[TRX40] 3960X / Gigabyte Aorus Xtreme - Installation Issues
info
please do not modify anything otherwise I will be crazy to understand
I will explain what I want to do
I would like that your system uses your MMIO..
so we have to convert it for you and see if in txt they are skipped to 1
I haven't modified anything ! Just wanted to inform you that i changed the graphics card just in case 🙂
yes because no pikera booting in there..I have thought you have Nvidia..
48:200 00:054 OCABC: MMIO devirt 0xE2100000 (0x81 pages, 0x8000000000000001) skip 0
48:237 00:036 OCABC: MMIO devirt 0xE3180000 (0x81 pages, 0x8000000000000001) skip 0
48:273 00:036 OCABC: MMIO devirt 0xEA400000 (0x181 pages, 0x8000000000000001) skip 0
48:309 00:036 OCABC: MMIO devirt 0xFA180000 (0x81 pages, 0x8000000000000001) skip 0
48:345 00:036 OCABC: MMIO devirt 0xFA300000 (0x100 pages, 0x8000000000000001) skip 0
48:404 00:058 OCABC: MMIO devirt 0xFEA00000 (0x100 pages, 0x8000000000000001) skip 0
48:440 00:036 OCABC: MMIO devirt 0xFEC00000 (0x1 pages, 0x8000000000000001) skip 0
48:476 00:036 OCABC: MMIO devirt 0xFEC10000 (0x1 pages, 0x8000000000000001) skip 0
48:512 00:035 OCABC: MMIO devirt 0xFED00000 (0x1 pages, 0x8000000000000001) skip 0
48:548 00:036 OCABC: MMIO devirt 0xFED40000 (0x5 pages, 0x8000000000000001) skip 0
48:602 00:053 OCABC: MMIO devirt 0xFED80000 (0x10 pages, 0x8000000000000001) skip 0
48:638 00:036 OCABC: MMIO devirt 0xFEDC2000 (0xE pages, 0x8000000000000001) skip 0
48:674 00:036 OCABC: MMIO devirt 0xFEDD4000 (0x2 pages, 0x8000000000000001) skip 0
48:710 00:036 OCABC: MMIO devirt 0xFEE00000 (0x100 pages, 0x8000000000000001) skip 0
48:747 00:036 OCABC: MMIO devirt 0xFF000000 (0x1000 pages, 0x8000000000000001) skip 0
48:805 00:058 OCABC: MMIO devirt 0x1040000000 (0x10400 pages, 0x8000000000000001) skip 0
48:841 00:036 OCABC: MMIO devirt 0x6EE0000000 (0x10400 pages, 0x8000000000000001) skip 0
48:878 00:036 OCABC: MMIO devirt 0x6F10000000 (0x10400 pages, 0x8000000000000001) skip 0
48:914 00:036 OCABC: MMIO devirt 0xCDB0000000 (0x10400 pages, 0x8000000000000001) skip 0
these are your MMIO with bios you are using by now and they are different from @Ploddlesone posted in OP of other thread
My questions are:
1) same BIOS
2)CSM on or off?
My questions are:
1) same BIOS
2)CSM on or off?
Same BIOS , the latest one available for the Aorus Xtreme and CSM OFF . I've tried with on and it gets stuck before booting
With the latest config and the AMD flag it boots normally and then randomly just freezes after about a minute.
LOGS.zip
Still the same.. boots up and freezes around a minute later. It's so weird that it's always at the same time!
Also, I've noticed that it's a bit slow while it's booting. When i click MacOS to boot it takes about 10 seconds to start showing the verbose mode
You have no idea much I appreciate your help. I would be lost !
opencore-2020-11-13-152306.txt.zip
config.plist.zip
Edited by info
OMG! It didn't crash yet ! You are a god!
The only weird thing is that it takes too long to boot and the logic screen takes about 20 seconds to turn from black to normal! Is that something that could be fixed?
THANK YOU THANK YOU!!!
Edited by info
@info
I'm thinking you didn't have my latest OC 0.6.3 EFI if it is giving you errors. If you didn't download it from the Dropbox link in one of my old posts from a week or so ago it wouldn't work with the latest Catalina/Big Sur etc.
Attached is my latest one (with serials removed). Try this, just to make sure.
10 minutes ago, Ploddles said:
@info
I've tried again but still the same error ! Latest bios right? It gives me this error first then the usual MACH reboot
