Release 0.6.3
Added support for xml comments in plist files
Updated underlying EDK II package to edk2-stable202008
Provide fallbacks for NULL memory SMBIOS strings
Fixed BOOTx64.efi and BOOTIA32.efi convention
Fixed SMBIOS handling with multiple memory arrays
Fixed memory array handle assignment on empty slots
Fixed CPUID patching on certain versions of macOS 10.4.10 and 10.4.11
Fixed incorrect core/thread counts on Pentium M processors
Added SSDT-UNC.dsl ACPI sample to resolve X99 issues, thx @RemB
Updated builtin firmware versions for SMBIOS and the rest
Increased slide allocation reserve to 200 MB for Big Sur beta 10
Fixed assert when trying to enable direct renderer on blit-only GOP
Added support for custom memory properties
Fixed intermittent 32-bit prelinking failures caused by improper Mach-O expansion
Fixed failures in cacheless injection dependency resolution
Fixed detection issues with older Atom CPUs
Fixed ScanPolicy NVMe handling on MacPro5,1
Fixed I/O issues on platforms incapable of reading over 1MB at once
Fixed plist-only kext injection in Big Sur
Add ForceResolution option for enabling non-default resolutions
Fixed Ps2MouseDxe not properly loading under OpenDuetPkg
Added workaround for read-only errors on some X299 boards
Added support for x86legacy Secure Boot model
Added missing Secure Boot NVRAM variables required by 11.0
Added setting of system-id NVRAM variable
Added ForceSecureBootScheme quirk for virtual machines
Fixed kernel and ACPI patches failing to replace last bytes of memory
35 minutes ago, Gengik84 said:
Release 0.6.3
Aggiornamento effettuato alla 0.6.3
  • 5 weeks later...
Release v0.6.4
Added BlacklistAppleUpdate to fix macOS 11 broken update optout
Dropped HII services from OpenDuet improving size and performance
Fixed patching of injected kexts in mkext
Added support for launching from relative paths
Added direct path passing for tools via RealPath
Allowed launching tools and entries in text mode via TextMode
Fixed ACPI patches not applying if tables are in locked memory
Fixed EnableSafeModeSlide on macOS 11
Added AllowRelocationBlock quirk for older macOS and safe mode
Fixed CPU frequency calculation on AMD 19h family
Updated recovery_urls
Fixed DisableSingleUser quirk when Apple Secure Boot is enabled
Added BootstrapShort to workaround buggy Insyde firmwares
Changed Bootstrap(Short) to choose dynamic entry (requires NVRAM reset)
Avoided Boot prefix in RequestBootVarRouting to workaround AMI issues
Added bootloader patch support in Booter Patch section
Fixed startup hang on firmwares allowong reentrance for timer functions
Made pointer control optional for OpenCanopy via PickerAttributes
Added support for StartupMute variable in PlayChime
Added support for per-volume icons for APFS on Preboot
Removed HII dependency from OpenUsbKbDxe driver
Fixed undefined behavior in OpenDuet causing random crashes and hangs
  • Like 4
Puntuali come un Orologio. Pochi minuti per aggiornare e sei a posto per un altro mese, senza che questi upgrade diventino un Lavoro a tempo pieno.
Insomma che dire, pallati, organizzati, idee chiare di un progetto che è nato bene e prosegue ancora meglio :)...
Questa organizzazione nel suo "piccolo" sembra quella di un Sistema Operativo vero e proprio :)...
Fino ad ora Complimenti.
x AMD ci sono patches nuove?
Just now, Gengik84 said:
che c'entra scusa? 🙂
la patch AMD sono legate al sistema, non a versione di opencore
Ho fatto una domanda a zazo 😣 sorry
Stavo per editare ma mi hai anticipato......
Grazie mitico!!!!!
  • whahahah 1
Adesso, Andre1897! ha scritto:
Buongiorno a tutti , io ho la versione 0.6.3 , per aggiornare è abbastanza sostituire l'efi?? C'è una guida a riguardo?? Grazie.
Ciao, no
Devi anche aggiornare il config per le ultime aggiunte/modifiche fatte
