Adobe Applications and AMD-OSX
@Ploddles: Thanks! Your scripts work with PS V21 (I initially ran them on V22 -- that didn't work)!  Now I think I can survive until Adobe releases new versions early next year supporting the M1 processor... Hopefully that will also work with our AMD hacks🤞THANK YOU EVERYBODY!!!
Link to post
14 minutes ago, Ploddles said:
It stops all the crashing you described but still problems with Liquify, Neural Filters and Colourise.
ok no news , it is the same as before
we reach that condition some time ago I think
Link to post
Did anybody successfully install parallels or VMware Fusion ? As soon as I try to create a virtual machine it errors out.
I guess they rely on intel processor?
Virtualbox does appear to work though but it is slow.
Link to post
21 hours ago, Ploddles said:
I did have it working but since wiping my beta install of BS and installing the release version, I can't get it working again, with exactly the same patches. 😞
The problem (at least for me) appears to be a codesign related problem. Lightroom v10 was crashing with:
Exception Type:        EXC_CRASH (Code Signature Invalid)
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace CODESIGNING, Code 0x2
Obvious not the best solution, but I was able to get Lightroom v10 to start with the patches by signing it myself with: 'codesign --force --deep --sign -' .
Link to post
I'm guessing you need Xcode installed for that?
Can you share the full command if it is just a terminal command?
Link to post
Yes. Just a terminal command. Codesign comes with Xcode. Full command I used was 'codesign --force --deep --sign - '/Applications/Adobe Lightroom Classic/Adobe Lightroom Classic.app', but this isn't really a great solution because I'm sure it breaks some other stuff. I'm actually surprised patching the other Adobe apps don't break them as well with regard to codesigning. I haven't had a chance to do a deep dive yet, but I guess one possibility is the patched files in the other apps aren't signed, but they are for Lightroom v10.
Link to post
That was what I tried but I get an error:-
/Applications/Adobe Lightroom Classic/Adobe Lightroom Classic.app: Permission denied
In subcomponent: /Applications/Adobe Lightroom Classic/Adobe Lightroom Classic.app/Contents/MacOS/LogTransport2.app
Link to post
Oops, brain fart by me, I should have realised 🙂
EDIT:-
For anyone else trying this solution by @nkw, for me it didn't work if I had already applied the usual patches. I keep a separate unpatched copy of all the Adobe apps, so I had to copy an unpatched version back to my Applications folder, run the code signing command and then apply the usual patches.
The first few times I tried to run Lightroom I had a prompt to enter my password, I had to do that about 10 times even though I selected "Always Allow". It did however finally get there after crashing if I didn't enter my password for a few minutes (I went to make a cup of tea).
It now appears to run fine but needs lots of testing to check if everything works.
Edited by Ploddles
Link to post
  • 4 weeks later...
21 minutes ago, Ploddles said:
The latest release of Lightroom Classic, V10.1.1, no long seems to need the patches/fixes to work.
Let's hope that Photoshop etc follow this lead.
Could you try from terminal this?
lipo -info
Then space, then drag and drop binary inside show contents Photoshop macOS or similar path inside Lightroom path?
maybe they compiled it for arm
thank you
Link to post
  • 4 months later...
@tomnicis working for a solution
for now I have seen and tested his work with photoshop 22.3.1 and latest after effects
and all seems to work fine (object selection tool and liquify or camera tracking in AE) without deleting or touching original included library
Grazie Nic 🙂
Link to post
