Adobe Applications and AMD-OSX
I just reran the PugetBench again (release version of AE) and had a score of 1057. Running it again now to see if I get a similar score on a second run. Tomorrow I will try the Beta version of AE, without the Adobe patches/fixes, to see if it will complete or stall at the last 5% again.
Link to post
Before patching it you can also try to move or delete two intel related plugin
mmx something and core somethingūüėā
later i will say better
Link to post
3 hours ago, Ploddles said:
New version of Photoshop has just been released, V22.0.
I'll download and try it, without the patches, later this evening when I get home. Hopefully the Intel specific stuff has been removed.
photoshop 2021 needs OSX greater than High Sierra
Thanks to @tomnicwe discovered that intel library are there......so I think same problem
  • Sad 2
Link to post
Boooooo, hissssssss Adobe.
Edit:-
Just tried it. It won't even load with the 'Adobe Crash Fix XLNC'.
Immediately crashes - loads of libtbbmalloc.dylib errors. Intel stuff but different dylib file than previous Photoshop version - libiomp5.dylib was the previous culprit.
Edited by Ploddles
  • Sad 2
Link to post
Adobe suite completely broke?
Edit:-
Link to post
2 hours ago, fabiosun said:
I have tested only photoshop for now..
Photoshop and Lightroom both crash out now. Strange that it is a different dylib file that is causing the crash.
I may try to install the old version of PS and copy the old version of the offending library file across to the new PS and see if that does anything for us. Just a PITA for Adobe to do this to us.
EDIT:-
Replaced the 2 offending dylib files. This time it gets a bit further, the splash screen loads, but it still crashes with a 'program error'.
Edited by Ploddles
Update
Link to post
EDIT:-
Edited Wednesday at 09:29 PM by Ploddles
I just renamed photoshop 2020 and installed the update (which is photoshop 2021), old still works if saved.
Link to post
ei @DriftwoodI hope all is fine
I think @Ploddlesas me, is trying to have a working 2021 in our AMD
And if I have understood well he wanted to try to use old library (with new one fail PS 2021 for us) and see
but in my case no joy
to many dependences I see in those new library..and by the way..intel stuff is present the same in this 2021 "arm" release
Link to post
If you install both the 2020 and 2021 versions, the 2020 version may also stop working because of a shared version of Camera Raw - V13.0
To get over this you can download and install the old 12.4 version. Download Link.
Remember to disable auto updates or V13.0 will be installed again.
Link to post
@fabiosun: Thanks for the Proxmox guide! ¬†Although¬†my bare metal hack (Gigabyte Designare 3070X) is running well with Big Sur (with just the sleep problem to content with), I can't run Photoshop or Davinci Resolve. ¬†Just download the Resolve 17 beta, it's still crashing at startupūü§®¬†¬†I've also tried all the patches from here (https://gist.github.com/naveenkrdy/26760ac5135deed6d0bb8902f6ceb6bd); these patches¬†help with starting Photoshop, but it¬†will crash if I do any editing!
Link to post
@shutterbug168
Davinci 17.1B beta 3 works (not tested other versions (it should be first release with Arm M1 compatibility)
Above is photoshop version I use
If you patch correctly it works well
also Liquify and camera raw and all filters without problems
Photoshop V22 for now has many problems
2006148011_ScreenShot2020-11-15at4_14_17PM.thumb.png.f9c7a4405fe6b7430d843bd4e3f86cd0.png
Link to post
There are a few different versions on there, the ones you want to use if you have Photoshop 2021 are :-
for file in MMXCore FastCore TextModel libiomp5.dylib libtbb.dylib libtbbmalloc.dylib; do
find /Applications/Adobe* -type f -name $file | while read -r FILE; do
sudo -v
echo "found $FILE"
[[ ! -f ${FILE}.back ]] && sudo cp -f $FILE ${FILE}.back || sudo cp -f ${FILE}.back $FILE
echo $FILE | grep libiomp5 >/dev/null
if [[ $? == 0 ]]; then
dir=$(dirname "$FILE")
[[ ! -f ${HOME}/libiomp5.dylib ]] && cd $HOME && curl -sO https://excellmedia.dl.sourceforge.net/project/badgui2/libs/mac64/libiomp5.dylib
echo -n "replacing " && sudo cp -vf ${HOME}/libiomp5.dylib $dir && echo
rm -f ${HOME}/libiomp5.dylib
continue
fi
echo $FILE | grep TextModel >/dev/null
[[ $? == 0 ]] && echo "emptying $FILE" && sudo echo -n >$FILE && continue
echo "patching $FILE \n"
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' $FILE
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' $FILE
done
done
AND THEN
[ ! -d $HOME/Library/LaunchAgents ] && mkdir $HOME/Library/LaunchAgents
AGENT=$HOME/Library/LaunchAgents/environment.plist
sysctl -n machdep.cpu.brand_string | grep FX >/dev/null 2>&1
x=$(echo $(($? != 0 ? 5 : 4)))
cat >$AGENT <<EOF
Label mkl-debug ProgramArguments sh -c launchctl setenv MKL_DEBUG_CPU_TYPE $x; RunAtLoad EOF launchctl load ${AGENT} >/dev/null 2>&1 launchctl start ${AGENT} >/dev/null 2>&1
After Camera Raw 12.4 installed, run:-
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Library/Application\ Support/Adobe/Plug-Ins/CC/File\ Formats/Camera\ Raw.plugin/Contents/Frameworks/libtbb.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Library/Application\ Support/Adobe/Plug-Ins/CC/File\ Formats/Camera\ Raw.plugin/Contents/Frameworks/libtbb.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Library/Application\ Support/Adobe/Plug-Ins/CC/File\ Formats/Camera\ Raw.plugin/Contents/Frameworks/libtbbmalloc.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Library/Application\ Support/Adobe/Plug-Ins/CC/File\ Formats/Camera\ Raw.plugin/Contents/Frameworks/libtbbmalloc.dylib
Link to post
