Asus TRX40 E Gaming - Baremetal [Help]
3 minutes ago, fabiosun said:
all this one:
0xE2180000
0xxxxxxxxx
and so on
I hope that i understand you correctly 🙂 If not send me please example of one line.
Dec:
52:972 00:064 OCABC: MMIO devirt 0 (0x81 pages, 0x8000000000000001) skip 0
53:036 00:063 OCABC: MMIO devirt 0 (0x81 pages, 0x8000000000000001) skip 0
53:108 00:072 OCABC: MMIO devirt 0 (0x100 pages, 0x8000000000000001) skip 0
53:172 00:063 OCABC: MMIO devirt 0 (0x181 pages, 0x8000000000000001) skip 0
53:235 00:063 OCABC: MMIO devirt 0 (0x81 pages, 0x8000000000000001) skip 0
53:299 00:064 OCABC: MMIO devirt 0 (0x100 pages, 0x8000000000000001) skip 0
53:363 00:063 OCABC: MMIO devirt 0 (0x1 pages, 0x8000000000000001) skip 0
53:581 00:218 OCABC: MMIO devirt 0 (0x1 pages, 0x8000000000000001) skip 0
53:646 00:064 OCABC: MMIO devirt 0 (0x1 pages, 0x8000000000000001) skip 0
53:710 00:064 OCABC: MMIO devirt 0 (0x5 pages, 0x8000000000000001) skip 0
53:774 00:064 OCABC: MMIO devirt 0 (0x10 pages, 0x8000000000000001) skip 0
53:838 00:063 OCABC: MMIO devirt 0 (0xE pages, 0x8000000000000001) skip 0
53:902 00:063 OCABC: MMIO devirt 0 (0x2 pages, 0x8000000000000001) skip 0
53:966 00:064 OCABC: MMIO devirt 0 (0x100 pages, 0x8000000000000001) skip 0
54:029 00:063 OCABC: MMIO devirt 0 (0x1000 pages, 0x8000000000000001) skip 0
54:093 00:063 OCABC: MMIO devirt 0 (0x10400 pages, 0x8000000000000001) skip 0
54:165 00:071 OCABC: MMIO devirt 0 (0x10400 pages, 0x8000000000000001) skip 0
54:228 00:063 OCABC: MMIO devirt 0 (0x10400 pages, 0x8000000000000001) skip 0
54:293 00:064 OCABC: MMIO devirt 0 (0x10400 pages, 0x8000000000000001) skip 0
Hex:
52:972 00:064 OCABC: MMIO devirt 0x0 (0x81 pages, 0x8000000000000001) skip 0
53:036 00:063 OCABC: MMIO devirt 0x0 (0x81 pages, 0x8000000000000001) skip 0
53:108 00:072 OCABC: MMIO devirt 0x0 (0x100 pages, 0x8000000000000001) skip 0
53:172 00:063 OCABC: MMIO devirt 0x0 (0x181 pages, 0x8000000000000001) skip 0
53:235 00:063 OCABC: MMIO devirt 0x0 (0x81 pages, 0x8000000000000001) skip 0
53:299 00:064 OCABC: MMIO devirt 0x0 (0x100 pages, 0x8000000000000001) skip 0
53:363 00:063 OCABC: MMIO devirt 0x0 (0x1 pages, 0x8000000000000001) skip 0
53:581 00:218 OCABC: MMIO devirt 0x0 (0x1 pages, 0x8000000000000001) skip 0
53:646 00:064 OCABC: MMIO devirt 0x0 (0x1 pages, 0x8000000000000001) skip 0
53:710 00:064 OCABC: MMIO devirt 0x0 (0x5 pages, 0x8000000000000001) skip 0
53:774 00:064 OCABC: MMIO devirt 0x0 (0x10 pages, 0x8000000000000001) skip 0
53:838 00:063 OCABC: MMIO devirt 0x0 (0xE pages, 0x8000000000000001) skip 0
53:902 00:063 OCABC: MMIO devirt 0x0 (0x2 pages, 0x8000000000000001) skip 0
53:966 00:064 OCABC: MMIO devirt 0x0 (0x100 pages, 0x8000000000000001) skip 0
54:029 00:063 OCABC: MMIO devirt 0x0 (0x1000 pages, 0x8000000000000001) skip 0
54:093 00:063 OCABC: MMIO devirt 0x0 (0x10400 pages, 0x8000000000000001) skip 0
54:165 00:071 OCABC: MMIO devirt 0x0 (0x10400 pages, 0x8000000000000001) skip 0
54:228 00:063 OCABC: MMIO devirt 0x0 (0x10400 pages, 0x8000000000000001) skip 0
Link to post
15 minutes ago, fabiosun said:
I have set to yes some of them
try to boot renaming this config properly and post newer debug log
usually in config MMIO comment you can put the name in ex decimal this is useful to check if conversion is fine
You are genius! It has booted now!:
1. But networking interface doesn't work. It is strange because I am using same LAN (Intel) on Proxmoxx with same kext and it is working.
2. How can I turn off logging in config?
3. Is it possible has two OpenCore on same disk? (One for Proxmox as backup and second for baremetal).
Thanks.
PS: Send me your paypal acc. I will send some donate 😉
Link to post
Ok. LAN problem solved (kext was only disabled). But I found next two small issues:
1. Can I ignore some SSDs? Because macOS always try to mount SSDs from Windows. This error appears after login:
2. After boot I see always this error about UPS:
128313048_205731067818932_1654125230619474636_n.jpg.9a9312d0060fe5efa355a7bb39cad268.jpg
Some other questions:
Is it possible use on-board WIFI and Bluetooth?
Link to post
Thanks.
for your PS 😛
please if you want help you can donate to forum..
No one here accept personal donations to help people 😉
So if you want to donate use donation button and help the forum and his admin to grow 🙂
1) I have used my EFI and my kext
try to put your ethernet kext and check the path in config.plist and in it
2) before turning it off.. 😛 put here latest debug..to check if MMIO are fine
3) you can use some apps to do it but I do not advice...uou can find a boot loader launcher also in this forum or in Insanelymac forum..
for me it is better to have different EFi
Link to post
  • fabiosun featured and unfeatured this topic
first two I do not know (maybe first error is due to your windows raid
for wifi bt see here (beta support of intel stuff)
audio should work as is (I mean onboard internal audio)
check your mmio
something is wrong
see first 0 and check in config
Link to post
23 minutes ago, fabiosun said:
maybe 8 conversion is wrong
remember, if you change bios option or card slot..it could change your mmio...
Good to know because I connect back nVidia GPU and all stopped work. Where is this log:
And How correct log looks?
Edited by jasin755
Link to post
on your OpenCore debug log search for MMIo inside
I have put yes on many of them
if you see also on 8 position
and there you see 0 (it means no or a bad conversion..or you have changed something in system)
so you have to recalculate your exact MMIO
1222324599_Screenshot2020-11-27at19_34_15.png.7f0b714a86ca5198b8bd176e9ba76d75.png.a12d6d2d9cfb5a5f68416e31b1215680.png
dinner time see you tomorrow..I hope you can try and solve additional simple things you have to do 😉
Link to post
And what about this zeros:
Link to post
Just now, fabiosun said:
you can try to put them to 0 (no in config)..but system then hangs
some combinations could also work..but many users leave them to zero...
How do you recognize what must be 1 and what can be zero?
  • whahahah 1
Link to post
1 hour ago, fabiosun said:
try this and see if something happen
also post your audio settings as you can see here
Can you send me what you changed in config? I don't want to replace all config because MMIO. Here my sound devices:
I think not all my USB are working. Because I had to switch keyboard and mouse into another USB port and how Can I disable and enable logging?
Edited by jasin755
Link to post
I found problem why mac shows problem with UPS. It is because I have Corsair Commander Pro and macOS thinks that is UPS :X
Source: https://forum.corsair.com/v3/showthread.php?t=192465
Possible solution for macOs 10.xx here: https://www.tonymacx86.com/threads/solved-catalina-thinks-my-corsair-commander-pro-is-a-ups.288458/post-2110721 for Big Sur solution hasn't existed yet.
Link to post
