netgear
Bios Mod
alla prima lettura... non ci ho capito na mazza 🤔 che ci si dovrebbe fare con questo .efi, metterlo in drivers UEFI di clover?
Share this post
Link to post
Io avevo fatto una USB per la "cavia", gengik mi aveva passato la modifica da fare decompilando il BIOS.
setup_var 0x5C1 0x00
per la Z390 di un mio paziente :), ma si è rifiutato...
Share this post
Link to post
ho realizzato ora che è un clone potenziato di shell.efi 😏
ah quindi per sbloccare determinate cose nel BIOS, tipo quelle che hanno aggiunto in guida di OC 054
7.7 Quirks Properties
1. AppleCpuPmCfgLock
Type: plist boolean
Failsafe: false
Description: Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in AppleIntelCPUPowerManage- ment.kext, commonly causing early kernel panic, when it is locked from writing.
Note: This option should Certain firmwares lock PKG_CST_CONFIG_CONTROL MSR register. To check its state one XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
can use bundled VerifyMsrE2 tool. Select firmwares have this register locked on some cores only. XXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
AsmodernfirmwaresprovideCFG Locksetting,whichallowsconfiguringPKG_CST_CONFIG_CONTROLMSRregister XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
lock, this option should be avoided whenever possible. Modern firmwares provide For several APTIO firmwares XXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXX
not displaying CFG Lock setting , disabling which is much cleaner. More details about the issue can be foundin XXXXXXXXXXXXX
notes.in the GUI it is possible to access the option directly: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
  1. (a)  Download UEFITool and IFR-Extractor. XXXXXXXXX XXXX XX
  2. (b)  Open your firmware image in UEFITool and find CFG Lock unicode string. If it is not present, your firmware XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
may not have this option and you should stop.
(c) Extract the Setup.bin PE32 Image Section (the one UEFITool found) through Extract Body menu option. XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
  1. (d)  Run IFR-Extractor on the extracted file (e.g. ./ifrextract Setup.bin Setup.txt). XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
  2. (e)  Find CFG Lock, VarStoreInfo (VarOffset/VarName): in Setup.txt and remember the offset right after XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    it (e.g. 0x123). XXXXXXXXXXXXXX
  3. (f)  Download and run Modified GRUB Shell compiled by brainsucker or use a newer version by datasone. XXXXXXXXXXXXXXXXX XXXXXXXXXXX XXXXX XX XX
  4. (g)  Enter setup_var 0x123 0x00 command, where 0x123 should be replaced by your actual offset, and reboot. XXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
WARNING: Variable offsets are unique not only to each motherboard but even to its firmware version. Never XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
ever try to use an offset without checking.
Share this post
Link to post
Ah eccola avevo fatto un Immagine rdr per una USB avvaibile, si avvia questa SHELL che permette di modificare il BIOS, ovviamente conoscendo le Mod da fare...
Boot_BIOS_MOD.zip
Si esatto, magari dopo si avvia NVRam 😋
Share this post
Link to post
quella che hai attuato dovrebbe essere lo sblocco del cfg lock da shell
se hai calcolato correttamente  il valore che annulli con 0x00
0x5C1
modello e versione del bios z390?
Share this post
Link to post
Si Z390 Fabio
Ma non ha voluto fare la modifica, forse ci ripensa, io non ho insistito, ci mancherebbe 😀
Share this post
Link to post
si si ti chiedevo marca e versione utilizzata del bios
meglio comunque..soprattutto se l'utente non e' smaliziato meglio non fargli fare queste xose 🙂
Share this post
Link to post
Il 14/1/2020 at 17:51, netgear ha scritto:
Z390 Aorus Bios F11c
In teoria dovrebbe essere 0x5C1 come la mia e l'altra mia ex (Designare) ... l'importante è , dopo aver fatto lo sblocco con setup_var(meglio il 3), salvare la conf del bios...spegnere il pc...togliere  la spina...togliere la batteria del bios...aspettare un paio di minuti...riavviare...entrare nel bios...ti dirà che si è resettato ai valori di fabbrica..a quel punto, caricare il bios precedentemente salvato (la config)...godersi la Z390 Aorus sbloccata xD almeno fino a che Windows non ci mette mano / aggiorni il bios / ricarichi i valori di default 😄
Share this post
Link to post
In settimana ci torno ma non credo che farà la modifica, lungi da me convincerlo, alla fine un po' come me OS X lo tiene solo avere più icone nella GUI 😄
Share this post
Link to post
Ma perché torturate così queste macchine, staccare il cavo, togliere la batteria, ci sono modi più semplici per resettare un BIOS, lo dico perché spesso mi arrivano computer con la batteria rimontata all'incontrario 😄, schede video non inserite bene, fermi delle stesse spaccati. Sono nemico di tutto questo stacca attacca, una pratica molto diffusa.
I miei Nipoti sono uguali il computer tarda a riavviarsi, stacco la spina e ricollego...
Share this post
Link to post
