Blast
Gigabyte x299x aorus master bios reset.
I managaed to get an efi to install catalina but more often when i try to boot it fails and goes back to bios saying boot failure detected. can anyone  please help me out thanks. Attached is my efi.
Share this post
Link to post
hi @Blast
your EFI is very..very weird
Put in your signature your exact system (Motherboard, cpu, GPU and so on)
Also post here your exact BIOS version and configuration settings
thank you
Share this post
Link to post
5 hours ago, fabiosun said:
hi @Blast
thank you
Thanks for your response. I am using bios version f3c on gigabyte x299x aorus master CSM disable other OS,  XMP profile 1, VTD disable , above 4G enabled.Thanks.
Share this post
Link to post
Hi @Blast
test this efi
CSM Off
4G ON
CSM on
4g on
off
off
on
off
if it does not work..post all your bios settings (CPU,USB,Boot) screen grab of it I mean 😉
Share this post
Link to post
1 hour ago, fabiosun said:
Hi @Blast
test this efi
CSM Off
4G ON
CSM on
4g on
off
off
on
off
can't boot with this efi no matter what boy settings i used. it gets to the picker then shuts down. thanks.
Share this post
Link to post
shutdown or reboot?
post screen capture of your bios settings
Share this post
Link to post
you say it shutdown..any debug or verbose lines?
it turn off your pc or it reboots?
it seems x299x bios are a bit crappy for mackintosh..but I can't say it
no experience with it
Share this post
Link to post
this is what i found in the efi.file attached.opencore-2020-11-19-064033.txt.zip
Share this post
Link to post
Sorry it is difficult to say..when I have had a X299 system I was happy with it and I have had different board like Asus She 10 G or Gigabyte Designare Ex
AMD is a different story..you have to evaluate well if Software you use is working well
Usually when you have configured well a x299 system..you have never a problem
With AMD it depends from many factor
I have an AMD..it is a beast for my job pipeline 🙂
Share this post
Link to post
ok so i cleaned up my efi and now everything shows ok on OC sanity checker website. but my PCI info is a mess in about this mac system report. How to i fix this?
i kinda have an idea it has to do with SSDT, but which ones?thanks.
Share this post
Link to post
explain
now it starts? 🙂
you mean in this tab?
if so check post a picture and check in your device properties (config.plist) if you have some device there
Share this post
Link to post
@Blast
I am seeing your original starting efi posted here
x299 does not need of DevirtualizeMMIO booster quirk to boot
Why are you using it?
Share this post
Link to post
57 minutes ago, fabiosun said:
explain
now it starts? 🙂
It shows thunderbolt but my UAD Apollo is not connecting. (thunderbolt is turned on in bios with security Slo- 0 No security.321092466_PCIinfo.thumb.png.b751c3c39e87c405b187f887d277d242.png321092466_PCIinfo.thumb.png.b751c3c39e87c405b187f887d277d242.png321092466_PCIinfo.thumb.png.b751c3c39e87c405b187f887d277d242.png
Share this post
Link to post
I think you need a patched firmware for your thunderbolt to see peripherals on OSX
see also this thread:
Share this post
Link to post
I am getting this text  in my EFI-Folders folder and I really do not understand what it means. it seems to be some type of error. can you please help me. Thanks.opencore-2020-11-20-161221.txt.zip
Edited by Blast
changed efi folder
Share this post
Link to post
it is only a debug txt
useful some time if system does not start
you can avoid to print it every time changing to a non debug open core version or to set to 3 this value:
Target from 67 as it is now to 3
also this should be to Disable...but if your system starts well leave it as is
Share this post
Link to post
Ok did all that but now i am realizing that the system will not boot from cold boot, instead goes to bios safe mode. I have to reset cmos in order to boot again. do you have any idea why this might be happening? thanks.
Share this post
Link to post
