[TRX40] 3960X / Gigabyte Aorus Xtreme - Installation Issues
Just received my PCIE Firewire ( SYBA) which was recommended by a lot of users that works OTB but it doesnt show up or work. Is it something to do with mmio whitelist?
I downloaded DPCImanager and it shows up there but not in system preferences.
Edited by info
Link to post
3 minutes ago, fabiosun said:
simply...have  you connected  the power on it?
It doesn't have a power connector ! I've seen a few models that have molex connectors but mine doesnt!
It shows up in the bios and in DPCImanager ( screenshots ) or that doesn't matter?
The only thing i see is an 8 pin pad.
Link to post
WEEELLL......
Had to move my graphics card to slot 3 ( Don't kill me Fabio , i promised not to touch anything) and moved the firewire card to slot 2 and it works!
Any reason why it wouldnt work on slot 3 and 4? I can barely fit it to slot 2 with the GPU on slot 1 and it's blocking the 1 of the fans
  • whahahah 1
Link to post
11 minutes ago, fabiosun said:
it seems you have changed else
maybe CSm or 4g on bios?
in this way you could loose some functionality on sleep/wake, reboot or shutdown
you have to test
I double checked everything now. The only difference is I selected Primary Display PCIE slot and chose the 3rd one. Everything else is as last time ( Saved FABIO DONT TOUCH profile 😄 )
Is there a way to change the whitelist myself?
Link to post
18 minutes ago, fabiosun said:
before you have to see newer one
put #in front your mmiolist in config
and check the new mmio list (all skipped to 0 should be (Yoda) 🙂
I put # in front and I get everything 0 . Is the goal to have everything say skip 1?
Link to post
1 hour ago, fabiosun said:
try to enable one on one the latest four..with some combinations it could start..all no
Well the last 4 are 0 but it boots and restarts normally ! Thank you !
Btw meant to ask , do you get some lagging when you resize Chrome's window?
I'm still trying to figure out whether everything is proper graphic's wise since i still get the black screen.
Would you recommend any "testing" to see if everything works as it should?
Link to post
  • 3 weeks later...
No, no particular lag
You have to stress in your ideal pipeline job condition...f it is good for you 🙂
You have an ideal system
with black screen it is not ideal (imho)
Link to post
This is a great thread! I watched it like a movie, lol.
I also have the AORUS XTREME and will be trying the OC EFI folders on my machine.
I have the 3990x though, do I have to make any modifications to get that to work?
I also have the Vega64 since I can't use my 2080ti/1080ti/980
Going to try to install Catalina 🙂
Edited by boolean
Link to post
welcome here  @boolean 🙂
you have to lock in your bios your great cpu @32 cores 32 threads or 64 core without SMT (better for performance)
this is an OSX limits
Link to post
