[Release] 10.14.6
Combo update disponibile https://support.apple.com/kb/DL2010?locale=it_IT">https://support.apple.com/kb/DL2010?locale=it_IT
Ha scritto dopo 35 minuti 41 secondi:
Info per aggiornamento
[code]The macOS Mojave 10.14.6 update improves the stability and reliability of your Mac, and is recommended for all users.
This update:
• Makes downloaded issues available in the My Magazines section of Apple News+, both online and offline
• Adds all publications in Apple News+, including newspapers, to the catalog at the top of the News+ feed
• Adds the ability to clear downloaded magazine issues in Apple News+ by selecting History > Clear > Clear All
• Addresses an issue which prevents creation of a new Boot Camp partition on iMac and Mac mini with Fusion Drive
• Resolves an issue that may cause a hang during a restart
• Resolves a graphics issue that may occur when waking from sleep
• Fixes an issue that may cause fullscreen video to appear black on Mac mini
• Improves file sharing reliability over SMB
[/code]
@ziocharly[/mention] apri il terminale e incolla questo comando:
curl -O https://raw.githubusercontent.com/Gengik84/MacOS_Updater/master/MacOS_Updater">https://raw.githubusercontent.com/Gengi ... OS_Updater">https://raw.githubusercontent.com/Gengik84/MacOS_Updater/master/MacOS_Updater && chmod +x ./MacOS_Updater && sh ./MacOS_Updater[/hidden]
ma comunque vedi https://github.com/Gengik84/MacOS_Updater">qui
poi segui le istruzioni
questo script di @Gengik84[/mention] è come dire... una figata spaziale, infatti permette di salvarsi in loco gli aggiornamenti (se si hanno diversi hack da aggiornare e ADSL scrause) ma ancora più interessante, puoi aggiornare mojave in HFS in quanto con questo FS gli aggiornamenti NON vengono segnalati
*nov* https://support.apple.com/kb/DL2015?viewlocale=en_US&locale=en_US">https://support.apple.com/kb/DL2015?vie ... cale=en_US">https://support.apple.com/kb/DL2015?viewlocale=en_US&locale=en_US
Post Date: Aug 1, 2019
File Size: 954.8 MB
fixes an issue that may prevent certain Macs from waking from sleep properly
Ciao a tutti! Sto aggiornando i miei hack a Mojave 10.14.6 ma rilevo dei problemi con lo script macOS_Updater su più pc (versione presa dal GitHub di @@Gengik84[/mention] )
Allego un'immagine dell'output del terminale (1)
A mia vista sembra corrompere il pkg dato che se anche lo backuppo su Scrivania e tento di aprirlo manualmente mi da la seconda foto (2) appena do il consenso con password all'installazione.
Se qualcuno ha idea di dove sbaglio me lo faccia sapere :)
https://postimg.cc/FYs9wqf2">1.png
https://postimg.cc/CZRwxqs7">2.png
Ciao ha avuto qualche problema in locale mentre scaricavi, quindi normale che il pkg poi non vada
quindi ripeti la procedura da capo
e comunque per le release puoi anche usare il comboupdate dopo averlo preventivamente sbloccato se sei in hfs
"Gengik84" post_id="39707" time="1565020812" user_id="2">
Ciao Gengik, Scusami l'ignoranza, come si fa a sbloccarlo? Con HFS_Friendly?
problemi ne da da 2 giorni, su pc diversi... forse è lo script? emoticon_vergogna
non penso.. usato da più persone sia per release sia poco dopo per aggiornamento di sicurezza...me compreso
per sbloccare i combo devi usare l'unlocker
Ha scritto dopo 3 minuti 28 secondi:
HFS_ComboUpdate_UnLocker
"Gengik84" post_id="39712" time="1565022138" user_id="2">
Okay, provato un'altra volta ma da sempre lo stesso errore anche riscaricando, sto tirando giù il combo e l'unlocker così provo a mano.
Grazie comunque default_wink
