IntelGraphicsFixup
v1.2.7 https://github.com/lvs1974/IntelGraphicsFixup/releases">https://github.com/lvs1974/IntelGraphicsFixup/releases
Add igfxgl=1 boot argument (and disable-metal property) to disable Metal support
Implement Gen6Accelerator with IntelAccelerator rename to fix GVA warnings (use igfxsnb=0 boot argument to disable)
Harden solved symbol verification to avoid panics with broken kext cache
Replace connector-less Sandy Bridge framebuffer for unsupported macmodels from 0x30030 to 0x50000
In order to boot with igfxgl=1 on 10.13.x you may need to set the defaults:
sudo defaults write /Library/Preferences/com.apple.CoreDisplay useMetal -boolean no
sudo defaults write /Library/Preferences/com.apple.CoreDisplay useIOP -boolean no
V 1.2.6
Fix Skylake and KabyLake automatic framebuffer detection
Ensure standard connector-less framebuffers are used
V 1.2.5
Add basic automatic IGPU model detection if it is not set
Add IGPU device id correction (correct device-id should be set via device properties or ACPI
Add basic digital audio correction on (HDAU rename on Haswell and layout-id/hda-gfx where needed)
Add GFX0 -> IGPU automatic rename
Add MEI/HECI -> IMEI automatic rename
Add IMEI device id automatic correction on Sandy Bridge and Ivy Bridge
Add basic automatic AAPL,ig-platform-id injection (defaults to connector-less when AMD/NVIDIA is found)
Add GuC microcode loading on SKL (9.33) and KBL (9.39) in 10.13 (enabled via igfxfw=1 boot-arg)
Add igfxframe=frame boot-arg for framebuffer id injection in testing cases
Fix booting without -disablegfxfirmware boot argument on KBL GPUs
Fix compatibility with connector-less frames
Minor performance improvements
Se sui KEXT fai destro mouse e selezioni "ottieni informazioni" ti dirà tra le varie cose, quale versione è; vai sul sito di LILU e verifichi se la tua versione è l'ultima disponibile in download ;) se si hai la più aggiornata.
  • 4 weeks later...
