HP Pavilion 14-CE1009NL i3-8145U UHD 620
Ricky_91
2 minuti fa, A23SS4NDRO ha scritto:
cosa ci sarebbe da migliorare? accetto consigli volentieri
sbus non serve, nessun portatile mac kaby e successivi lo usa.
mettere irq a 0 su RTC non serve
etc...
figurati io nemmeno uso HPET...
poi ti passerò magari ioreg del mio
1 minute ago, Ricky_91 said:
Si, funziona anche avendo un monitor 4K 😁
Allega un log ACPI con HackCheck, sezione log
Hai le USB mappate già, i connettori della integrata sistemati, la batteria sistemata via SSDT senza uso di alcun DSDT, meglio di così non ti poteva andare @Ricky_91
Vedo intanto che siamo bene a cavallo
tuttavia ci sono alcuni errori
2021-04-14 15:54:16.365689+0200  localhost kernel[0]: (AppleACPIEC) ACPI: no ECDT
2021-04-14 15:54:16.587622+0200  localhost kernel[0]: (AppleACPIPlatform)  found RTC service
2021-04-14 15:54:25.966606+0200  localhost kernel[0]: (AppleACPIPlatform) Matched against SMC (started)
2021-04-14 15:54:25.966608+0200  localhost kernel[0]: (AppleACPIPlatform) Generation from SMC report as 2
2021-04-14 16:01:00.551500+0200  localhost kernel[0]: (AppleACPIPlatform) ACPI Error:
2021-04-14 16:01:00.551502+0200  localhost kernel[0]: (AppleACPIPlatform) ACPI Error:
2021-04-14 16:01:00.551508+0200  localhost kernel[0]: (AppleACPIPlatform) No handler for Region [CMS0] (ffffff801f395280) [SystemCMOS]
2021-04-14 16:01:00.551510+0200  localhost kernel[0]: (AppleACPIPlatform) No handler for Region [CMS0] (ffffff801f395280) [SystemCMOS]
2021-04-14 16:01:00.551515+0200  localhost kernel[0]: (AppleACPIPlatform)  (20160930/evregion-252)
2021-04-14 16:01:00.551517+0200  localhost kernel[0]: (AppleACPIPlatform)  (20160930/evregion-252)
2021-04-14 16:01:00.551519+0200  localhost kernel[0]: (AppleACPIPlatform) ACPI Error:
2021-04-14 16:01:00.551520+0200  localhost kernel[0]: (AppleACPIPlatform) ACPI Error:
2021-04-14 16:01:00.551523+0200  localhost kernel[0]: (AppleACPIPlatform) Region SystemCMOS (ID=5) has no handler
2021-04-14 16:01:00.551525+0200  localhost kernel[0]: (AppleACPIPlatform) Region SystemCMOS (ID=5) has no handler
2021-04-14 16:01:00.551529+0200  localhost kernel[0]: (AppleACPIPlatform)  (20160930/exfldio-392)
2021-04-14 16:01:00.551530+0200  localhost kernel[0]: (AppleACPIPlatform)  (20160930/exfldio-392)
2021-04-14 16:01:00.551536+0200  localhost kernel[0]: (AppleACPIPlatform) [_Q33] @00001 #002D:
2021-04-14 16:01:00.551538+0200  localhost kernel[0]: (AppleACPIPlatform) [_Q33] @00001 #002D:
2021-04-14 16:01:00.551541+0200  localhost kernel[0]: (AppleACPIPlatform) ^
2021-04-14 16:01:00.551543+0200  localhost kernel[0]: (AppleACPIPlatform) ^
2021-04-14 16:01:00.551544+0200  localhost kernel[0]: (AppleACPIPlatform) ^
2021-04-14 16:01:00.551545+0200  localhost kernel[0]: (AppleACPIPlatform) R
2021-04-14 16:01:00.551546+0200  localhost kernel[0]: (AppleACPIPlatform) R
2021-04-14 16:01:00.551547+0200  localhost kernel[0]: (AppleACPIPlatform) T
2021-04-14 16:01:00.551548+0200  localhost kernel[0]: (AppleACPIPlatform) T
2021-04-14 16:01:00.551549+0200  localhost kernel[0]: (AppleACPIPlatform) C
2021-04-14 16:01:00.551550+0200  localhost kernel[0]: (AppleACPIPlatform) C
2021-04-14 16:01:00.551552+0200  localhost kernel[0]: (AppleACPIPlatform) .
2021-04-14 16:01:00.551554+0200  localhost kernel[0]: (AppleACPIPlatform) R
2021-04-14 16:01:00.551556+0200  localhost kernel[0]: (AppleACPIPlatform) T
2021-04-14 16:01:00.551557+0200  localhost kernel[0]: (AppleACPIPlatform) T
2021-04-14 16:01:00.551558+0200  localhost kernel[0]: (AppleACPIPlatform) M
2021-04-14 16:01:00.551559+0200  localhost kernel[0]: (AppleACPIPlatform) M
2021-04-14 16:01:00.551560+0200  localhost kernel[0]: (AppleACPIPlatform) N
2021-04-14 16:01:00.551561+0200  localhost kernel[0]: (AppleACPIPlatform) N
2021-04-14 16:01:00.551562+0200  localhost kernel[0]: (AppleACPIPlatform)
2021-04-14 16:01:00.551563+0200  localhost kernel[0]: (AppleACPIPlatform)
2021-04-14 16:01:00.551566+0200  localhost kernel[0]: (AppleACPIPlatform) No Local Variables are initialized for method [_Q33]
2021-04-14 16:01:00.551567+0200  localhost kernel[0]: (AppleACPIPlatform) No Local Variables are initialized for method [_Q33]
2021-04-14 16:01:00.551571+0200  localhost kernel[0]: (AppleACPIPlatform)
2021-04-14 16:01:00.551574+0200  localhost kernel[0]: (AppleACPIPlatform) No Arguments are initialized for method [_Q33]
2021-04-14 16:01:00.551575+0200  localhost kernel[0]: (AppleACPIPlatform) No Arguments are initialized for method [_Q33]
2021-04-14 16:01:00.551578+0200  localhost kernel[0]: (AppleACPIPlatform)
2021-04-14 16:01:00.551579+0200  localhost kernel[0]: (AppleACPIPlatform)
2021-04-14 16:01:00.551581+0200  localhost kernel[0]: (AppleACPIPlatform) ACPI Error:
2021-04-14 16:01:00.551582+0200  localhost kernel[0]: (AppleACPIPlatform) ACPI Error:
2021-04-14 16:01:00.551586+0200  localhost kernel[0]: (AppleACPIPlatform) Method parse/execution failed
2021-04-14 16:01:00.551587+0200  localhost kernel[0]: (AppleACPIPlatform) Method parse/execution failed
2021-04-14 16:01:00.551591+0200  localhost kernel[0]: (AppleACPIPlatform) [\_SB.PCI0.LPCB.EC0._Q33] (Node ffffff801f8cfcc0)
2021-04-14 16:01:00.551593+0200  localhost kernel[0]: (AppleACPIPlatform) [\_SB.PCI0.LPCB.EC0._Q33] (Node ffffff801f8cfcc0)
2021-04-14 16:01:00.551597+0200  localhost kernel[0]: (AppleACPIPlatform) , AE_NOT_EXIST
2021-04-14 16:01:00.551598+0200  localhost kernel[0]: (AppleACPIPlatform) , AE_NOT_EXIST
2021-04-14 16:01:00.551601+0200  localhost kernel[0]: (AppleACPIPlatform)  (20160930/psparse-632)
2021-04-14 16:01:00.551602+0200  localhost kernel[0]: (AppleACPIPlatform)  (20160930/psparse-632)
si direi anche normali, sono OP in RTC..
1 minuto fa, Ricky_91 ha scritto:
In realtà ho un SSD di quelli tipo NVMe, ma con interfaccia Sata
si ma il discorso non cambia essendo collegato SATA
si infatti da ioreg vedo che spunta su SAT0
@Gengik84 Come mai ha quell'AE_NOT_FOUND su EC0._Q33?
Figata comunque, mettendo un disco msata esce sulla porta PRT1, invece io che usavo SATA su interfaccia normale avendo comprato il cavetto mi esce su PRT0
Infatti dal BIOS ci sono 3 porte SATA configurabili
discorso di cui sopra, perchè "chiamano" OP su RTC
con questo intendo che alcuni "collegamenti" di fatto non portano a nulla, non ci sono
quindi AE_NOT_FOUND è plausibile e anche corretto alla fine
@Ricky_91 i tasti per la luminosità ti funzionano?
c'è modo per sistemare al volo? Dove serve intervenire?
Da quando funziona la scheda video, vanno anche tutti i tasti funzione. Diciamo che gli unici difetti che ho riscontrato finora sono, il lettore di schede SD, e il color banding
Edited by Ricky_91
Ah piccola nota, tra le proprietà della iGPU, oltre ai connettori sistemati ed il fix per i 60MB brutti di firewolf è presente anche un fix quando metterai big sur, con catalina questo problema non ci sta forse perché i driver video sono ad una versione precedente, ma personalmente da BigSur in poi la luminosità va quasi a zero se il fix per i backlight registers non è attivo
Anche la batteria viene visualizzata correttamente
verifica installando iStatMenus se vedi anche la ventola
Link al pacchetto qui: https://download.bjango.com/istatmenus/
Hai anche le frequenze della CPU sistemate, arrivi fino a 800MHz in idle per risparmiare più possibile batteria
Dovresti vedere una cosa del genere, impostando anche da BIOS:
"Fan Always on" Disabled
