Sign in to follow this
SHIKI
v2.2.7 https://github.com/vit9696/Shiki/releases">https://github.com/vit9696/Shiki/releases
Disable iTunes hack on 10.13.5 and newerv2.2.6 https://github.com/vit9696/Shiki/releases">https://github.com/vit9696/Shiki/releases
Added Photo Booth to NVIDIA whitelist
Disabled hardware accelerated renderer hacks on 10.13.4 and newer (Apple fix)
Removed Sandy Bridge Gen6Accelerator patch due to better fix in IntelGraphicsFixup
Just a reminder: do NOT use shikigva boot argument, unless you know what you are doing. Shiki automatically chooses the optimal configuration for your software and hardware.
Solo un promemoria: NON usare l'argomento di avvio di shikigva, a meno che tu non sappia cosa stai facendo. Shiki sceglie automaticamente la configurazione ottimale per il tuo software e hardware.
v2.2.5
Reenable iTunes crashfix hack on 10.13.x (since 10.13.4 seems to only reduce crash frequency)
v2.2.4 https://github.com/vit9696/Shiki/releases">https://github.com/vit9696/Shiki/releases
Added an AppleGVA patch to fix Sandy Bridge accelerator name (shikigva=128)
Added /usr/libexec/AirPlayXPCHelper, ffmpeg, Quick Look, and Photos to the renderer whitelist
Added Broadwell patches for compatible renderer (discrete GPU hardware acceleration)
Implemented GPU detection for compatible renderer, whitelist, and snb name (you can remove shikigva)
Fixed invalid Sandy Bridge compatible renderer patches
Disabled automatic iTunes crashfix hack for 10.13.4 and higher (you may have to reset DRM once you upgrade)
Share this post
Link to post
Ciao a tutti potete spiegarmi perchè si usa questo kext? nei miei Hack avrei giovamenti ????
Share this post
Link to post
FAQ https://github.com/vit9696/Shiki/blob/master/Manual/FAQ.en.md">https://github.com/vit9696/Shiki/blob/m ... /FAQ.en.md">https://github.com/vit9696/Shiki/blob/master/Manual/FAQ.en.md
Protected video playback support and hardware video acceleration on various officially unsupported hardware
Si usa praticamente in quasi tutti gli hack
Share this post
Link to post
Share this post
Link to post
