA654-3E6F-3719-B9B9-65C4CDA41BC5> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff28591000 -     0x7fff2859afff  com.apple.IOAccelerator (442.9 - 442.9) <CF36BA06-85BA-3CCF-B59D-6A92EAB5EABB> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff2859b000 -     0x7fff286befff  com.apple.Metal (244.303 - 244.303) <1A5DBC62-5F40-3407-8BBA-FE2B56CFA993> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff286bf000 -     0x7fff286dbfff  com.apple.audio.caulk (1.0 - 70) <B2CA358A-CC85-3B89-810C-B0209F0EEAEA> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
    0x7fff286dc000 -     0x7fff287c6fff  com.apple.CoreMedia (1.0 - 2780.10.4.1) <FDE1187A-BDBD-3B4E-A200-A3E2E22694B5> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff287c7000 -     0x7fff28923fff  libFontParser.dylib (305.6.0.4) <7A6DF449-3B4B-34FC-9D5C-B00FE59E6031> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
    0x7fff28924000 -     0x7fff28c1ffff  com.apple.HIToolbox (2.1.1 - 1062) <028D8F63-A386-33B9-A797-FF5C82B44C2F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff28c20000 -     0x7fff28c33fff  com.apple.framework.DFRFoundation (1.0 - 267) <236EDA40-6A75-3BFE-9300-F9E4AAD36256> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff28c34000 -     0x7fff28c37fff  com.apple.dt.XCTTargetBootstrap (1.0 - 18119.1) <EAD6AFB0-E0FC-32FE-866B-8D017C12D868> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
    0x7fff28c38000 -     0x7fff28c61fff  com.apple.CoreSVG (1.0 - 149) <01655535-CA23-3F54-A8CE-92423D73CC99> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
    0x7fff28c62000 -     0x7fff28ea2fff  com.apple.ImageIO (3.3.0 - 2130.7.3) <85D4DBE0-4882-370C-966C-8DF37F986E37> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff28ea3000 -     0x7fff2921efff  com.apple.CoreImage (16.3.0 - 1140.2) <E05C48FC-81E3-3270-A37C-D206F364FF62> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff2921f000 -     0x7fff29285fff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <6AE9618A-B8C9-3D0F-A389-71382F438DF8> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff29286000 -     0x7fff29289fff  libsystem_configuration.dylib (1109.140.1) <89E70992-616F-3DD3-9430-67025F759A1B> /usr/lib/system/libsystem_configuration.dylib
    0x7fff2928a000 -     0x7fff2928efff  libsystem_sandbox.dylib (1441.141.4) <087B0ADD-EF39-3E80-800F-F111FD65ABBA> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff2928f000 -     0x7fff29290fff  com.apple.AggregateDictionary (1.0 - 1) <9FD9D68F-7B02-31A6-9583-EFF60B2A9F1C> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
    0x7fff29291000 -     0x7fff29294fff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <0B523600-B02C-359B-BDD7-6EADCE8B5AD8> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff29295000 -     0x7fff29296fff  liblangid.dylib (136) <5645ED02-635B-3BA0-ACEF-D6C8BC74FAF0> /usr/lib/liblangid.dylib
    0x7fff29297000 -     0x7fff2933bfff  com.apple.CoreNLP (1.0 - 245.2) <24291100-1C4C-361B-B53B-B99CB4B53906> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fff2933c000 -     0x7fff29342fff  com.apple.LinguisticData (1.0 - 399) <55FF3554-9E14-3351-8E3C-3280C9CB664B> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff29343000 -     0x7fff2993efff  libBNNS.dylib (288.100.5) <CF9C3646-9299-3DF7-A75B-9BD26A484201> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff2993f000 -     0x7fff29accfff  libvDSP.dylib (760.100.3) <7704318F-6565-3188-8C5D-31C290F68685> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff29acd000 -     0x7fff29adefff  com.apple.CoreEmoji (1.0 - 128.4) <37352743-CFF8-3196-8234-6AF30E531759> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff29adf000 -     0x7fff29ae9fff  com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <A6497A63-1658-3652-91ED-D3AF0EFAFABD> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
    0x7fff29aea000 -     0x7fff29bbcfff  com.apple.framework.CoreWLAN (16.0 - 1657) <5887F6C3-D272-3B6C-8CC8-262701FD9862> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff29bbd000 -     0x7fff29dbefff  com.apple.CoreUtils (6.6 - 660.37) <CC8A07A0-797C-3943-BEFF-A9E3466A0B7C> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff29dbf000 -     0x7fff29de1fff  com.apple.MobileKeyBag (2.0 - 1.0) <70A80CF0-3682-32A6-AB83-8647FD8B2E52> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff29de2000 -     0x7fff29df2fff  com.apple.AssertionServices (1.0 - 505.100.9) <968E021C-1BCD-3249-BBAD-FEE64370EB1F> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
    0x7fff29df3000 -     0x7fff29e7efff  com.apple.securityfoundation (6.0 - 55240.40.4) <DB010D41-F904-3592-9301-BB75A0FA2FD4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff29e7f000 -     0x7fff29e88fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <B222BEB6-CE24-3D70-903B-A9034D6FC6F6> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff29e89000 -     0x7fff29e8dfff  com.apple.xpc.ServiceManagement (1.0 - 1) <E1167FFF-E757-3C96-B26A-C0CE98EAA899> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff29e8e000 -     0x7fff29e90fff  libquarantine.dylib (119.40.2) <B1418CB0-CDC7-3EB2-ABC3-8609ADC92BC4> /usr/lib/system/libquarantine.dylib
    0x7fff29e91000 -     0x7fff29e9cfff  libCheckFix.dylib (31) <AA2CA9EF-88C2-3DB6-89E4-7E946131788D> /usr/lib/libCheckFix.dylib
    0x7fff29e9d000 -     0x7fff29eb4fff  libcoretls.dylib (169.100.1) <972397D6-A93B-302D-9CA3-C8B12C93899B> /usr/lib/libcoretls.dylib
    0x7fff29eb5000 -     0x7fff29ec5fff  libbsm.0.dylib (68.40.1) <FEA138A5-B03E-3AD5-9E21-3F35405D147F> /usr/lib/libbsm.0.dylib
    0x7fff29ec6000 -     0x7fff29f0ffff  libmecab.dylib (929.10) <E391699C-D139-338C-8919-1B2817BC1E25> /usr/lib/libmecab.dylib
    0x7fff29f10000 -     0x7fff29f15fff  libgermantok.dylib (24) <3DF990AD-8806-36B2-8168-4F18762C74A4> /usr/lib/libgermantok.dylib
    0x7fff29f16000 -     0x7fff29f2bfff  libLinearAlgebra.dylib (1336.140.1) <6CE0B7EF-EC7A-34A1-B590-A05851FE42D9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff29f2c000 -     0x7fff2a14afff  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <5B727E28-3ACF-3DBB-B787-B1633CFB2413> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff2a14b000 -     0x7fff2a19afff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <315027A8-ADFD-3DC7-9B2A-6F1457E4D32E> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
    0x7fff2a19b000 -     0x7fff2a2fcfff  com.apple.MLCompute (1.0 - 1) <E0A748E2-21DA-319C-8B28-80A853090B86> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
    0x7fff2a2fd000 -     0x7fff2a333fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <5D3C245B-BF53-31B0-B405-E4EB0FA608ED> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff2a334000 -     0x7fff2a38afff  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <C251786D-BC17-3C99-94E7-10EC828139D4> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
    0x7fff2a38b000 -     0x7fff2a41bfff  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <AAE88278-E296-3976-9FCC-345F71C8005D> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff2a41c000 -     0x7fff2a42bfff  com.apple.AppleFSCompression (125 - 1.0) <EAA1DBD4-02EE-3E39-A9F8-C40AA535C32A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff2a42c000 -     0x7fff2a438fff  libbz2.1.0.dylib (44) <90425CDA-B4E1-3004-800B-7E4A87DCBCD2> /usr/lib/libbz2.1.0.dylib
    0x7fff2a439000 -     0x7fff2a43dfff  libsystem_coreservices.dylib (127.1) <7AE405FC-6A44-34A0-86AD-6BD80B0050BB> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff2a43e000 -     0x7fff2a46bfff  com.apple.CoreServices.OSServices (1122.45 - 1122.45) <8D3DFB6A-1621-38D0-BA1C-A972C343D839> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff2a46c000 -     0x7fff2a59bfff  com.apple.AuthKit (1.0 - 1) <BE5EBFF1-F354-3F16-9B16-B30B6867ED3E> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
    0x7fff2a59c000 -     0x7fff2a5cafff  com.apple.UserNotifications (1.0 - 348.5) <F6D81ADE-EDF8-39FA-995A-4249DDC7E696> /System/Library/Frameworks/UserNotifications.framework/Versions/A/UserNotifications
    0x7fff2a5cb000 -     0x7fff2a639fff  com.apple.CoreSpotlight (1.0 - 2150.26) <A6A2E008-5AD4-3A09-AB41-98284756E61B> /System/Library/Frameworks/CoreSpotlight.framework/Versions/A/CoreSpotlight
    0x7fff2a63a000 -     0x7fff2a64cfff  libz.1.dylib (76) <73C471D3-07CE-307D-A531-92C5D0E4C0E9> /usr/lib/libz.1.dylib
    0x7fff2a64d000 -     0x7fff2a698fff  libsystem_m.dylib (3186.100.3) <10F86B94-7CEE-35AB-86DC-E91032378BC7> /usr/lib/system/libsystem_m.dylib
    0x7fff2a699000 -     0x7fff2a699fff  libcharset.1.dylib (59) <E389024B-7CAC-32A5-BF12-DF20C8A3B050> /usr/lib/libcharset.1.dylib
    0x7fff2a69a000 -     0x7fff2a69ffff  libmacho.dylib (980) <1FCE2BE3-4F6F-3EAA-9BC5-A9892A45CF0D> /usr/lib/system/libmacho.dylib
    0x7fff2a6a0000 -     0x7fff2a6bbfff  libkxld.dylib (7195.141.8) <A4FF718B-9B75-339A-BDDF-987C38610870> /usr/lib/system/libkxld.dylib
    0x7fff2a6bc000 -     0x7fff2a6c7fff  libcommonCrypto.dylib (60178.120.3) <7E242F29-1CB6-30EF-8C9A-C768A90FDBA0> /usr/lib/system/libcommonCrypto.dylib
    0x7fff2a6c8000 -     0x7fff2a6d2fff  libunwind.dylib (201) <A5B040A8-847F-36EE-B13D-5DD1F5CD5BED> /usr/lib/system/libunwind.dylib
    0x7fff2a6d3000 -     0x7fff2a6dafff  liboah.dylib (203.58) <26D08622-69F5-32DB-80D2-9B4651A9F0CC> /usr/lib/liboah.dylib
    0x7fff2a6db000 -     0x7fff2a6e5fff  libcopyfile.dylib (173.40.2) <8C783785-0F5F-3DC5-B815-B29CEBA75737> /usr/lib/system/libcopyfile.dylib
    0x7fff2a6e6000 -     0x7fff2a6edfff  libcompiler_rt.dylib (102.2) <1FDC92D1-8A17-30AF-8E72-4F0517AEA157> /usr/lib/system/libcompiler_rt.dylib
    0x7fff2a6ee000 -     0x7fff2a6f0fff  libsystem_collections.dylib (1439.141.1) <11D5775A-AD4C-35ED-BC05-616AB67ACBBE> /usr/lib/system/libsystem_collections.dylib
    0x7fff2a6f1000 -     0x7fff2a6f3fff  libsystem_secinit.dylib (87.60.1) <27982311-637E-3308-9F55-4871762736F4> /usr/lib/system/libsystem_secinit.dylib
    0x7fff2a6f4000 -     0x7fff2a6f6fff  libremovefile.dylib (49.120.1) <5973CED7-797B-3288-9589-C1856752F91A> /usr/lib/system/libremovefile.dylib
    0x7fff2a6f7000 -     0x7fff2a6f7fff  libkeymgr.dylib (31) <AAA929A0-45E5-3186-8ABD-37EB25B2C939> /usr/lib/system/libkeymgr.dylib
    0x7fff2a6f8000 -     0x7fff2a6fffff  libsystem_dnssd.dylib (1310.140.1) <4A85F13B-E3AD-3C44-B327-091F56D35CC1> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff2a700000 -     0x7fff2a705fff  libcache.dylib (83) <435668CB-666B-3379-AD65-F604A72099F4> /usr/lib/system/libcache.dylib
    0x7fff2a706000 -     0x7fff2a707fff  libSystem.B.dylib (1292.120.1) <2553EE0F-3C42-3ACE-9400-EF055BD5BE8E> /usr/lib/libSystem.B.dylib
    0x7fff2a708000 -     0x7fff2a70bfff  libfakelink.dylib (3) <C7E36B51-4FD6-3704-975E-AB9B46DF6D30> /usr/lib/libfakelink.dylib
    0x7fff2a70c000 -     0x7fff2a70cfff  com.apple.SoftLinking (1.0 - 1) <AF16BDE9-8995-39F5-A0ED-C65232A61095> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
    0x7fff2a70d000 -     0x7fff2a744fff  libpcap.A.dylib (98.100.3) <7EB940E4-BB5E-327D-B7F8-951F22F27D72> /usr/lib/libpcap.A.dylib
    0x7fff2a745000 -     0x7fff2a835fff  libiconv.2.dylib (59) <1F132286-CEA4-37A4-93F7-3C0A60C3645B> /usr/lib/libiconv.2.dylib
    0x7fff2a836000 -     0x7fff2a847fff  libcmph.dylib (8) <8A5DF97C-1CDA-36BC-86E8-EF8B7F314EDC> /usr/lib/libcmph.dylib
    0x7fff2a848000 -     0x7fff2a8b9fff  libarchive.2.dylib (83.100.2) <BAF76083-029C-3AC5-96E5-AE54786574A6> /usr/lib/libarchive.2.dylib
    0x7fff2a8ba000 -     0x7fff2a921fff  com.apple.SearchKit (1.4.1 - 1.4.1) <7B3B1E70-2C63-30E2-B5CF-6BC8EE7EA418> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff2a922000 -     0x7fff2a923fff  libThaiTokenizer.dylib (3) <84E7B443-74C5-386F-AEFF-FD48B94A04EB> /usr/lib/libThaiTokenizer.dylib
    0x7fff2a924000 -     0x7fff2a946fff  com.apple.applesauce (1.0 - 16.28) <0F9016E9-9DBB-3047-A1C3-A9FC85BAFE20> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff2a947000 -     0x7fff2a95efff  libapple_nghttp2.dylib (1.41) <B730D1A0-8F61-3497-B63A-5661EB887E73> /usr/lib/libapple_nghttp2.dylib
    0x7fff2a95f000 -     0x7fff2a971fff  libSparseBLAS.dylib (1336.140.1) <D18578FF-C9A9-38EF-86D9-18C0D4FFCE5E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff2a972000 -     0x7fff2a973fff  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <295CF572-CFF5-3C5D-8006-F63988CFB5B7> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff2a974000 -     0x7fff2a978fff  libpam.2.dylib (28.40.1) <B2457D3D-DADD-3157-8BFD-CF76F982FC13> /usr/lib/libpam.2.dylib
    0x7fff2a979000 -     0x7fff2a999fff  libcompression.dylib (96.120.1) <FAAB6617-1DDB-3B53-9290-8ACDEFF1510B> /usr/lib/libcompression.dylib
    0x7fff2a99a000 -     0x7fff2a99ffff  libQuadrature.dylib (7) <EA417A8F-8395-32AC-A67A-FA75DC2110CB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff2a9a0000 -     0x7fff2ad44fff  libLAPACK.dylib (1336.140.1) <EF9A0E29-BFF1-3A1A-A19E-4361F085EB13> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff2ad45000 -     0x7fff2ad94fff  com.apple.DictionaryServices (1.2 - 341) <960CC0D7-B2C6-3308-A120-C86F41A2301C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff2ad95000 -     0x7fff2adadfff  liblzma.5.dylib (16) <933D5DEC-E8E8-3946-A16E-1056F2075602> /usr/lib/liblzma.5.dylib
    0x7fff2adae000 -     0x7fff2adaffff  libcoretls_cfhelpers.dylib (169.100.1) <E2AC5901-93EC-3F67-A8B1-738E76B49804> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff2adb0000 -     0x7fff2aeabfff  com.apple.APFS (1677.141.2 - 1677.141.2) <C4CDA06B-22D5-35A4-BA73-856DC272FAB5> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff2aeac000 -     0x7fff2aeb9fff  libxar.1.dylib (452.0.4) <F45E7073-9E81-30DE-9DCB-FABA46E5DBBC> /usr/lib/libxar.1.dylib
    0x7fff2aeba000 -     0x7fff2aebdfff  libutil.dylib (58.40.2) <AE460378-5737-3BD8-90D9-E4E7603C4002> /usr/lib/libutil.dylib
    0x7fff2aebe000 -     0x7fff2aee6fff  libxslt.1.dylib (17.6) <BFB2EA40-332D-3DB4-AA3E-025966219E88> /usr/lib/libxslt.1.dylib
    0x7fff2aee7000 -     0x7fff2aef1fff  libChineseTokenizer.dylib (37.1) <344E5492-4BD5-354A-8274-047F8388A826> /usr/lib/libChineseTokenizer.dylib
    0x7fff2aef2000 -     0x7fff2b068fff  libvMisc.dylib (760.100.3) <135DB3B5-6CCC-3FD4-992B-98B2B766D151> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff2b069000 -     0x7fff2b19afff  libate.dylib (3.0.6) <AD713B5B-0048-3127-9D03-C6B6AA4337DF> /usr/lib/libate.dylib
    0x7fff2b19b000 -     0x7fff2b1a2fff  libIOReport.dylib (64.100.1) <4690B952-7BCF-31DB-A796-996D8094AB24> /usr/lib/libIOReport.dylib
    0x7fff2b1a3000 -     0x7fff2b1b6fff  com.apple.CrashReporterSupport (10.13 - 15053.1) <4DF43384-1E50-3AB8-9DA7-5C328381A847> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff2b1ce000 -     0x7fff2b24bfff  com.apple.CVNLP (1.0 - 119) <2800BA19-1061-3032-8C0D-0E8FC72274C5> /System/Library/PrivateFrameworks/CVNLP.framework/Versions/A/CVNLP
    0x7fff2b26d000 -     0x7fff2b2a3fff  com.apple.pluginkit.framework (1.0 - 1) <545963FE-A289-3F66-B6EA-9122340016DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
    0x7fff2b2a4000 -     0x7fff2b2abfff  libMatch.1.dylib (38) <E1296A96-E533-39A6-A519-05A0AE78181E> /usr/lib/libMatch.1.dylib
    0x7fff2b2ac000 -     0x7fff2b337fff  libCoreStorage.dylib (554.140.2) <AEE8AC91-7058-3275-90D4-B0217A41BED6> /usr/lib/libCoreStorage.dylib
    0x7fff2b338000 -     0x7fff2b38bfff  com.apple.AppleVAFramework (6.1.3 - 6.1.3) <DC3B87A5-AA7D-3534-BF4F-089E16226C0D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff2b38c000 -     0x7fff2b3a5fff  libexpat.1.dylib (26.141.1) <F579645F-A493-3F2D-A9DB-C77664A1BCA1> /usr/lib/libexpat.1.dylib
    0x7fff2b3a6000 -     0x7fff2b3affff  libheimdal-asn1.dylib (597.140.2) <D59F68F4-A2E2-3F98-8167-DD5DDDAB568B> /usr/lib/libheimdal-asn1.dylib
    0x7fff2b3b0000 -     0x7fff2b3c4fff  com.apple.IconFoundation (479.4 - 479.4) <6B77361F-69AF-393F-97B8-9BDED38304B0> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
    0x7fff2b3c5000 -     0x7fff2b431fff  com.apple.IconServices (479.4 - 479.4) <727B7BC3-AC02-31F7-9149-0014FDBCF17B> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff2b432000 -     0x7fff2b4d0fff  com.apple.MediaExperience (1.0 - 1) <B71F329D-70E3-34A8-A789-82D7ACA63C34> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
    0x7fff2b4d1000 -     0x7fff2b4f9fff  com.apple.persistentconnection (1.0 - 1.0) <E05B6AF9-376E-3E4D-B2F5-3A7A85D7CBB3> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
    0x7fff2b4fa000 -     0x7fff2b508fff  com.apple.GraphVisualizer (1.0 - 100.1) <09C716AC-B62A-3EF0-85A1-98A949EB88B3> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff2b509000 -     0x7fff2b924fff  com.apple.vision.FaceCore (4.3.2 - 4.3.2) <0E25BE9A-551C-3457-B7E8-7ED414223E3A> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff2b925000 -     0x7fff2b96cfff  com.apple.OTSVG (1.0 - 677.6.0.2) <53E2913D-E023-3685-9161-A14608F89DC1> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
    0x7fff2b96d000 -     0x7fff2b973fff  com.apple.xpc.AppServerSupport (1.0 - 2038.120.1) <523B9C03-A39E-3FF4-8216-34309C158113> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
    0x7fff2b974000 -     0x7fff2b986fff  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <53477D30-E8A6-3935-A3B1-7CBDE387210A> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
    0x7fff2b987000 -     0x7fff2b989fff  libspindump.dylib (295.2) <003C7E84-C242-311A-A2FA-4622B66E3F24> /usr/lib/libspindump.dylib
    0x7fff2b98a000 -     0x7fff2ba4afff  com.apple.Heimdal (4.0 - 2.0) <22D8BF25-5FD0-3EE3-A547-B3F55FC09330> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff2ba4b000 -     0x7fff2ba65fff  com.apple.login (3.0 - 3.0) <6A0F479C-875F-3280-A99F-4424C3ED9448> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
    0x7fff2ba66000 -     0x7fff2bb3dfff  com.apple.corebrightness (1.0 - 1) <D9088C56-2629-305D-B664-479950849BE1> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
    0x7fff2bbea000 -     0x7fff2bc26fff  com.apple.bom (14.0 - 235) <8C9005F1-FC51-3CF3-9CAC-264C1D8031F7> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff2bc27000 -     0x7fff2bc70fff  com.apple.AppleJPEG (1.0 - 1) <D751A39A-DC50-3E2E-9C2D-70284574EC84> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff2bc71000 -     0x7fff2bd4ffff  libJP2.dylib (2130.7.3) <8D977418-51A1-3935-80BB-3E9B70FA64DF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff2bd50000 -     0x7fff2bd53fff  com.apple.WatchdogClient.framework (1.0 - 98.120.2) <13BB2B82-DF17-33C3-A19B-432E03744896> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
    0x7fff2bd54000 -     0x7fff2bd8afff  com.apple.MultitouchSupport.framework (4440.3 - 4440.3) <8B7FB5F9-E38B-3193-98AC-51EF565F61CB> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff2bd8b000 -     0x7fff2bee9fff  com.apple.VideoToolbox (1.0 - 2780.10.4.1) <1134D8C6-EA97-32B4-BD4C-DD02901F4B0B> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff2beea000 -     0x7fff2bf1dfff  libAudioToolboxUtility.dylib (1181.72.1) <3043E7BD-6B6A-39EA-B482-4BDB39E1DF85> /usr/lib/libAudioToolboxUtility.dylib
    0x7fff2bf1e000 -     0x7fff2bf3efff  libPng.dylib (2130.7.3) <BB3D23A8-ABE2-3F19-B48E-C13E88F4D46B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff2bf3f000 -     0x7fff2bf9efff  libTIFF.dylib (2130.7.3) <224A082C-2A78-3E08-B433-79AEE6500E04> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff2bf9f000 -     0x7fff2bfbbfff  com.apple.IOPresentment (58 - 37) <990B304C-15B6-397D-8B7E-636DA14AE1D3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff2bfbc000 -     0x7fff2bfc3fff  com.apple.GPUWrangler (6.3.5 - 6.3.5) <E07D5D60-104E-3141-90CC-F81074D95E0D> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
    0x7fff2bfc4000 -     0x7fff2bfc6fff  libRadiance.dylib (2130.7.3) <311E41C5-E8AA-38DF-AAF7-706E5AEC1DC8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff2bfc7000 -     0x7fff2bfccfff  com.apple.DSExternalDisplay (3.1 - 380) <DCD6682A-9C61-3779-A81D-8E1FBED38C69> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff2bfcd000 -     0x7fff2bff1fff  libJPEG.dylib (2130.7.3) <D3C4DD82-71F8-3DAA-AABA-93D6F1FFF485> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff2bff2000 -     0x7fff2c021fff  com.apple.ATSUI (1.0 - 1) <92428504-C766-3ACE-BC36-89F1A5CAB61C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
    0x7fff2c022000 -     0x7fff2c026fff  libGIF.dylib (2130.7.3) <30DDD320-77E2-3A77-A741-A0545B34149B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff2c027000 -     0x7fff2c030fff  com.apple.CMCaptureCore (1.0 - 82.6) <C1960208-BCA3-3D47-9DBE-CF1A81C2053B> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
    0x7fff2c031000 -     0x7fff2c078fff  com.apple.print.framework.PrintCore (16.1 - 531.1) <8139D1A2-7037-3B4F-AB8F-2BF38D64D798> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff2c079000 -     0x7fff2c146fff  com.apple.TextureIO (3.10.9 - 3.10.9) <0E29AC8D-246E-3F7F-A8A0-10E09DD64603> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff2c147000 -     0x7fff2c14ffff  com.apple.InternationalSupport (1.0 - 61.1) <8E0C26AC-7462-34B5-B608-0DB611CCB687> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
    0x7fff2c150000 -     0x7fff2c1cafff  com.apple.datadetectorscore (8.0 - 674) <3E182298-355E-337F-A398-B266DEC5E6F3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff2c1cb000 -     0x7fff2c228fff  com.apple.UserActivity (439 - 439) <E011EB02-BB18-3154-8010-AD4C6D21792B> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
    0x7fff2c229000 -     0x7fff2c9c5fff  com.apple.MediaToolbox (1.0 - 2780.10.4.1) <A90F330D-ACB5-30FC-9F25-CA12F6D8DE3C> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff2ca2f000 -     0x7fff2ce05fff  libswiftCore.dylib (5.4 - 1205.0.24.15) <B074D36E-07D2-37D0-A8FC-E23C030B9D8E> /usr/lib/swift/libswiftCore.dylib
    0x7fff2ce06000 -     0x7fff2ce6cfff  com.apple.imfoundation (10.0 - 1000) <32F0B225-1249-3EAF-9F71-5D2D11F7778B> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
    0x7fff2ce6d000 -     0x7fff2ce95fff  com.apple.locationsupport (2420.19.23 - 2420.19.23) <0CED90D1-F2D8-34B3-8501-236B0EAA8C7F> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
    0x7fff2ce96000 -     0x7fff2cec7fff  libSessionUtility.dylib (76.69) <E6D8E0BB-3C76-343B-B8EA-03C411971A6C> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
    0x7fff2cec8000 -     0x7fff2cffcfff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <7C7D69A5-6686-3040-88F4-87B892B96C0D> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff2cffd000 -     0x7fff2d062fff  com.apple.audio.AudioSession (1.0 - 76.69) <3E7FD009-AC1B-398E-A5BE-D892725A73C7> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
    0x7fff2d063000 -     0x7fff2d075fff  libAudioStatistics.dylib (27.64) <2072394F-C2D4-3EBE-8259-CEBBC87DB2C7> /usr/lib/libAudioStatistics.dylib
    0x7fff2d076000 -     0x7fff2d085fff  com.apple.speech.synthesis.framework (9.0.66 - 9.0.66) <3FADC203-0E7D-3208-9BF7-CD8AE1B9D204> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff2d086000 -     0x7fff2d0f2fff  com.apple.ApplicationServices.ATS (377 - 516) <79E67A4C-DAED-3E60-AF13-23BF0C11A3CA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff2d0f3000 -     0x7fff2d10bfff  libresolv.9.dylib (68) <E2B9E465-C557-3CEA-85F9-4DAF5D550503> /usr/lib/libresolv.9.dylib
    0x7fff2d18c000 -     0x7fff2d1bffff  com.apple.securityinterface (10.0 - 55149.120.1) <F804A124-CA96-3542-9037-30B9F1ED462E> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fff2d1d9000 -     0x7fff2d23dfff  com.apple.CoreMediaIO (1000.0 - 5325) <4139F0CF-51D7-3742-80CB-ED04E249D254> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fff2d23e000 -     0x7fff2d31dfff  libSMC.dylib (20) <B45BD314-B645-3948-B1C2-1FDA40453078> /usr/lib/libSMC.dylib
    0x7fff2d31e000 -     0x7fff2d37dfff  libcups.2.dylib (494.3) <353033B4-E6E6-375A-8BC7-0EE2F67FC8C3> /usr/lib/libcups.2.dylib
    0x7fff2d37e000 -     0x7fff2d38dfff  com.apple.LangAnalysis (1.7.0 - 254) <EE21E044-0B25-3D3E-A892-A276452D8EC8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff2d38e000 -     0x7fff2d398fff  com.apple.NetAuth (6.2 - 6.2) <08F7BAF1-D834-3FAF-9FCC-7FBC32BAF037> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff2d399000 -     0x7fff2d3a0fff  com.apple.ColorSyncLegacy (4.13.0 - 1) <67ED2EE7-B12F-301E-B164-059F452084DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff2d3a1000 -     0x7fff2d3acfff  com.apple.QD (4.0 - 416) <41CBD1BE-1975-3983-B4E0-32E511997BB5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff2d3ad000 -     0x7fff2da01fff  com.apple.audio.AudioResourceArbitration (1.0 - 1) <882F280D-B129-3299-B098-D1E59B78841A> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
    0x7fff2da02000 -     0x7fff2da0dfff  com.apple.perfdata (1.0 - 67.40.1) <B80E66C3-5A5F-391A-9475-15DB16BA72E8> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
    0x7fff2da0e000 -     0x7fff2da1cfff  libperfcheck.dylib (41) <A9A6BE18-57EA-35F6-96BC-D71C49013A09> /usr/lib/libperfcheck.dylib
    0x7fff2da1d000 -     0x7fff2da2cfff  com.apple.Kerberos (3.0 - 1) <06AAAB8C-AA8B-344E-A3F3-4CEDF0AF8C78> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff2da2d000 -     0x7fff2da7dfff  com.apple.GSS (4.0 - 2.0) <604B241D-5B83-3F6C-85D3-F3AB29C950D8> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff2da7e000 -     0x7fff2da8efff  com.apple.CommonAuth (4.0 - 2.0) <90C46CDE-4DD0-338C-9609-68F4BCDD3F03> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff2da8f000 -     0x7fff2dab6fff  com.apple.MobileAssets (1.0 - 659.100.21) <5516BEA4-1FAC-353E-8195-23EEFFA08AB7> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
    0x7fff2dab7000 -     0x7fff2dae3fff  com.apple.CacheDelete (1.0 - 1) <DB62C46F-B802-3F37-9B1D-94D5631A8080> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
    0x7fff2dae4000 -     0x7fff2db03fff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <92FFAD21-9FA8-3194-8764-946F3D8F429E> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
    0x7fff2db04000 -     0x7fff2db0cfff  com.apple.CorePhoneNumbers (1.0 - 1) <A667EA02-1F06-36D7-8290-0B6CD36F89BC> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff2db0d000 -     0x7fff2db96fff  libTelephonyUtilDynamic.dylib (5359.1) <77A0F846-3480-31C8-9373-80A8D0056B54> /usr/lib/libTelephonyUtilDynamic.dylib
    0x7fff2dc5f000 -     0x7fff2dc5ffff  liblaunch.dylib (2038.120.1) <A3F46CC6-BD89-39DB-8732-C885B881A635> /usr/lib/system/liblaunch.dylib
    0x7fff2df58000 -     0x7fff2e1e3fff  com.apple.NetworkExtension (1.0 - 1) <D5C908CF-8818-37F7-970E-B507A3466C47> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
    0x7fff2e1e4000 -     0x7fff2e2e5fff  com.apple.ids (10.0 - 1000) <24E1ADD5-184F-352E-8C97-D9B62974F29E> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
    0x7fff2e2e6000 -     0x7fff2e440fff  com.apple.idsfoundation (10.0 - 1000) <80BAA3A4-590A-335C-81C3-13BE067F9E62> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
    0x7fff2e441000 -     0x7fff2e58cfff  com.apple.Sharing (1630 - 1630) <76D1A200-27A3-3B3E-8B30-4026ABD24217> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff2e58d000 -     0x7fff2e6aefff  com.apple.Bluetooth (8.0.5 - 8.0.5d7) <2197F126-63A6-39DE-B3AB-6DD8B1F79398> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff2e6af000 -     0x7fff2e6c3fff  com.apple.AppContainer (4.0 - 509.140.3) <74319AC9-E412-3C61-8C9E-458E433542FD> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff2e6c4000 -     0x7fff2e6c7fff  com.apple.SecCodeWrapper (4.0 - 509.140.3) <FB661B58-5C98-37A2-937D-6CF8F4B34F65> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff2e6c8000 -     0x7fff2e721fff  com.apple.ProtectedCloudStorage (1.0 - 1) <4BCCB350-CAA2-3217-8AE6-6A6B25755D9F> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff2e722000 -     0x7fff2e781fff  com.apple.QuickLookFramework (5.0 - 928.5) <F2695014-0FAE-389B-8099-5933BC9CF6B6> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff2e782000 -     0x7fff2e79dfff  com.apple.MetalKit (147.1 - 147.1) <53DEED6A-862C-3ADA-8146-071DDD34DBFD> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
    0x7fff2e886000 -     0x7fff2e980fff  com.apple.combine (1.0 - 252.158) <9EE8B2DA-E5DC-3E18-8B2A-D87BAB666328> /System/Library/Frameworks/Combine.framework/Versions/A/Combine
    0x7fff2e981000 -     0x7fff2fe7cfff  com.apple.GeoServices (1.0 - 1757.26.6.2.2) <6DA1AB95-612F-3B54-B5FC-C817C9FF609F> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff2fe89000 -     0x7fff2feb0fff  com.apple.RemoteViewServices (2.0 - 163) <5A16528F-4822-3B0C-BB89-A79459F3AF87> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff2feb1000 -     0x7fff2fec0fff  com.apple.SpeechRecognitionCore (6.1.25 - 6.1.25) <80F52037-912C-335F-B1DA-22AFD73DBDA2> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff2fec1000 -     0x7fff2fec8fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <00007833-3C2A-3F10-97ED-838FB606B5FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff2fec9000 -     0x7fff2fed9fff  com.apple.AppleLDAP (11.6 - 54) <2D4D19D0-2849-3BFB-9152-A47776F46D0B> /System/Library/PrivateFrameworks/AppleLDAP.framework/Versions/A/AppleLDAP
    0x7fff300f6000 -     0x7fff300f6fff  libsystem_product_info_filter.dylib (8.40.1) <6CA8DEA4-5BD4-375F-9AA7-3338135306C5> /usr/lib/system/libsystem_product_info_filter.dylib
    0x7fff3016e000 -     0x7fff30185fff  libnetworkextension.dylib (1295.140.3) <8B28ADBC-CF77-3F16-911D-8F5A2391BA3F> /usr/lib/libnetworkextension.dylib
    0x7fff301ce000 -     0x7fff301cefff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <AB0631EC-4898-3FA1-8A55-769D815EC2E2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff301f4000 -     0x7fff301f4fff  com.apple.CoreServices (1122.45 - 1122.45) <0B568FBF-B224-3C1C-8602-8124A23112CB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff303b0000 -     0x7fff303b0fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <1C9D7B74-C680-3548-B16F-2841666146FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff303d1000 -     0x7fff303f0fff  com.apple.AssetCacheServices (118 - 118) <D084499C-BD9C-3394-AC1D-FF727CDEF4EC> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fff303f1000 -     0x7fff303fcfff  com.apple.MediaAccessibility (1.0 - 130) <9F936D44-8663-3C49-9B14-3D906CEC361C> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff303fd000 -     0x7fff3041cfff  com.apple.networking.AlgosScoreFramework (1.0 - 1) <D0286FFC-1658-30C0-A2C6-FBE9C94331EB> /System/Library/PrivateFrameworks/AlgosScoreFramework.framework/Versions/A/AlgosScoreFramework
    0x7fff3041d000 -     0x7fff30421fff  com.apple.AppleSRP (5.0 - 1) <DA2F374E-D025-3E62-B688-8D2772B23FC0> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff30422000 -     0x7fff3042dfff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <657A98E1-0365-3F99-9B79-8091C19A4BAD> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff30466000 -     0x7fff3073efff  com.apple.VN (4.3.1 - 4.3.1) <2AE1121C-E1C4-3C62-A3E1-DE8238C6B8DD> /System/Library/Frameworks/Vision.framework/Versions/A/Vision
    0x7fff3073f000 -     0x7fff30897fff  libswiftFoundation.dylib (25.103) <7F1F4968-2556-35BC-8D73-77EAED71F95A> /usr/lib/swift/libswiftFoundation.dylib
    0x7fff30898000 -     0x7fff3091bfff  com.apple.AddressBook.ContactsFoundation (8.0 - 1151.2) <E42749F4-6E8E-3A97-9280-3D5B1958E7F0> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
    0x7fff3091c000 -     0x7fff3095efff  com.apple.contacts.ContactsPersistence (1.0 - 3497.5) <EAFD2B43-01FD-3710-A889-2AC289363549> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
    0x7fff3095f000 -     0x7fff30a95fff  com.apple.AddressBook.core (1.0 - 2452.7) <E521C2AB-2931-31ED-ACF4-C2D79A47BB4D> /System/Library/PrivateFrameworks/AddressBookCore.framework/Versions/A/AddressBookCore
    0x7fff30a96000 -     0x7fff30bcafff  com.apple.contacts (1.0 - 3497.5) <5750DD98-BDB6-3244-909B-C7EE313F547C> /System/Library/Frameworks/Contacts.framework/Versions/A/Contacts
    0x7fff30bcb000 -     0x7fff30bd8fff  com.apple.PersonaKit (1.0 - 1) <1E50BB74-27F9-377B-AE20-5EE3976A4A44> /System/Library/PrivateFrameworks/PersonaKit.framework/Versions/A/PersonaKit
    0x7fff30bf2000 -     0x7fff30c57fff  com.apple.CoreBluetooth (1.0 - 1) <3045519A-D711-3CD1-9E87-D7581A430423> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff30c58000 -     0x7fff30c61fff  com.apple.SymptomDiagnosticReporter (1.0 - 79.120.1) <22A34196-22AD-3021-88CD-CC9A7C0AF006> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
    0x7fff30c62000 -     0x7fff30c74fff  com.apple.PowerLog (1.0 - 1) <134B88CE-59B5-3B92-91E0-A3079C8B3952> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
    0x7fff30c75000 -     0x7fff30c81fff  com.apple.AppleIDAuthSupport (1.0 - 1) <B80B4F16-3756-303D-A349-3486A08B2216> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
    0x7fff30c82000 -     0x7fff30d2afff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <647A8433-AFF3-3F20-A07E-3471F427DA80> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff30d2b000 -     0x7fff30d5efff  com.apple.MediaKit (16 - 927.40.2) <88268EAB-5430-3BCB-9263-E3B4BCC34609> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff30d5f000 -     0x7fff30e4afff  com.apple.DiskManagement (14.0 - 1733.140.2) <4BF7BFA4-4950-3582-B43B-25A4B6A3E7B7> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
    0x7fff30e4b000 -     0x7fff31205fff  com.apple.CoreAUC (326.2.0 - 326.2.0) <2CA2A80E-FEA5-3631-AD13-A8CC304C7FF7> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff31206000 -     0x7fff31209fff  com.apple.Mangrove (1.0 - 25) <00241832-3B38-3D76-88DA-0F0ADEEBFAAC> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fff3120a000 -     0x7fff31237fff  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <D4FFFBBA-0AD9-31D0-99A1-7FC249867A20> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff31238000 -     0x7fff31387fff  com.apple.FileProvider (349.141.1 - 349.141.1) <B17CE44C-07C0-3C92-BA3B-40CF881F4C78> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
    0x7fff31388000 -     0x7fff313aafff  com.apple.GenerationalStorage (2.0 - 323) <9419BDA9-3F2D-32A8-8ABD-5CAF5B6DB77F> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff313c7000 -     0x7fff313ddfff  com.apple.CPAnalytics (1.0 - 361.0.100) <50BB2901-28E8-3CDD-9BAB-E726C3FF3C1B> /System/Library/PrivateFrameworks/CPAnalytics.framework/Versions/A/CPAnalytics
    0x7fff31720000 -     0x7fff317eefff  com.apple.CoreTelephony (113 - 8260.1) <3D3D1409-4F24-3964-97E6-7A8C3B6B69C0> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
    0x7fff317ef000 -     0x7fff317fcfff  com.apple.AppSandbox (4.0 - 509.140.3) <B8CA84EA-D8AB-3CA5-B0DC-41C0D3480FDE> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fff317fd000 -     0x7fff31812fff  libswiftDispatch.dylib (4.100.1) <6CB6A353-7D77-3B38-9DEB-2875BDC809F2> /usr/lib/swift/libswiftDispatch.dylib
    0x7fff31813000 -     0x7fff319a7fff  com.apple.AVFCore (1.0 - 2020.10) <70A422C7-FCC6-3C1F-A78E-686B861847F4> /System/Library/PrivateFrameworks/AVFCore.framework/Versions/A/AVFCore
    0x7fff319a8000 -     0x7fff31a17fff  com.apple.FrontBoardServices (703.16 - 703.16) <1B6F7F55-D9F7-342F-8361-E66465F2A617> /System/Library/PrivateFrameworks/FrontBoardServices.framework/Versions/A/FrontBoardServices
    0x7fff31a18000 -     0x7fff31a41fff  com.apple.BoardServices (1.0 - 526) <12D89B26-4E91-34A2-83D9-3023D199255C> /System/Library/PrivateFrameworks/BoardServices.framework/Versions/A/BoardServices
    0x7fff31a42000 -     0x7fff31a6dfff  com.apple.contacts.vCard (1.0 - 3497.5) <2FBB0F61-22C1-3E10-9843-EDACBC152E15> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
    0x7fff31a83000 -     0x7fff31a9efff  com.apple.ExtensionKit (19.4 - 19.4) <A9753B92-EFA2-32EF-AF39-58E5605FBB61> /System/Library/PrivateFrameworks/ExtensionKit.framework/Versions/A/ExtensionKit
    0x7fff31a9f000 -     0x7fff31aa5fff  com.apple.ExtensionFoundation (19.4 - 19.4) <2D46CB26-6391-398E-A8DA-F2D370D0A0CE> /System/Library/PrivateFrameworks/ExtensionFoundation.framework/Versions/A/ExtensionFoundation
    0x7fff31b31000 -     0x7fff31ba4fff  com.apple.avfoundationcf (2.0 - 430.4.1) <BE6892F7-91CB-3C90-89F2-8756DB3C1515> /System/Library/PrivateFrameworks/AVFoundationCF.framework/Versions/A/AVFoundationCF
    0x7fff31bf4000 -     0x7fff31c33fff  com.apple.AppleVPAFramework (3.26.1 - 3.26.1) <07AE0E16-85CC-30F2-A575-A51458366DD9> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
    0x7fff31ce6000 -     0x7fff31d21fff  com.apple.DebugSymbols (195.1 - 195.1) <C94557E3-11DD-3007-B001-DC2509CFE14D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff31d22000 -     0x7fff31dd7fff  com.apple.CoreSymbolication (12.5 - 64544.81.1) <1D4A9F11-AB1C-3F5F-90A1-38C3EAA7BE1F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff31dd8000 -     0x7fff31de1fff  com.apple.CoreTime (284.0.4) <FC81E173-26AA-349F-BF34-21EEF521B84F> /System/Library/PrivateFrameworks/CoreTime.framework/Versions/A/CoreTime
    0x7fff31de2000 -     0x7fff31e57fff  com.apple.Rapport (2.6.0 - 260.3) <F0117B24-BE94-300E-936F-19019FE81850> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
    0x7fff3272c000 -     0x7fff32778fff  com.apple.coreduetcontext (1.0 - 1) <9DB089D7-90D0-3073-BFAE-3DB94AB3A876> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
    0x7fff32779000 -     0x7fff32ce5fff  com.apple.Intents (1.0 - 1) <EBAA7FE2-516C-3C64-9569-280DE870B0B4> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
    0x7fff32ce6000 -     0x7fff32d49fff  com.apple.framework.Apple80211 (17.0 - 1728) <533F7734-3B2E-3F8C-AAF6-971011659A95> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff32d4a000 -     0x7fff32e9bfff  com.apple.CoreWiFi (3.0 - 341) <B6423C61-FA72-35FD-9D43-4F6CC39F23CB> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff32e9c000 -     0x7fff32eb6fff  com.apple.BackBoardServices (1.0 - 1.0) <A7D65AAF-EFEF-3BC9-BF87-973374EBA5D7> /System/Library/PrivateFrameworks/BackBoardServices.framework/Versions/A/BackBoardServices
    0x7fff32eef000 -     0x7fff32ef0fff  com.apple.TrustEvaluationAgent (2.0 - 35) <2F6327D6-E9A1-3CC5-93C8-CA189B5C2D22> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff330d5000 -     0x7fff3310bfff  com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <72DFE637-46E4-3CF1-8233-6B88CDB4855B> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
    0x7fff3310c000 -     0x7fff3311bfff  com.apple.RemoteServiceDiscovery (1.0 - 1.120.1) <4D674B64-AC7B-3654-8A51-E256FCD9D524> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
    0x7fff33134000 -     0x7fff33178fff  com.apple.DataDetectorsNaturalLanguage (1.0 - 159.1) <1585D871-706E-33FF-919D-EE45FD698C2A> /System/Library/PrivateFrameworks/DataDetectorsNaturalLanguage.framework/Versions/A/DataDetectorsNaturalLanguage
    0x7fff33179000 -     0x7fff3317cfff  com.apple.help (1.3.8 - 71) <F94CF2A6-2886-3552-A1E5-8D83452AE773> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff3317d000 -     0x7fff33184fff  com.apple.EFILogin (2.0 - 2) <A86695A6-1567-330B-870D-805FDB9EE437> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff33185000 -     0x7fff33190fff  libcsfde.dylib (554.140.2) <678CA1E1-733D-3709-A327-2208B49C6C1A> /usr/lib/libcsfde.dylib
    0x7fff33200000 -     0x7fff33262fff  com.apple.AppSupport (1.0.0 - 29) <9DF0F117-4F1B-3E0B-A4E3-BDCAB2EB1740> /System/Library/PrivateFrameworks/AppSupport.framework/Versions/A/AppSupport
    0x7fff333cf000 -     0x7fff333cffff  com.apple.ApplicationServices (48 - 50) <4F5BA3E6-0A85-3250-AEA7-B7F3897B2113> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff333d0000 -     0x7fff333d2fff  com.apple.InternationalTextSearch (1.0 - 1) <D2F8FE9C-8B84-390F-8578-7B3CCABB996A> /System/Library/PrivateFrameworks/InternationalTextSearch.framework/Versions/A/InternationalTextSearch
    0x7fff333d3000 -     0x7fff3344bfff  com.apple.ClassKit (1.2 - 146.6) <EC19C4F1-D161-30BD-8CAA-0248F3F4D60C> /System/Library/Frameworks/ClassKit.framework/Versions/A/ClassKit
    0x7fff3344c000 -     0x7fff33590fff  com.apple.AppleAccount (1.0 - 1.0) <86661655-1BD4-32D0-96DB-5011830EE6CB> /System/Library/PrivateFrameworks/AppleAccount.framework/Versions/A/AppleAccount
    0x7fff33591000 -     0x7fff335d0fff  com.apple.AppleIDSSOAuthentication (1.0 - 1) <836444C4-6FDD-3659-81EB-1F366C9F1C71> /System/Library/PrivateFrameworks/AppleIDSSOAuthentication.framework/Versions/A/AppleIDSSOAuthentication
    0x7fff335d1000 -     0x7fff33628fff  com.apple.CorePrediction (1.0 - 1) <EAA60434-D01F-3117-9596-C544DC0EB782> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
    0x7fff336e4000 -     0x7fff336e4fff  libHeimdalProxy.dylib (79) <2572CF4E-C22E-346A-A72F-9BD07BA56057> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
    0x7fff33797000 -     0x7fff33797fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <92D76741-76FC-3010-A9C1-8885E9D5DE18> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff337bb000 -     0x7fff337fefff  com.apple.StreamingZip (1.0 - 1) <7F9BB412-0B57-3261-BAC1-8FAA2704710E> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
    0x7fff337ff000 -     0x7fff3381dfff  com.apple.DuetActivityScheduler (1.0 - 1) <7B51AE4F-579A-318D-93B6-FB58DE7402C3> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
    0x7fff3381e000 -     0x7fff3381ffff  libswiftObjectiveC.dylib (3) <6B9E4AF2-89A1-3607-868F-CDEAB81AA32A> /usr/lib/swift/libswiftObjectiveC.dylib
    0x7fff33820000 -     0x7fff33831fff  libswiftos.dylib (1000.120.2) <7225483D-DE38-3D00-87F8-583066CFC5B1> /usr/lib/swift/libswiftos.dylib
    0x7fff33832000 -     0x7fff3383efff  com.apple.IntentsFoundation (1.0 - 1) <AAEE66E2-F3D5-3689-B09B-6E1768FABC53> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
    0x7fff3383f000 -     0x7fff33844fff  com.apple.PushKit (1.0 - 1) <31E9D56F-55EF-3840-905E-BD487ABB1747> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
    0x7fff33845000 -     0x7fff33878fff  com.apple.C2 (1.3 - 573) <CFEF2E5F-94C4-3DEA-8F06-F68ED73E13EF> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
    0x7fff33879000 -     0x7fff338a9fff  com.apple.QuickLookThumbnailing (1.0 - 135.5) <5681E46A-FF2A-3D9C-BC39-C20EA57D0D6A> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
    0x7fff338aa000 -     0x7fff340abfff  com.apple.vision.EspressoFramework (1.0 - 256.4.4) <A207A19F-47D1-38C7-A792-9E0CCC778EF3> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
    0x7fff340ac000 -     0x7fff340c3fff  com.apple.ANEServices (4.76 - 4.76) <3C70C879-5C89-3890-AEE6-A72BA53ACCFC> /System/Library/PrivateFrameworks/ANEServices.framework/Versions/A/ANEServices
    0x7fff340c4000 -     0x7fff34129fff  com.apple.proactive.support.ProactiveSupport (1.0 - 294.7) <88ABAF1D-B37F-38C1-AD2B-6C12A0F989D6> /System/Library/PrivateFrameworks/ProactiveSupport.framework/Versions/A/ProactiveSupport
    0x7fff3412a000 -     0x7fff34134fff  com.apple.corerecents (1.0 - 1) <EF6A10A4-9E1E-32B5-BF92-9A31500F12E2> /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/CoreRecents
    0x7fff34135000 -     0x7fff34166fff  com.apple.iCalendar (7.0 - 833) <C1A36E58-BF77-3F34-89A7-BE12400E0972> /System/Library/PrivateFrameworks/iCalendar.framework/Versions/A/iCalendar
    0x7fff34167000 -     0x7fff341d7fff  com.apple.CalendarFoundation (8.0 - 1178.5.2) <6AC24A3A-8A95-3FA3-A42A-D7DBB3961EA2> /System/Library/PrivateFrameworks/CalendarFoundation.framework/Versions/A/CalendarFoundation
    0x7fff341d8000 -     0x7fff341dafff  com.apple.CoreDuetDebugLogging (1.0 - 1) <C2B49AAE-5792-397F-AB3A-5F59B36A7733> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
    0x7fff341db000 -     0x7fff341e7fff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <D4989410-F136-3A95-8F83-9672F4869DD1> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
    0x7fff3447b000 -     0x7fff3474efff  com.apple.spotlight.index (10.7.0 - 2150.26) <40FF1E73-F746-32C4-AC00-4BE570B6C178> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
    0x7fff34767000 -     0x7fff347b7fff  com.apple.ChunkingLibrary (334.1 - 334.1) <1F0C24A0-F8F0-3773-91FF-39956CF3A1F8> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff348ee000 -     0x7fff3493dfff  com.apple.CalDAV (8.0 - 795) <780700B4-7D80-3602-9167-959782C3477A> /System/Library/PrivateFrameworks/CalDAV.framework/Versions/A/CalDAV
    0x7fff3493e000 -     0x7fff349dbfff  com.apple.CoreSuggestions (1.0 - 1115.519) <FC2400C4-2100-373E-B788-49D22640439B> /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/CoreSuggestions
    0x7fff349dc000 -     0x7fff34b66fff  com.apple.ical.EventKit (3.0 - 1414.5.1) <0720E6DA-613F-377E-B802-F4EE2FCAA3C5> /System/Library/Frameworks/EventKit.framework/Versions/A/EventKit
    0x7fff34b67000 -     0x7fff34e38fff  com.apple.CalendarPersistence (8.0 - 1071.4.4) <0A2092B0-DEAB-3293-9A8A-DCE2ED2026E0> /System/Library/PrivateFrameworks/CalendarPersistence.framework/Versions/A/CalendarPersistence
    0x7fff34e39000 -     0x7fff34e5efff  com.apple.CalendarAgentLink (8.0 - 250) <CBB68C55-9675-3AF3-8448-F8A510973BCF> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
    0x7fff34e5f000 -     0x7fff34e69fff  com.apple.RTCReporting (11.85.2 - 11.85.2) <C94EB3D2-585A-3BEE-ADF4-77696968FA2A> /System/Library/PrivateFrameworks/RTCReporting.framework/Versions/A/RTCReporting
    0x7fff34e6a000 -     0x7fff35010fff  com.apple.WebKitLegacy (16611 - 16611.3.10.1.6) <E61927E1-3589-37AE-B8F3-5124FDA7128D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
    0x7fff3502b000 -     0x7fff35040fff  com.apple.CoreML.AppleNeuralEngine (1.0 - 1) <14E9F653-6DB2-3E6B-805F-C3FA91EAF4FC> /System/Library/PrivateFrameworks/AppleNeuralEngine.framework/Versions/A/AppleNeuralEngine
    0x7fff35096000 -     0x7fff35101fff  com.apple.audio.midi.CoreMIDI (2.0 - 88) <074EA20A-790C-31D1-B240-05F8C937EB04> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x7fff351c7000 -     0x7fff351cafff  com.apple.Cocoa (6.11 - 23) <E8E14342-DDF9-3351-B93D-8DEDBA5CAABA> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff35c6f000 -     0x7fff35cf1fff  com.apple.PhotoFoundation (6.0 - 361.0.100) <3567A3B0-243D-3688-A012-FB71BEEF11C4> /System/Library/PrivateFrameworks/PhotoFoundation.framework/Versions/A/PhotoFoundation
    0x7fff35db4000 -     0x7fff35dbbfff  com.apple.DisplayServicesFW (3.1 - 380) <8054192B-AB2B-36CB-99F3-30EBC04E451F> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fff362f5000 -     0x7fff36589fff  libAWDSupportFramework.dylib (4205) <0EA22A3B-3DA1-3E4B-95C1-5457C3828A15> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
    0x7fff365fd000 -     0x7fff3662dfff  libtidy.A.dylib (18.2) <44E1E390-C730-33FE-A15E-4AB62ED52FBA> /usr/lib/libtidy.A.dylib
    0x7fff3662e000 -     0x7fff3664efff  com.apple.MarkupUI (1.0 - 383.6) <16B68DE7-3443-31D9-AB85-6A2988EF8F1C> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
    0x7fff3664f000 -     0x7fff36662fff  com.apple.Engram (1.0 - 1) <3CAB051B-160A-3137-AE2C-DB078C0FF830> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
    0x7fff36663000 -     0x7fff36686fff  com.apple.openscripting (1.7 - 190) <96A579D8-4148-31DD-9752-D41F9E121051> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff36687000 -     0x7fff3668afff  com.apple.securityhi (9.0 - 55008) <4933616C-D994-3E1E-AFEA-E1E460A1A39E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff3668b000 -     0x7fff3668efff  com.apple.ink.framework (10.15 - 227) <FDE6A6E5-DDD2-31DE-9695-6148EE88005B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff3668f000 -     0x7fff36692fff  com.apple.CommonPanels (1.2.6 - 101) <623B24C3-6256-388A-949B-C7A37AD72690> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff36693000 -     0x7fff3669afff  com.apple.ImageCapture (1711.5.2.1 - 1711.5.2.1) <DF34BF94-579A-3CD7-8785-F49C06525E50> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff3669b000 -     0x7fff3788bfff  com.apple.JavaScriptCore (16611 - 16611.3.10.1.6) <C81585E1-7118-3D00-849C-16485B8668C7> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff378f7000 -     0x7fff37a09fff  com.apple.AVFCapture (1.0 - 82.6) <119E6F65-DB53-38B4-B4FA-7AFB5645476D> /System/Library/PrivateFrameworks/AVFCapture.framework/Versions/A/AVFCapture
    0x7fff37a0a000 -     0x7fff37a9dfff  com.apple.Quagga (47 - 47) <7DABFA1D-0B1C-3F38-8B71-FDA918DF066E> /System/Library/PrivateFrameworks/Quagga.framework/Versions/A/Quagga
    0x7fff37a9e000 -     0x7fff37ce8fff  com.apple.CMCapture (1.0 - 82.6) <FBCE95F0-81D5-38F1-8B39-88F51E3EC323> /System/Library/PrivateFrameworks/CMCapture.framework/Versions/A/CMCapture
    0x7fff38084000 -     0x7fff38131fff  com.apple.accounts.AccountsDaemon (113 - 113) <B538A8B2-0BF0-3C16-9FD7-95DD757FD754> /System/Library/PrivateFrameworks/AccountsDaemon.framework/Versions/A/AccountsDaemon
    0x7fff38132000 -     0x7fff38134fff  com.apple.OAuth (25 - 25) <457FF7AF-025F-338F-B8FD-86A5D7C22794> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
    0x7fff386e4000 -     0x7fff386f3fff  com.apple.HID (1.0 - 1) <B6B1791D-B625-337C-8D2F-05C9F95F494B> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
    0x7fff386f4000 -     0x7fff3881bfff  com.apple.QuickLookUIFramework (5.0 - 928.5) <8661B2DA-061A-309C-BD42-9DEE6D7F9E3E> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fff38bee000 -     0x7fff38c74fff  com.apple.coredav (1.0.1 - 889) <423466E8-387E-353F-A134-618BAD13AB7A> /System/Library/PrivateFrameworks/CoreDAV.framework/Versions/A/CoreDAV
    0x7fff38c75000 -     0x7fff38ccbfff  com.apple.ExchangeWebServices (8.0 - 814.100.1) <661EFC35-04D2-3733-A806-5C1956F0C00C> /System/Library/PrivateFrameworks/ExchangeWebServices.framework/Versions/A/ExchangeWebServices
    0x7fff38e08000 -     0x7fff38e08fff  com.apple.marco (10.0 - 1000) <10CD3F3D-C1ED-313F-BD24-0CDD95926844> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
    0x7fff38fee000 -     0x7fff39026fff  com.apple.contacts.ContactsAutocomplete (1.0 - 1152.4) <6F168917-1552-3A8B-B7F8-DAA21468349E> /System/Library/PrivateFrameworks/ContactsAutocomplete.framework/Versions/A/ContactsAutocomplete
    0x7fff39027000 -     0x7fff39033fff  com.apple.KerberosHelper (4.0 - 1.0) <8E7333D0-DCA2-3599-90FE-0B2F50C3EB64> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
    0x7fff39034000 -     0x7fff39077fff  com.apple.ResponseKit (1.0 - 165.2) <D996529D-562A-3E6E-A9D6-5C9A45446703> /System/Library/PrivateFrameworks/ResponseKit.framework/Versions/A/ResponseKit
    0x7fff39078000 -     0x7fff39097fff  com.apple.proactive.support.ProactiveEventTracker (1.0 - 294.7) <15483C77-7686-336C-BDAF-E16AFC986711> /System/Library/PrivateFrameworks/ProactiveEventTracker.framework/Versions/A/ProactiveEventTracker
    0x7fff394bb000 -     0x7fff394bbfff  com.apple.PhoneNumbers (1.0 - 1) <3C3718A2-FD55-37F3-B45B-7328BE28F8CC> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fff394bc000 -     0x7fff394c3fff  com.apple.URLFormatting (146 - 146.22) <22DEF2D9-9562-3894-B49E-EABD33DD746B> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
    0x7fff394c4000 -     0x7fff394d2fff  com.apple.accessibility.AXCoreUtilities (1.0 - 1) <203FB146-6AA7-38B4-90E4-7E6321B04D56> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
    0x7fff394d3000 -     0x7fff394eafff  libAccessibility.dylib (2885.49.1) <3686A929-B308-3045-B64E-3B78F9631DAD> /usr/lib/libAccessibility.dylib
    0x7fff394eb000 -     0x7fff3bc35fff  com.apple.WebCore (16611 - 16611.3.10.1.6) <405F670D-0966-3694-B279-FA641D46767A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
    0x7fff3bf25000 -     0x7fff3bf47fff  com.apple.quicklook.QuickLookSupport (1.0 - 135.5) <B6FB31F8-4790-3A43-9051-58FDB5A0BB88> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
    0x7fff3bf48000 -     0x7fff3bfdffff  com.apple.AirPlaySync (1.0 - 2780.10.4.1) <AD221FBA-7DFB-310F-AB9C-760D0F1F37B2> /System/Library/PrivateFrameworks/AirPlaySync.framework/Versions/A/AirPlaySync
    0x7fff3bfe4000 -     0x7fff3c0a5fff  com.apple.siri.parsec.CoreParsec (1.0 - 386.6.3) <047BED34-8377-3EF0-AE87-FF0C4D3D8C23> /System/Library/PrivateFrameworks/CoreParsec.framework/Versions/A/CoreParsec
    0x7fff3c1b2000 -     0x7fff3c1bcfff  libswiftCoreGraphics.dylib (2) <72BFB4DB-2627-3687-83C8-9F6875038F64> /usr/lib/swift/libswiftCoreGraphics.dylib
    0x7fff3c1bd000 -     0x7fff3c1c6fff  libswiftDarwin.dylib (??? - ???) <3A8833E7-2C6E-3FE2-BF58-602D4812E4CB> /usr/lib/swift/libswiftDarwin.dylib
    0x7fff3c213000 -     0x7fff3c261fff  com.apple.Safari.SafeBrowsing (16611 - 16611.3.10.1.6) <6445E8FE-D90A-38AA-80F2-834993AD7C50> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
    0x7fff3c262000 -     0x7fff3ca41fff  com.apple.WebKit (16611 - 16611.3.10.1.6) <8BEF50B1-DA9A-3BF0-9EC8-86D652883769> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x7fff3cb70000 -     0x7fff3cbf3fff  com.apple.CorePDF (4.0 - 529) <24987CDD-9F92-3359-AA4C-F3E9C2E9DD13> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fff3cbf4000 -     0x7fff3cbf7fff  com.apple.print.framework.Print (15 - 271) <47961FDE-D450-3357-948E-CFDEFA763A7B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff3cbf8000 -     0x7fff3cbfbfff  com.apple.Carbon (160 - 164) <0939DBF6-0BC9-3342-8053-1AD741298E3C> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff3ccf4000 -     0x7fff3ccf4fff  com.apple.avfoundation (2.0 - 2020.10) <19FE20E3-D0AC-3846-A30D-E1B9EC6731C3> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff3ceae000 -     0x7fff3cecdfff  com.apple.private.SystemPolicy (1.0 - 1) <328482A7-11FC-3DF4-B4B3-C73796A1FEA1> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
    0x7fff3d071000 -     0x7fff3d08efff  com.apple.sidecar-core (1.0 - 231.0.1) <0D792284-3B63-3245-AC0C-B30AB7028133> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
    0x7fff3d08f000 -     0x7fff3d092fff  com.apple.QuickLookNonBaseSystem (1.0 - 1) <D371CEC5-4326-3218-A9A4-280DA8DF6D85> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
    0x7fff3d252000 -     0x7fff3d26cfff  com.apple.mediastream (1.0 - 361.0.100) <B91A82EC-8466-3A1E-8B72-AE0CB85F43B9> /System/Library/PrivateFrameworks/MediaStream.framework/Versions/A/MediaStream
    0x7fff3d4a5000 -     0x7fff3d4a9fff  com.apple.CoreOptimization (1.0 - 1) <FDE8D61F-3821-38CE-8990-A45D4E88BB28> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
    0x7fff3d621000 -     0x7fff3d638fff  com.apple.SafariServices.framework (16611 - 16611.3.10.1.6) <A204D970-9F32-371A-B194-A9A652A7B2AE> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fff3d77a000 -     0x7fff3d7eafff  com.apple.LoggingSupport (1.0 - 1277.120.1) <07B8B384-3E3E-3A54-9F77-23A172A2494D> /System/Library/PrivateFrameworks/LoggingSupport.framework/Versions/A/LoggingSupport
    0x7fff3d7eb000 -     0x7fff3d7f6fff  com.apple.MallocStackLogging (1.0 - 1) <80F5AFE5-59AD-39BF-9A19-C055FE2468F1> /System/Library/PrivateFrameworks/MallocStackLogging.framework/Versions/A/MallocStackLogging
    0x7fff3d80b000 -     0x7fff3d81dfff  libmis.dylib (274.140.2) <F4EE6883-6A50-33B0-9AF9-5131DA07E3D3> /usr/lib/libmis.dylib
    0x7fff3d822000 -     0x7fff3d82afff  libswiftCoreAudio.dylib (1.1) <ED7E115B-DCF7-3FE9-8616-B3DE7F220651> /usr/lib/swift/libswiftCoreAudio.dylib
    0x7fff3d82b000 -     0x7fff3d82bfff  libswiftCoreFoundation.dylib (1.6) <7089C022-D5D4-30F1-905C-A6CED670A0AC> /usr/lib/swift/libswiftCoreFoundation.dylib
    0x7fff3d837000 -     0x7fff3d837fff  libswiftXPC.dylib (1.1) <AA894831-E21A-343D-85CD-AC6ABD45B39D> /usr/lib/swift/libswiftXPC.dylib
    0x7fff3d838000 -     0x7fff3d838fff  libswiftCoreImage.dylib (1) <C2D47675-3935-3356-BDE2-B99896B23823> /usr/lib/swift/libswiftCoreImage.dylib
    0x7fff3d839000 -     0x7fff3d839fff  libswiftIOKit.dylib (1) <3A1876ED-315D-3BCD-BDE3-C7438114B2CA> /usr/lib/swift/libswiftIOKit.dylib
    0x7fff3d83a000 -     0x7fff3d9a9fff  com.apple.CoreHandwriting (161 - 1.2) <4A2F7C42-4376-3AB3-8B82-5E9CB99C8378> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
    0x7fff3d9aa000 -     0x7fff3dc05fff  com.apple.imageKit (3.0 - 1100) <BB7249A7-AABA-39D2-8632-609871885248> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fff3dc06000 -     0x7fff3dd1cfff  com.apple.PencilKit (1.0 - 1) <3B310B07-A578-356A-B7B6-696EAC2CB933> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
    0x7fff3dd1d000 -     0x7fff3dd2efff  com.apple.sidecar-ui (1.0 - 231.0.1) <2BFBDB5D-449F-312D-8DB0-BAF97EAA1C5D> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
    0x7fff3dd3a000 -     0x7fff3dd3dfff  com.apple.WebInspectorUI (16611 - 16611.3.10.1.6) <71070A03-166E-309D-BE24-EFBF5273E5BA> /System/Library/PrivateFrameworks/WebInspectorUI.framework/Versions/A/WebInspectorUI
    0x7fff3df91000 -     0x7fff3e117fff  com.apple.SearchFoundation (1.0 - 386.6.3) <24C725DF-CEB5-3FE4-95F2-F4C91283138D> /System/Library/PrivateFrameworks/SearchFoundation.framework/Versions/A/SearchFoundation
    0x7fff3e118000 -     0x7fff3e350fff  com.apple.Photos (1.0 - 361.0.100) <121607ED-8881-3658-93B2-6E68C1A1F344> /System/Library/Frameworks/Photos.framework/Versions/A/Photos
    0x7fff3e351000 -     0x7fff3e3b3fff  com.apple.ImageCaptureCore (1711.5.2.1 - 1711.5.2.1) <B2AF26AA-B52B-3B72-8AB2-CD9EE596838B> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fff3e3b4000 -     0x7fff3e3d9fff  com.apple.quartzfilters (1.10.0 - 98) <2B9E46C1-57D6-3432-BADF-A1F3A96B138D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fff3e407000 -     0x7fff3e431fff  com.apple.ToneLibrary (1.0 - 1) <CDE1D4D5-1259-3117-90A6-111691FDE9B2> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
    0x7fff3ea95000 -     0x7fff3ebc1fff  com.apple.AnnotationKit (1.0 - 383.6) <4351CE42-686C-38AD-AFB1-14409718883A> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
    0x7fff3ebc2000 -     0x7fff3f062fff  com.apple.QuartzComposer (5.1 - 383) <28A84577-F578-3CCC-8163-F4417FEBCA57> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fff3f063000 -     0x7fff3f14bfff  com.apple.PDFKit (1.0 - 950.40.3) <A9CE6759-E17D-3C9C-81A4-5ABEDFC6E236> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fff3fde5000 -     0x7fff3fdfefff  libswiftsimd.dylib (1.3) <1FE0258C-4147-3F73-91F1-C4EDC5C96B81> /usr/lib/swift/libswiftsimd.dylib
    0x7fff403ca000 -     0x7fff40485fff  com.apple.AssetsLibraryServices (1.0 - 361.0.100) <C1192BB7-1D2D-326D-B09E-A15B7572192A> /System/Library/PrivateFrameworks/AssetsLibraryServices.framework/Versions/A/AssetsLibraryServices
    0x7fff40486000 -     0x7fff40b72fff  com.apple.PhotoLibraryServices (1.0 - 361.0.100) <359E552D-72B4-3F8B-A6D8-C2F3649320D5> /System/Library/PrivateFrameworks/PhotoLibraryServices.framework/Versions/A/PhotoLibraryServices
    0x7fff40b73000 -     0x7fff40bacfff  com.apple.siri.DistributedEvaluation (1.0 - 36.3) <9F47A6C4-DEE3-3591-B8D5-8BDC13127A9A> /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/DistributedEvaluation
    0x7fff40c53000 -     0x7fff40c5efff  com.apple.CaptiveNetworkSupport (13.0 - 1) <240BA909-E91B-3F24-A2EC-8D6A02931F5D> /System/Library/PrivateFrameworks/CaptiveNetwork.framework/Versions/A/CaptiveNetwork
    0x7fff410aa000 -     0x7fff410adfff  com.apple.quartzframework (1.5 - 25) <33CBA95A-CD84-3348-9187-F5255FF5966C> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fff414f0000 -     0x7fff414f1fff  libswiftCoreLocation.dylib (5) <35F180EB-670F-31BF-AABB-DA98D6275EC9> /usr/lib/swift/libswiftCoreLocation.dylib
    0x7fff414f2000 -     0x7fff414fbfff  libswiftCoreMIDI.dylib (2) <E37D2757-4D96-3B46-ADB8-6E98B50F7FF0> /usr/lib/swift/libswiftCoreMIDI.dylib
    0x7fff41de7000 -     0x7fff41debfff  libswiftCoreData.dylib (3) <730565F1-62BD-3367-8D3E-96B019628488> /usr/lib/swift/libswiftCoreData.dylib
    0x7fff42b6f000 -     0x7fff438cffff  libfaceCore.dylib (4.3.1) <71AE1B46-AE0E-3E12-9175-97654FDB7384> /System/Library/Frameworks/Vision.framework/libfaceCore.dylib
    0x7fff438d0000 -     0x7fff439e3fff  com.apple.TextRecognition (1.0 - 157) <45029F8D-0C5C-338F-ADAF-D5E15A538AE1> /System/Library/PrivateFrameworks/TextRecognition.framework/Versions/A/TextRecognition
    0x7fff439e4000 -     0x7fff439fcfff  com.apple.Futhark (1.0 - 1) <2170A7F5-ED10-3E79-B950-8A6A1A4E7F71> /System/Library/PrivateFrameworks/Futhark.framework/Versions/A/Futhark
    0x7fff45c4c000 -     0x7fff45cf8fff  com.apple.MMCS (1.3 - 573) <F9100BFC-83BB-3C69-ACB0-4DB6210611A4> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fff45cf9000 -     0x7fff45d65fff  com.apple.acg.InertiaCam (1.0 - 1) <624C1078-697B-3AE6-B6B7-DCCF5236B594> /System/Library/PrivateFrameworks/InertiaCam.framework/Versions/A/InertiaCam
    0x7fff45ed9000 -     0x7fff45edefff  libswiftMetal.dylib (1.3.1) <4BF4F0EE-7AEF-3246-8C2B-24F30C00E582> /usr/lib/swift/libswiftMetal.dylib
    0x7fff45ee5000 -     0x7fff45ef0fff  libswiftCloudKit.dylib (990) <49044D72-AE08-3AC5-8227-F4426CB989C3> /usr/lib/swift/libswiftCloudKit.dylib
    0x7fff47bfa000 -     0x7fff47c3afff  com.apple.osanalytics.OSAnalytics (1.0 - 1) <0827F522-B66F-33E7-8670-7DC967961979> /System/Library/PrivateFrameworks/OSAnalytics.framework/Versions/A/OSAnalytics
    0x7fff47d75000 -     0x7fff47eeafff  com.apple.CloudPhotoLibrary (1.0 - 361.0.100) <D0D2920C-25CC-3A86-BE74-8504DE8D22DD> /System/Library/PrivateFrameworks/CloudPhotoLibrary.framework/Versions/A/CloudPhotoLibrary
    0x7fff47eeb000 -     0x7fff47ef7fff  com.apple.DCIMServices (1.0 - 361.0.100) <652F02D5-F70D-341A-87BF-9A285DCAEDBF> /System/Library/PrivateFrameworks/DCIMServices.framework/Versions/A/DCIMServices
    0x7fff4846f000 -     0x7fff48483fff  libswiftAppKit.dylib (104) <ADE56277-3204-363A-8D8F-A63935022C60> /usr/lib/swift/libswiftAppKit.dylib
    0x7fff48484000 -     0x7fff48485fff  libswiftQuartzCore.dylib (1) <C97D1F92-3C90-386C-91D9-0F6EFF8338AC> /usr/lib/swift/libswiftQuartzCore.dylib
    0x7fff48b13000 -     0x7fff48b3afff  com.apple.photo.MediaConversionService (6.0 - 361.0.100) <E517D643-657C-3139-AE7E-9FD7AE10A362> /System/Library/PrivateFrameworks/MediaConversionService.framework/Versions/A/MediaConversionService
    0x7fff497c4000 -     0x7fff499c5fff  com.apple.photo.NeutrinoCore (1.0 - 361.0.100) <7674BF37-3C1F-3138-9410-E865F76831ED> /System/Library/PrivateFrameworks/NeutrinoCore.framework/Versions/A/NeutrinoCore
    0x7fff4a76e000 -     0x7fff4a7dafff  com.apple.PhotosFormats (1.0 - 361.0.100) <B900A11B-7BE8-36BC-A65F-74EBF6E9F7E7> /System/Library/PrivateFrameworks/PhotosFormats.framework/Versions/A/PhotosFormats
    0x7fff4bb51000 -     0x7fff4bc5cfff  com.apple.CoreMediaStream (1.0 - 361.0.100) <B7454289-09A9-3825-9B65-B68DA62CEC77> /System/Library/PrivateFrameworks/CoreMediaStream.framework/Versions/A/CoreMediaStream
    0x7fff4bc5d000 -     0x7fff4bc6ffff  libswiftUniformTypeIdentifiers.dylib (637) <7BE0DCE3-4501-3EC8-801D-9515A9F3A2A5> /usr/lib/swift/libswiftUniformTypeIdentifiers.dylib
    0x7fff4d508000 -     0x7fff4d65efff  com.apple.photo.PhotoImaging (1.0 - 361.0.100) <D1789D00-8403-3FDD-A85D-1F2D3E81BC07> /System/Library/PrivateFrameworks/PhotoImaging.framework/Versions/A/PhotoImaging
    0x7fff4de99000 -     0x7fff4dee3fff  com.apple.PhotosImagingFoundation (6.0 - 361.0.100) <C2789A85-110B-33FA-A570-4B0A3A1E29FF> /System/Library/PrivateFrameworks/PhotosImagingFoundation.framework/Versions/A/PhotosImagingFoundation
    0x7fff4dee4000 -     0x7fff4deeefff  com.apple.CloudPhotoServices (1.0 - 361.0.100) <F70C9CC6-0D71-3BD3-B405-EDFB26DE1D1C> /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/CloudPhotoServices
    0x7fff4deef000 -     0x7fff4df4afff  com.apple.acg.AutoLoop (1.0 - 1) <A2AF33D5-E928-34C6-A3CB-C1264E9419A9> /System/Library/PrivateFrameworks/AutoLoop.framework/Versions/A/AutoLoop
    0x7fff4e460000 -     0x7fff4e498fff  libswiftCoreMedia.dylib (1) <83BAE990-F5E8-3140-8EAA-790003640039> /usr/lib/swift/libswiftCoreMedia.dylib
    0x7fff4ef4b000 -     0x7fff4ef4cfff  libswiftOSLog.dylib (1) <110E5984-F615-349C-A936-EBDF79253237> /usr/lib/swift/libswiftOSLog.dylib
    0x7fff4effc000 -     0x7fff4f002fff  libswiftAVFoundation.dylib (2020.10) <6B04BD80-9F5E-384D-9F59-04F9FE5CC500> /usr/lib/swift/libswiftAVFoundation.dylib
    0x7fff518b9000 -     0x7fff51958fff  com.apple.Symbolication (12.5 - 64544.70.1) <6D9C8333-6369-3964-A972-5BF99B0AC549> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff53e17000 -     0x7fff53e23fff  com.apple.OSLog (1.0 - 1277.120.1) <BB2562DB-6D07-3A93-953B-A423D71CF9E3> /System/Library/Frameworks/OSLog.framework/Versions/A/OSLog
    0x7fff53f64000 -     0x7fff53f79fff  com.apple.ScriptingBridge (1.4 - 80) <CDB2C881-3762-30FD-ABC6-D9A0EC17AED6> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
    0x7fff53fd0000 -     0x7fff540f8fff  com.apple.InternalSwiftProtobuf (1.0 - 1.14.0) <65A487DB-39B1-34A8-A3E7-4EFAAF5AAEC7> /System/Library/PrivateFrameworks/InternalSwiftProtobuf.framework/Versions/A/InternalSwiftProtobuf
    0x7fff6bd63000 -     0x7fff6bd69fff  libCoreFSCache.dylib (200.11) <A10745F3-1533-329E-B42A-6DE60871F7C0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff6bd6a000 -     0x7fff6bd6efff  libCoreVMClient.dylib (200.11) <3370F902-DA03-3297-804C-EB5F7FD67A01> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff6bd6f000 -     0x7fff6bd7efff  com.apple.opengl (18.5.9 - 18.5.9) <2A421CC5-4D60-339C-9772-3AC991232BD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff6bd7f000 -     0x7fff6bd81fff  libCVMSPluginSupport.dylib (18.5.9) <BF44FEB3-FB8E-3FD8-8988-AD56AD53CFD4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff6bd82000 -     0x7fff6bd8afff  libGFXShared.dylib (18.5.9) <C4751529-359A-3ECC-84B2-74A23EFAD42A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff6bd8b000 -     0x7fff6bdbefff  libGLImage.dylib (18.5.9) <C153E192-20A3-3F7D-A897-533DACE748EC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff6bdbf000 -     0x7fff6bdfbfff  libGLU.dylib (18.5.9) <8275A6AB-AAD5-3222-A80B-411C0FAFCA63> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff6bf90000 -     0x7fff6bf9afff  libGL.dylib (18.5.9) <C6BE589B-CD26-3142-BD18-10C13D404904> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff6d3da000 -     0x7fff6d432fff  com.apple.opencl (4.6 - 4.6) <79DA4138-12AB-3561-9967-D49EFB14B437> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff6e4e4000 -     0x7fff6e5cbfff  com.apple.audio.AVFAudio (1.0 - 477.88) <B2C8331B-60D4-3651-B9A0-B9914A230C36> /System/Library/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fff6fb4d000 -     0x7fff6fb5ffff  com.apple.CMImaging (1.0 - 82.6) <F60EEDA0-C221-3B51-B537-EE2FE48E19E9> /System/Library/PrivateFrameworks/CMImaging.framework/Versions/A/CMImaging
    0x7fff71e72000 -     0x7fff725fbfff  com.apple.PegasusAPI (1.0 - 386.6.3) <C23212FD-EEE7-3928-B0E1-049D80E4F45C> /System/Library/PrivateFrameworks/PegasusAPI.framework/Versions/A/PegasusAPI
    0x7fff77c12000 -     0x7fff77c19fff  libRosetta.dylib (203.58) <26D08622-69F5-32DB-80D2-9B4651A9F0CC> /usr/lib/libRosetta.dylib
    0x7fff77e81000 -     0x7fff77f6cfff  libcrypto.0.9.8.dylib (80) <0D035BEF-BB52-3237-B734-66EDBB33EF23> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff7832c000 -     0x7fff7837ffff  libstdc++.6.dylib (104.1) <72E707D0-D277-3AA2-980E-02302FAEE5BC> /usr/lib/libstdc++.6.dylib
    0x7fff78414000 -     0x7fff78414fff  libswiftPhotos.dylib (361.0.100) <41146949-00A7-38E5-B05F-D8C634D01F1E> /usr/lib/swift/libswiftPhotos.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=933.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=933.5M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Kernel Alloc Once                    8K        1
MALLOC                           178.5M       17
MALLOC guard page                   24K        4
MALLOC_MEDIUM (reserved)         360.0M        3         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
STACK GUARD                       56.0M        1
Stack                             8192K        1
VM_ALLOCATE                        208K        3
__DATA                            31.3M      583
__DATA_CONST                      31.1M      342
__DATA_DIRTY                      1868K      228
__FONT_DATA                          4K        1
__LINKEDIT                       527.6M       71
__OBJC_RO                         70.3M        1
__OBJC_RW                         2480K        2
__TEXT                           495.2M      571
__UNICODE                          588K        1
shared memory                        4K        1
TOTAL                              2.1G     1832
TOTAL, minus reserved VM space     1.4G     1832
There's a problem in the main executable: it calls intel fastmem.A, it needs to be patched to call intel fastmem.V just like Autodesk Maya. Can you link me this specific version which doesn't work?
Link to post
