WhatEverGreen alias WEG
@netgear[/mention] hai perfettamente ragione...
https://postimg.cc/vc21dRgf">LINK_TEXT>
avevo visto l'aggiornamento nella lista messo da poco, ma ufficialmente non è disponibile... solo chi ha la possibilità di compilarlo ha il WEG 1.2.9
Se a qualcuno serve, basta chiedere o vedere nel link del builder
  • 3 weeks later...
v1.2.9
Added AMD Radeon VII to detected list
Disabled automatic framebuffer usage on Polaris GPUs
Added preserve-names device property to preserve current GPU names
Added AppleVPA patching support, replaces NoVPAJpeg.kext (thx CMMChris and uglyJoe)
La versione 1.3.0 è stata rilasciata
[code]Fixed custom connector support for Radeon GPUs, thx @lwfitzgerald
Added disable-gfx-submit property to back ngfxsubmit=0 boot argument
Added GuC firmware loading patch for latest SKL+ drivers
Allow loading on 10.15 without -lilubetaall
Disabled NVIDIA performance fix on 10.15, as it now is built-in
Enable HDMI 2.0 patches on 10.14+ (Use at own risk in case of undiscovered change)
Added CFL graphics kernel panic workaround on 10.14.4+
Added infinite loop fix when calculating dividers for Intel HDMI connections on SKL, KBL and CFL platforms.
Added driver support for onboard LSPCON chips to enable DisplayPort to HDMI 2.0 output on Intel IGPUs (by @0xFireWolf)
[/code]
Release 1.3.1
[code]Fixed an issue that LSPCON driver fails to set the mode after the adapter power is off, i.e. sleep/wake up cycle.
Unified release archive names
Enforce complete IGPU modeset on Kaby Lake and newer (overridable by igfxfcmsfbs bootarg or
complete-modeset-framebuffers device property)
Disable VRAM testing on AMD GPUs on 10.14.4+ (based on vladie's patch)
[/code]
  • 4 weeks later...
  • 4 weeks later...
Release v1.3.5
  • Added Lilu 1.4.0 support, which is now the minimum supported version
  • Dropped legacy boot arguments (-shikigva, -shikifps)
  • Fixed handling agdpmod GPU property (in IGPUs and in conjunction with boot-arg)
  • Added -wegtree boot argument to force device renaming
  • Fixed FairPlay DRM playback patches on 10.15
  • Added shikigva and shiki-id aliases in IORegistry
  • Added applbkl aliases to IORegistry (data, 32-bit)
  • Added applbkl-name and applbkl-data IORegistry data keys to provide custom backlight data
  • Fixed applying CoreFP patches on Apple firmware, when they are not needed
  • Added shikigva=16 (repurposed) property to use AMD hardware DRM decoder in select apps
  • Added shikigva=128 (repurposed) property to use hardware decoder for FairPlay 1.0 (can be used as shikigva=144)
  • Do not disable DRM patches when shikigva is used even on Apple hardware for MacPro5,1 support
Release 1.3.6
Enabled CoreLSKD streaming patches by default for AMD hardware DRM on Ivy Bridge
Repurposed 64 bit for FP 2.x streaming hardware accelerated streaming patches (can be used as shikigva=80)
Fixed accelerator name update logic for X4xxx kexts
Fixed Verde IOGVACodec injection to make hardware video decoder work
Enable software TV+ decoding on all CPUs without IGPU (shikigva=256)
Added HEVC capabilities to AMD6 decoders for all GPUs (disabled by -radnogva or disable-gva-support)
Added HW decoder device-id spoofing via -radcodec boot-arg, by @osy86
